Question about Gateway GT5408 PC Desktop
How to install a new disc drive - Gateway GT5408 PC Desktop
  • langhawkhawk Mar 18, 2008
    its a compaq presario C306 notebook
I can not open disc drive to insert CD , can not locate were to open csc drive
Posted on Dec 07, 2008
  • 95 Answers
What is the make of your pc?
Posted on Mar 18, 2008
Refer Acer m3970 Can not Install windows 7 of new hard drive
Factory back-up discs and recovery discs are intended to repair defective installations or to kick-start an installation that refuses to start so it is unsurprising they will only go so far.
Your system disc might be defective. This is a problem I have had with XP in the past. It is possible your CD/DVD drive has a dusty lens and is unable to read the disc properly or perhaps the new hard drive has a problem.
I suggest you instal the new hard drive as a slave in another computer and format it and run the chkdsk utility. If all is well reinstal in your computer.
Take a close look at your system disc checking for flaws and perhaps put a lens cleaning disc in your CD/DVD reader before trying again.
Oct 27, 2016 | Seagate Computers & Internet
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
Im trying to put a new seagate 40gb sata hdrive into my hp nc6320,when i try to load xp to install it tells me there is no hard drive in the computer
New Hard drives do not come with an operating system on them. It's basically a blank disc. You would need to have an XP operating installation disc or the original system restore discs that came with your computer in order to load the XP operating system. If you do not have either of these discs, you will need to purchase an operating system and install it so that you have something on the hard drive to run.
Mar 01, 2011 | Computers & Internet
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
I cant get my ibook g4 to run it turns on with blinking folder
Blinking ? mark folder means that your OS can't be found. Take out your RAM underneath the keyboard and re-insert and try again. Nothing? Install a different new RAM chip and try again. Nothing? Install your disc 1 install disc, power down, wait a few seconds, now press the power button to turn on, now press and hold the option button, until your disc 1 shows up, select it, and bring your pointer to the right arrow on the screen and press enter. Now your booting from the disc 1. Go to disc utility folder at the top of the screen and select your hard drive and then select repair disc permissions. Then shut down and reboot when finished. Nothing? Your hard drive is fu.k.d-Try re-installing the OS. Nothing? Your hard drive is really fu.k.d-You need a new hard drive. Installing a new hard drive in the iBook is a *****. You may want to pay someone to install a hard drive or you can just get a new laptop.
Mar 09, 2010 | Apple iBook G4 Mac Notebook
DVD DOES NOT PLAY, BRAND NEW FROM BEST BUY ACER EXTENSA LAPTOP EX5230E-2177 WILL NOT BURN A DVD OR PLAY A MOVIE
first make sure that the drive is installed properly. I would advise you to install it from the manufacturer's site. Let me know if you need the installation files.
Also, it can help if you can let me know if it reads any other discs- like regular discs. Try several different types- burned cd and dvd discs, brand new discs, original discs etc.
If installing it doesn't help and the drive will not read any kinds of discs, you will have to return the laptop to the store where you bought it, or try to return it to the manufacturer, maybe they can replace the drive.
Nov 12, 2009 | Computers & Internet
How to download unreadable disc for lexmark printer
The printer install disc may be faulty or your disc drive is faulty.
Insert the disc into a different computer, if it can be read then the problem is your disc drive.
If it is your disc drive, turn off your computer, open your computer and remove and reconnect the power and data cables on the "faulty" drive, switch on your computer, let it boot up and install the printer disc.
If it still cannot read the disc then you need to replace the faulty disc drive with a new one.
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Gateway GT5408 PC Desktop Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
