Question about Gateway Solo 2150CS Notebook
Gateway Solo 2150 Inverter Cable configuration
A friend has a Gateway 2150 where the cable connects to the inverter there are 5 wires, Black, Blue, White, Yellow, and White, The white connector that they connected with was destroyed when the screen was taken off and he does not remember what order they were in, so i am trying to find out what order they connect so that i can reconnect them.
  • 111 Answers
I bought a used motherboard from ebay.After a month it turned black screen again so can u help me
So you replaced the motherboard.
Well the systems are like laptops so you need to check LCD cable inverter and the LCD screen.
eres one that had a motherboard problem but the screen seems ok.GATEWAY ZX4300 01E ALL IN ONE AS IS FOR PARTS <<< i buy part as is when it system don't power up because its not screen related.
or pay seperate
Gateway All in One ZX4300 41 Inverter Board
Gateway All in One ZX4300 41 Inverter Board Cable DD0EL2IV000
Gateway All in One ZX4300 LCD Video Cable DDEL2CLC000
check if the system is compatible.
May 13, 2014 | Gateway One ZX4300-41 (PWGAW02017) 20 in....
Laptop screen becomes black after 1 second
You have to diagnose the problem.......
Right off hand I would say the screen Inverter is bad, but this is just guessing......
Why?
Because your laptop may not use a screen Inverter.
It may use LED's as backlighting.
Or, it may have a pinched/damaged video cable.......
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.....
A Backlight can be a CCFL, (Or more than one), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch, or about the width of this capital letter -> O <-
Average length is almost as long, as the LCD screen is in height.
A screen Inverter is used to convert the power, (Electricity), of the laptop; for the LCD screen, and the Backlight.
A laptop that uses a CCFL, (Or more than one), uses a screen Inverter.
A laptop that uses LED backlighting, May or May Not use a screen Inverter.
Seems when the LED backlighting technology first came out, a few laptop models Did use a screen Inverter.
As the LED backlighting technology evolved, a screen Inverter was no longer used.
Average example of a screen Inverter,
http://www.amazon.com/Screen-Inverter-HP-Pavilion-DV6000/dp/B0058TMLLY
The LCD screen is in the Display Assembly.
The plastic frame in front of the LCD screen, is the Display Bezel.
(Different manufacturers use different terms. The above is for HP, and Compaq laptops)
Display Bezel removed, the screen Inverter is located at the bottom of the LCD screen.
That is IF, the laptop uses a screen Inverter.
If the Backlight is bad on a laptop that uses LED backlighting, the LCD screen itself is replaced.
The LED backlighting is built-in.
The Video Cable, (Display Cable, etc), connects to the motherboard, usually under an area under the Keyboard, or just above it. Some models have the Video Cable connecting to the Bottom of the motherboard, and at the back.
Average example of a Video Cable,
http://www.amazon.com/Video-HP-Pavilion-DV6000-FOXDDAT8ALC0041A/dp/B003YDLDBK
The Video Cable then routes through Channels, and Latches; and comes up around the left Hinge.
It then goes on to up into the Display Assembly.
Depending on the technology used, (screen Inverter, or no), the Video Cable splits off, and connects to the screen Inverter.
The rest of the Video Cable then connects to the back, of the LCD screen.
Due to just normal opening, and closing of the laptop; the Video Cable may become pinched, and/or pulled on.
This can cause the connection at the motherboard to become loose, and/or at the screen Inverter, (IF used), and/or at the back of the LCD screen.
It may also cause damage to the Video Cable. (Stretched/Broken)
Point?
1) May be just a loose connection/s of the Video Cable
2) May be a damaged Video Cable
3) May be a bad screen Inverter
4) May be a bad LCD screen.
Post in a Comment, as to the laptop manufacturer name, and model number.
This way I can step by step you through diagnosing the problem, for YOUR laptop; and not post a bunch of generic information.
HOWEVER, it does depend on if the information is available on the internet. Such as a free Service Manual, and/or pictorial guides.
I CAN guide you even if there is not, but if there is; it just makes it simpler for you.
I can tell you it is easy. Once you have performed this procedure, you may want to do it for a friend, or relative; if the situation arises.
Regards,
joecoolvette
http://www.insidemylaptop.com/
Jul 09, 2013 | Computers & Internet
Manual for black and decker 1200 watt invertor
some idea for inverter, collect inverter circuit Books from market.
May 28, 2012 | Black & Decker Vector Cable Kit for 1200...
How to determine the plus and minus wires
You may check it with DC voltmeter. With voltmeter, red cable is plus, black cable is minus. Connect it wit the inverter.If your voltmeter is measuring positive, it mean the polarity is true, this is mean cable of inverter that connect with red cable of is plus, and with black cable is minus. If voltmeter measuring negative, try to flip the connection to measuring postive.
Apr 19, 2012 | Targus APV10US1 100W Slim Line Mobile...
Power comes on but screen stays black
The backlight inverter board may be bad, or worst case will be bad lamp. You should look to see if the cable comes off the inverter board first. You may learn maore here:
http://www.insidemylaptop.com/category/5-gateway-laptops/
Please post back what you find.
Nov 15, 2009 | Gateway M465-E Notebook
My monitor screen keeps turning off even when the
First open the Data cable (From AD card to Panel).If light comes means Inverter card is ok and AD card is bad..If not means Inverter card is bad and AD card is ok..If you want to repair the inverter card,pls replace all the Electrolytic capacitor and Enjoy..
Sep 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Black screen
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen, the inverter or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge.
Try also replacing the inverter.
In case the problem is not the cable or the inverter you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Jun 23, 2008 | Sony VAIO VGN-TX650P/B' Notebook PC
Opening a Gateway Solo 2150 laptop
I found the answer on another wed site. I tried it on my Gateway Solo 1500 and it works! The extra screws are hidden on top. You carefully remove the small face plate around the power button. I used a very small screw drive to lift it off.
Opening Gateway Solo 1400
by Aelanna - 2/3/05 11:04 AM In reply to: Gateway SOLO 1400 by hunjibunji
I'm also an A+ certified tech, but I've done notebook service for a lot of years. I just finished opening up a Gateway Solo 1400 and it was NOT easy! There are no screws holding the keyboard on the bottom of the machine. You can get the case open about 95% and there will be one area stuck, in the back near where the screen cable goes into the unit. There is a hidden screw on the top of the case next to the hinge. To get to it, you have to remove the two screws that hold the plastic hinge cover and pry off the cover. I only managed to find it after removing the keyboard, the display, and the panel with the LEDs and power button. (The screws holding the keyboard are on the top of the machine, underneath the cover with the power button on it.)
May 02, 2008 | Computers & Internet
Gateway Solo 2150CS Notebook Logo
82 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
