Question about Samsung AW0603B Air Conditioner
Room not cooling
The unit is clean. How do I add freon?
    Champion:
  • 210 Answers
Install linetap service valve. purge gauge lines, charge it to about
60lbs psi @ 70 degrees ambiant, 70psi @ 80 degrees ambiant. Etc.
Posted on Mar 23, 2008
The back is icing up, what can I do
there are a few things that could cause this. first check that if there are any filters, they are clean. next, check that the front coil is clean. you will have to open the case to check this. another thing that could cause this is the room temperature is too cool or possibly that the humidistat is up all the way in a cool room. if it is not any of these then a freon leak may have developed and the unit is low on freon charge. check all of these the let me know the results.
May 14, 2011 | Goldstar Dehumidifiers
Unit blows cool air out but doesn't cool room off. the compressor is not coming on. had freon checked ok
I have a question, how was the freon checked if the compressor is not coming on. If the compressor is not coming on, make sure it is received the proper voltage, if it has a capacitor make sure the capacitor is good. Also, how clean are the coils on the unit?
Apr 22, 2011 | Frigidaire FAS256R2A Thru-Wall/Window Air...
Ice on the evaporator
Make sure the coils are not dirty,if they are not dirty,add freon to the system,not much,feel the evaporator,when the evaporator is cool all over,and the condenser is warm all over,there is enough freon,add very little at a time,this system does not hold much freon,if this was helpful,at all,please rate,thank you.
Jul 06, 2010 | Fedders A6Y12F2D Thru-Wall/Window Air...
Room does not cool down
It may be low on freon or have a leak, I'm not sure if that particular unit has Service Ports on it to enable a recharge, consult your Owner's Manual for any Troubleshooting Tips. www.goldstar.com
Jun 05, 2010 | Goldstar KG6000R Window Air Conditioner
A layer of ice forms on the unit. Checked & replaced thermostat
here's the deal. unless you have a license to purchase freon you can't. Most likely the unit contains r-22 freon unless it was made before I think 1987 if made before then it is more than likely r-12. The reason appliance techs do not want to do this is because of the intensive set up in orderto access the system to add freon. they have to weld connections to access the freon and in such small areas it can be a massive pain. I would contact Whisper cool and see if they have any service centers in the area where you can take the machine for repairs.
Good luck hope this helped
Dave
Jan 14, 2010 | Vinotheque Whisperkool 4200 Wine Cooling...
Air conditoner model gwhd5000 goldstar does not cool
Hi, first you will need to know, what type refrigerant,(freon) your a/c used, if you need to add freon, there's a leak in your a/c. you will have to find and repair leak, before you can charge/ add refrigerant(freon) . automobile a/c can be easily recharge (add) to system, but your window a/c unit, has the same principles but different approach, if you don't have experience, you will have to call mechanic, make sure you have a freon leak, before calling mechanic, plug a/c on let it work, put hands close to a/c, feel or check temperature of air blowing out from a/c, make sure compressor is working/running, fans could be working/ but compressor not, also put a/c thermostat to max, your model no. GWHD5000. means your unit is 5000 b.t.u, (british thermal unit) measurement of heat transfer, am wondering if a/c is to small for your space/room. making you think it needs freon, 5000. b.t.u. is for a small space,like a room 10' by 10' like a storage area or small bedroom, keep bedroom door/windows shut. measure you room/space/area , the bigger space/area needed to be cooled, has a chart, maybe you can find it on internet, any way a 10.000 or 12.000 b.t.u a/c is better buy, for normal room/space etc. so check compressor especially to make sure working, a/c could be to small for space/room, check it at night to see if it's colder. don't try to put gas/ freon yourself, could be very dangerous. but before calling mechanic, check those thing, mention before, could be your a/c are to small, for space/room etc. remember before attempting any repairs, disconnect power. good luck.
Aug 20, 2009 | LG Goldstar GWHD5000 wall/window Air...
Friedrich RS10J10-C: Only half the coils are chilled...
If the evaporator coil is only half coated with water, this means it is low on Freon. You need a repairman to fix the leak and add Freon, but this costs way over a hundred dollars.
Jul 23, 2008 | Friedrich QuietMaster RS10J10 Air...
Carrier 42G250CF-1 won't blow cold air (on lamp flashes)
sounds like you low on freon, you will need a qualified tech to refill the freon.
Nov 19, 2007 | Heating & Cooling
Samsung AW0603B Air Conditioner Logo
63 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
