Question about NetGear DG834G Router
Security My router I managed to change the SSID but omitted to change the password. How do i do that. Help!!! Jolly Jock
    Scholar:
  • 89 Answers
Hello, the same place you changed the SSID has a number of different options including username and password. You can also set you Security(WEP or WPA). Also turn on or off the firewall, if it supports one. If you didn't change the address it should be 192.168.1.1 Default password and username is usually "admin" for both or just password. Hope this helps.
Posted on Mar 18, 2008
SOURCE:
Belkin passwords
Please be more specific. Are you referring to the password to manage the router, or the pass-phrase/security key to authenticate with your wireless network/SSID?
Nov 17, 2013 | Computers & Internet
SSID
Hi John,
The SSID is either broadcast or sheilded, depending on whether the owner wanted to broadcast it or not. Many people often choose to shield the SSID as another layer of security for their WiFi. The SSID is needed to recieve a prompt for security keys, so without the SSID, you're stuck to look for another WiFi signal.
If the WiFi router is accessible to you - that is; you own it - you can access the router's setup page via any computer that is either 1) physically connect via network cable, or 2) connected via WiFi. You will need to point your browser at the router's setup page - often 192.168.0.1 is used. You will be prompted for a username and password. You didn't provide the model number of your router, but according to this Arris Router manual I found, if it was not changed from the factory default by the user - it will be "admin" and "password" (without the quotes). From here, you would go to the wireless settings to read or change the SSID and security settings.
If the router refuses the admin / password credentials, that means that it has been changed from the factory defaults. It will not be possible to view the router settings, but you can return the router back to the factory settings by locating the reset button on the device itself. With a paper clip or ball point pen, press and hold the reset button for several seconds, then release. This will remove all customizations to the router settings.
Using the manual as a guide, you can edit any of the settings as desired, but you should at least change the login password to something unique and set the WiFi security to WPA with a security key (word) that does not appear in the dictionary. Use WEP security *only* if there is no other type offered, as WEP security can be hack in under a minute or two by computer. As you can see, not broadcasting the SSID provides an additional layer of security. You can broadcast it is you wish.
Finally, record the the IP address, username, password, SSID, security type and key and attach to the underside of the router. Should you forget the info needed to access it in the future, you'll find everything you need on the label.
I hope this helps & good luck!
Jan 29, 2013 | Arris Computers & Internet
Changed password now can"t access router
Your laptop still insists on using the old password that's why it can't connect. Go to Control Panel > Network and Internet > Network and Sharing Center > Manage Wireless Networks. Select your router's SSID. Right click on it and change Properties > Security > Show characters. The old password that you forgot should appear. You may then change it to the latest one.
You may also click on the wifi signal icon on the lower right corner of your Taskbar, right click on the router's SSID, select Properties > Security > Show characters to reveal the old password you forgot and change it to the latest one.
Jan 03, 2013 | Belkin Basic Wireless Router
Reset password on wireless router
That more than likely mean you have put the password in wrong or you are using the wrong authentication type.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
Jun 08, 2012 | NetGear N300 Wireless Router
802.11g-SSID
How do I log into my D Link wireless router?
  • Open up a Web browser.
  • Type the address "http://192.168.0.1" or "http://dlinkrouter" (omit the quotes) into the browser's address bar, and then press "Enter."
  • Log in to the D-Link router with the administrator username and password.
  • The default username is Admin and the password is blank (nothing).
Mar 04, 2018 | D-Link Computers & Internet
My router is password enable before but no its not,how can i make it passsword enable again?i know my password
Here are some basic steps in setting up your Linksys router
Hope it helps!
Please follow the below instructions to protect your device:
  1. Connect your computer to the router using a network cable, or you can connect to the router through a wireless connection. Note that your wireless card in your computer must be enabled.
  2. Open your Web browser. Enter: http://192.168.1.1 in the address field. This is an internal IP address to access your router. Press the Enter Key.
  3. When the password request appears leave the user name field blank. By default, the password is admin.
  4. After logging in, you are not required to change the default administrative password. However, it's fully recommended that you change the default password by clicking on the Administration tab and Management. Enter a new password in the Password field and again in the Re-enter field to confirm.
  5. I recommend setting the Remote Management item as Disable. It will be another layer of security for your router. With this configuration you can only access your router for programming using a standard Ethernet network cabling.
  6. To save the new password, click Save Settings at the bottom of the page.
  7. To avoid intruders accessing your wireless connection we'll start to work with the Wireless tab.
  8. In the Basic Wireless Settings enter a name for your wireless network connection in the Wireless Network Name (SSID). Set the Wireless Broadcast to Disable.
    When wireless clients survey the local area for wireless networks to associate with, they will detect the SSID broadcast by the Router if the Broadcast is enabled. Do not broadcast the Router SSID. It must be Disabled.
    Note that your SSID should be set following similar rules for setting a password, e.g. at least 8 characters, a combination of letters, numbers and non consecutive characters.
    Disabling the SSID broadcast is not a strong security setting, but it can help prevent intruders from sharing your WLAN. Remember to save your settings.
Jul 15, 2011 | Linksys Wireless-G WRT54G Router
New tv, when turned on, makes the Belkin Router ask for a new password on the Router management. If you turn the TV off the Router is fine.
