Question about Refrigerators
Compressed air is leaking from Zanussi freezer? Can it be fixed & is it dangerous??
I have a Zanussi Fridge-freezer and I stupidly used a knife to take some ice off the inside of the freezer. There is a bad smell coming from the freezer now. I'd say it's compressed gas, as I cut (5mm) the lining in the freezer with a knife.
Can this be fixed? and is it dangerous to be exposed to this gas????
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 32 Answers
Gas is not really dangerous, I wouldn't recommend breathing lots of it in or eating food that it comes in contact with as it also contains oil, As for it being repaired, you may be able to have it brazed, but dont get your hopes up. The only sure way to repair it, is to remove the evaporator, re-braze a new one in, vac the system and re-gas. It will probably be cheaper to replace the whole thing, if brazing the hole does not work.
Posted on Mar 19, 2008
How do I get rid of bad smell in the freezer part of my Zanussi fridge freezer ZBB 6286. Pilot light and fast freeze light are flashing.
first cut a potato in half and push it ion the middle of the freezer, it will absorb the airborne bacteria and reduce the smell . leave in freezer for about 2 hours then take out an throw away. next pour bicarbinate of soda into a bowl and put it into the freezer also leave overnight and smell should be gone
Mar 03, 2015 | Zanussi Refrigerators
The fridge compartment was heavily iced on the back of the inside it has now stopped working both fridge and freezer compartments no longer work
The fan blower and/or heater assembly has failed leading to ice build up inside. However it could be more simple 'cos the drain from the freezer to the pan under the refrigerator is plugged up - most likely with ice. You can see this drain line behind the refrigerator. When the freezer goes through an automatic defrost this drain line is used to get the water out of the freezer. Try a thorough manual defrost to see if the line opens up - you will have quite a bit of water in the tray underneath and it might overflow. That is probably all you will have to do to fix this problem.
Basically three things to look for: clogged drain, bad defrost timer, bad mullion heater strip.
Dec 03, 2010 | Zanussi ZI918 / 12K Bottom Freezer...
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
Zanussi fridge freezer wont stop making a whirring noise
Sounds like the unit is goosed and is trying none stop to get the temperature down in the fridge.
That is of course unless the ice is building up like an iceberg inside the cabinet in which case the thermostat has gone
Dec 06, 2009 | Freezers
Freezer not blowing air - bad smell in fridge
Your automatic defroster coil is open and needs to be replaced along with the fan in the freezer that blows the cold air around and also blows air into refrigerator.
Bad smell down below is food rotting in that section because it is not cold enough.
Mar 22, 2017 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Bad smell coming from fridge
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try
Apr 01, 2009 | Refrigerators
That is your problem.
The plastic supply lines over time deteriorate and wind up causing the water to smell.
Replace the plastic line with a stainless steel ice maker water supply line available at any home improvement center. They are 1/4 inch inside diameter lines and fittings.
They come in 5/10 and 20 foot lenghts.
After you do this run about 2 gallons of water through the water in the door dispenser. Discard the first 3 drops of ice from the ice maker.
Your ice quality will improve.
Mar 25, 2009 | GE Profile PFS22 33" Artica French Door...
Fridge freezer
did your friend use a knife to prize off lumps of ice? i bet he/she did and has punctured the evaporator. if so, not repairable
Jul 04, 2008 | Zanussi Freezers
Fridge does not cool
Sounds like ice built up on the evaporator coils inside the freezer. thus hindering air flow to the refridgerator section. Is there ice build up in the freezer? This is assuming the temperature control didn't get changed inadverttily.
Hope this helps
Jan 16, 2008 | Zanussi ZEBF250W Bottom Freezer...
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Refrigerators Logo
291 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
