Question about RCA RTD207 System
Rtd207 WHEN I TRY TO PLAY A DVD OR CD IT SAYS "LOADING" THEN GOES TO "OPEN" AND DOESNT PLAY AT ALL NOR DOES IT OPEN.
  • 3 more comments
  • lillianne Mar 30, 2008
  • lamp123 Apr 12, 2008
    won'y play we tryed everything that you said still wont play
  • JSABIR1 Oct 30, 2008
    WHEN I TRY TO PLAY A DVD OR CD IT SAYS "LOADING" THEN GOES TO "OPEN" AND DOESNT PLAY AT ALL NOR DOES IT OPEN. PLEASE HELP!
  • 7663 Mar 30, 2009
    After it inserts cd it says "loading", it spins up, the laser lights up, but ends up saying "no disc" and then "open". Does the same for any cd in any of the 5 positions.
  • lamp123 May 11, 2010
    we tryed what you said still not playing
  • 47 Answers
There may be something blocking the path of the dvd drawer. Take a peek inside. You might also try very gently shaking the machine. Do you have kids who might have shoved something in there?
Posted on Mar 19, 2008
Rca rtd206/207 disk will not spin, goes from loading to open everytime.
It is called the pladder motor, causes no B+ to the motor "5volts" the pladder motor is defective, or the laser pickup is not in sync with the pladder motor.
May 05, 2012 | RCA Televison & Video
The tray goes in but doesnt react to the play button and comes right out again.
THere may be a weak loading belt, the CD door cannot quite complete the cycle to close, so there for it ejects the disc.
Mar 28, 2012 | Philips DVDR70 DVD Recorder
My dvd/cd player gives me some kind of message when I turn on the power. I haven't used it in a couple of weeks. But I took out a cd to play in another room. When I came back to put the cd back into the...
what kind of CD/DVD-ROM are you using? Sometimes the CD are protected and cannot be played with every ROM. and also try playing another CD/DVD to study if it would do the same.About opening the CD/DVD-ROM if it is still not opening get an office-pin and push it into the small visible hole on the CD/DVD-ROM
Aug 02, 2010 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I have an RCA DVD/VHS combo with TVG. The DVD
This is a work-around rather than a solution. We put an audio CD in the tray and after closing the tray the unit begins to play the music. After waiting a few seconds we open the tray and quickly substitute a DVD and it loads OK. We had also tried cleaning the player to no avail. The CD approach is a pain but it does allow us to play DVDs. Jim
Jan 15, 2010 | RCA Televison & Video
Power dvd 5 will not play. When I put dvd tries to play floppy dr
OK, try this then
Put in a dvd again, when asked if you want it to open with Power DVD, press yes
When power dvd open, DONT press play, in the meny you will find the add button, press that one, and point it to the dvd, that will hoppfully mount the image to the power dvd since you told the program where the file is.
You know that power dvd dosent lay all formats right? so if it is a burned dvd you trying to play make sure that it is a format supported with power dvd
Let me know how it goes
Nic
Mar 30, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Doesnt play
Open it up, look for a loading belt (black rubber band about 2 cm diameter) and replace it.
Jan 21, 2008 | Philips DVD 622 DVD Player
My MD16XDVD9 doesnt work. Its power is on with the small greeen light flickering and the bigger green light steadily on. but the the DVD tray doesnot open automatically. Even if it is force-opened and a...
have you got it set on an IDE cable on it's own and if so have the jumper at the back set to master the other thing to do is power of pc and remove ide cable from all devices and leave power cable to burner then torn on pc if you have removed power and ide cable from hard drive then when pc boots in press button on cd,dvd drive to open tray then place cd lense disk or any cd in drive tray press close button and let device kick in if it picks up disk then try with a dvd disk with power on pc if all goes well try with a ifferent Ide cable to motherboard and reconnect harddrive and power up if all goes well the pc should recagonise it if not then get it replaced
Aug 06, 2007 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
RCA RTD207 System Logo
320 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
