Question about Ovens
Melted control panel on Kenmore self cleaning oven
When I used the self cleaning oven feature, the hot air vented onto the control panel (above the stove part of the oven, in the back) and melted the enamel off the control panel under one of the knobs. This looks terrible.
Is this a flaw in the way the oven vents during the self cleaning cycle? If it is a flaw, is it a fixable flaw?
The reason I ask, is that if it is a fixable flaw, I may see about having it fixed and then trying to replace the control panel .
Perhaps I am just crazy and need to buy a new oven that doesn't have an enamel coated control panel because it is cheaper/easier.
  • Anonymous Nov 26, 2008
    I'm having the same problem!
5 Suggested Answers
SOURCE:
SOURCE: Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Posted on Jun 28, 2008
Krazytech
  • 725 Answers
SOURCE: No power on control panel
No reset for the control panel... you can try a hard reset ( remove power by triping the breaker for 1 min ) most like you have a safety thermo thats blown or a bad control... I can help you find them if you want to take it apart
Posted on Dec 15, 2008
DeBruce
  • 145 Answers
SOURCE: self-cleaning heat stains on the front facing panel
Use DeBruce polish. We Use Debruce Polish on all our cooktops and ENAMELED SURFACES. Debruce also works on stainless steel polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 24, 2009
  • 672 Answers
SOURCE: advise use of self clean feature on kenmore self clean oven 30''
If there is an up and down arrow on the control panel, you need to press the clean button first and then choose clean time with the up and down arrow. Be sure to remove the racks, if left in the oven they will be blackened by the extreme heat. Clean them separately with oven cleaner. Place them on newspaper and spray them.
Posted on Dec 07, 2009
F10 code on a Kenmore self-clean range model #970-6061
Your Kenmore oven has a built-in fault detector. When the oven detects an issue, the display screen on the control panel will flash a fault code. The F10 fault code on your Kenmore oven indicates that the thermal protector on your oven's control unit, or microcontroller (MCU), has overheated. If the MCU overheats, the computer stops all motor functions. Several items on your oven could cause the thermal protector to overheat. Therefore, you must troubleshoot the F10 code to determine why it appeared on your display panel. Instructions 1 Inspect the area around and behind the oven to ensure you did not place the oven next to a source of heat, such as a register vent or other appliance that becomes very hot. If this is the case, you must remove the oven from the heat source to prevent the issue from occurring again. 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears. 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
Aug 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore oven cleaning cycle has scorched paint on top panel
I would expect a standard appliance paint to scorch at the exhaust of the machine and would expect enamel paint at that point.
Jun 07, 2017 | Kenmore 40494 / 40495 / 40499 Electric...
I have Jenn Air 30 inch slide in dual fuel oven JDS8860BDP I used the self cleaning feature on my oven 2 days ago and it has had a very strange odor ever since. A chemical oily smell within a few feet...
The self destruct or self clean feature has burnt the wiring inside your range... do not use that feature it causes the range to get too hot...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 15, 2010 | Ovens
My oven is less than a year old. I ran a self cleaning cycle on it and now it will not heat up. There is power to it because the light comes on inside. Do you have any ideas about what might be wrong with...
Self cleaning features on all ovens tend to blow fuses.
It is best to use a oven cleaner rather than the self clean feature.
Your oven has a fuse on the rear of the oven that must be replaced.
You must unplug the range and remove the rear panel to access the fuse.
Use a volt/ohm meter to check the fuse.
No reading on continuity is a bad fuse.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Kenmore Gas Oven, model # 911.30465864 and have lost the manual. I want to clean the oven, (it has self cleaning feature), but I am not sure if I can use oven cleaners in Gas Oven or not. Can...
Just use some easy off and do not use the self clean feature. Clean it the old fashioned way. Self clean ruins expensive electronics.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 20, 2010 | Ovens
Some aluminum foil melted onto the bottom of my Kenmore Elite oven, which happens to have a hidden bake element. I happened to catch that this was happening to remove most of the piece of foil, however,...
Don't use self clean. Get some easy off oven cleaner. Self clean gets too hot and ruins expensive delicate electronics.
Feb 07, 2010 | Ovens
When i use the oven it stays hot after turned off. front panel, right under the touch buttons gets very hot.
This oven has an oven vent that comes out under the control panel usually to the right. Very poor design as this vents heat into the controls and can cause a control board failure, especially during a self cleaning cycle. Good Luck, Appliance Specialists
Dec 14, 2009 | Amana AEW3530DD Electric Single Oven
Advise use of self clean feature on kenmore self clean oven 30''
Dec 07, 2009 | Ovens
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
