Question about VinoTemp (VT60GNV) Wine Cooler
Wine-cicles My vinotemp is broken and I'm trying to figure out how to get a new control panel for it. I called the company and told them the temperature reading said "LL" and they told me it was either a freon leak or I needed a new control panel. The bottom row of wine had frozen, and the rest of the bottles were pretty cold. I had the cooler set back in a designated "nook," but it was removed after the wine froze. I plugged the unit back in when it was sitting in the middle of the room, but it ultimately went back to the "LL" reading. I plan on having a vent cut out in the nook for additional air flow, but could someone please tell me how to get a new control panel within the Vinotemp system? Thanks in advance! Kate
  • 1 more comment
  • Anonymous May 16, 2008
    My cooler suddenly went to 75degrees and will not come down - was told the same from vinotemp, but can't find a repair person in my area.
  • Anonymous May 28, 2008
    I had the same LL issue about three months ago. It was 25 degrees. I had a repair guy tell me to unplug it and it should reset itself and that it is probably the thermostat. I did, but now 2 days ago it went back into freezer mode. I have since unplugged and will be calling to see if they can replace the thermostat. I would like to hear if anyone has fixed this issue with this unit. Also, I have now purchased a temperature monitor that will sound an alarm if it goes out of range. Only $25 on Amazon. I highly recommend.
  • Anonymous Jun 13, 2008
    its running too cold and we dont know how to turn it off..any on off switch or is it only unplug?
I found the vinotemp trouble shooting webpage that has good info for several different VT models. Here is the link. http://www.vinotemp.com/troubleshoot_pdf.htm
I emailed VT and they gave me a price for the parts
VT-TC32ECB -$34.95 (control board)
VT-60Sensor -$14.95
here is their services information
Jane Barron
Service Department
VINOTEMP INTERNATIONAL
jbarron@vinotemp.com
T 310.886.3332 x231
800.777.8466
F 310.886.3310
Posted on May 30, 2008
The unit seems to be overheating and shuts off.
wer
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | VinoTemp 32-Bottle Wine Cellar -...
Do you carry the thermostat for vinotemp wine cellar TC32G?
You can purchase replacement parts for virtually all Vinotemp coolers directly from Vinotemp. Some parts are listed/available on Vinotemp.com (http://www.vinotemp.com/Browse.aspx/446/Replacement-Parts) But otherwise, just give their service department a call or shoot them an email and you can confirm the part number and purchase the required part.
Jul 23, 2010 | VinoTemp (TC32GB)
I have Vinotemp wine chiller model number VT-21TEDS-2Z. It is Dual zone and the bottom zone temperature is to low. I set it to 60 but it is at 49. The temperature controller does not seem to control it.
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
http://www.vinotemp.com/Resources/Documents/VT60.pdf
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Nov 07, 2009 | VinoTemp (VINO-24GN)
Vinotemp (VT-60), cools, but doesn't turn off regardless of the temp setting. It will run, cut off for aprox 5 seconds, then continue running. Is thermostat broken? Can it be repaired?
Nov 05, 2009 | VinoTemp VT-60 Wine Cooler
Where can I purchase a control board for Vinotemp VT-50SBW My Vinotemp wine cooler won't start.
You may want to check if your unit is still in warranty by calling cutomer service @ 800-777-8466
Aug 23, 2009 | Refrigerators
Vinotemp Wine Fridge Makes Noise, Doesn't Hold Temperature
Call the place you bought it and check on warranty .
Nov 15, 2017 | VinoTemp (VINO-24GN)
Vinotemp wine cooler won't cool
It sounds like your control module is bad. Vinotemp does list the replacement part as available at a cost of around $35
Nov 14, 2008 | VinoTemp (VT60GNV) Wine Cooler
VinoTemp (VT60GNV) Wine Cooler Logo
877 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
jackj59
Level 1 Expert
jasbo
jasbo
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