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Nov 28, 2010 | Belkin Wireless Share Router (F7D3302)
Our router is visible for others and everyone has free access! how to block this router for others?(network is unprotected now without any password or whatever). Thanks in advance. E
  • Please follow the below instructions to protect your device:
  • Connect your computer to the router using a network cable, or you can connect to the router through a wireless connection. Note that your wireless card in your computer must be enabled.
  • Open your Web browser. Enter: http://192.168.1.1 in the address field. This is an internal IP address to access your router. Press the Enter Key.
  • When the password request appears leave the user name field blank. By default, the password is admin.
  • After logging in, you are not required to change the default administrative password. However, it's fully recommended that you change the default password by clicking on the Administration tab and Management. Enter a new password in the Password field and again in the Re-enter field to confirm.
  • I recommend setting the Remote Management item as Disable. It will be another layer of security for your router. With this configuration you can only access your router for programming using a standard Ethernet network cabling.
  • To save the new password, click Save Settings at the bottom of the page.
  • To avoid intruders accessing your wireless connection we'll start to work with the Wireless tab.
  • In the Basic Wireless Settings enter a name for your wireless network connection in the Wireless Network Name (SSID). Set the Wireless Broadcast to Disable.
  • When wireless clients survey the local area for wireless networks to associate with, they will detect the SSID broadcast by the Router if the Broadcast is enabled. Do not broadcast the Router SSID. It must be Disabled.
  • Note that your SSID should be set following similar rules for setting a password, e.g. at least 8 characters, a combination of letters, numbers and non consecutive characters.
  • Disabling the SSID broadcast is not a strong security setting, but it can help prevent intruders from sharing your WLAN. Remember to save your settings.
  • Enable network authentication and encryption. Listed in order strongest to weakest:
WPA2-PSK (data encryption TKIP or AES)
WPA-PSK (data encryption TKIP or AES)
WEP (256 Bit) - Weak, but better than no encryption
WEP (128 Bit) - Weaker, but better than no encryption
WEP (64 Bit) - Weakest, but better than no encryption
plz do rate the solution if got help
Nov 23, 2010 | Linksys Wireless-G Broadband Router
Help me ! I lost my Belkin Wireless Play Router (F7D4302) SSID and passphrase that comes on a card with the router before i set up my router ?? so i can't set up and use my router please if you...
Hi this is not a problem any more for you
  1. the password and SSID default is not important any more
  2. lets we make it manually
  3. open one explore and erase the address bar htt://xxxxx
  4. need to be blank the address bar and type (router)nad press enter
  5. belkin setup page will be open and you can make all configuration needed for you new SSID and Password
  6. left side under the Logo Belkin you will see a the menu for setup
  7. go to channel and SSID click and if the router ask you for some password just click Submit and the next page will be open
  8. for default SSID is Belkin XXXX now erase all and type your new SSID one name only no numbers and click in to apply changes
  9. after that go to left side again and next to channel and SSID line there is a Security click again and if ask you a password remember just click on to submit(no password needed)
  10. Ok now you are in security mode click the security mode and change to 64bitwep or WEP only after that will appear one area were you need to input your new password 10 numbers and click apply changes.
  11. Next disable wife protect setup and firewall in to your router .
Ok your new SSID and Password is setting just look for your wireless signal and be connected
any problems just ask me for a remote your PC.
Good Luck don't forget to rating me kk thanks
Oct 21, 2010 | Belkin Wireless Play Router (F7D4302)
I need to secure my router. I had payed to have it set up when I was getting my computer fixed only to find out that my son could log on with out a password. How can I fix this.
To set up wireless router security, there are four main steps, which are the same for most routers. These are:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
4) Enable WPA encryption.
************DETAILS************
1) Login to your router, using a wired (Ethernet) connection.
Make sure you have a cabled connection to your router. Then open a web browser, and type the router’s IP address into the address bar. For example, this is http://192.168.0.1
If you log in successfully, you should then see the router configuration screen.
2) Change the router login password.
To change the router password, find a menu option such as Setup, Tools, Administration, Basic Settings, Management, or Utilities.
Set and confirm a new login password. Click ‘Save/Apply’ when finished.
3) Change the SSID (network name):
The SSID or Network Name is the name you see when you are looking for an ‘available wireless network’.
To access this setting, find a menu option such as Wireless, Wireless Security, Security, or perhaps Advanced Settings.
Change the SSID from the default, to anything you like. It is case sensitive, and you can use up to 32 letters – but do not use something that could identify you, or your location. Click ‘Save’ or ‘Apply’ when finished.
Find the Wireless Security or Wireless Encryption Options section - often in the same section as the SSID (eg for Netgear – it’s still in Wireless Settings).
You may have a number of encryption options. Select WPA-PSK or WPA2-PSK (good choices to start with).
You then need to enter a network key. The box to enter this may be labelled Network Key: it may also be labelled WPA-PSK, WPA Shared Key, PSK, Security key, Passphrase, Pre-shared key, Authentication key .
Note down your network key carefully. You will need this to connect wirelessly. Click ‘Apply/Save’ when finished.
That's it - you have done enough to secure your network, and can close the screen.
Apr 08, 2009 | SMC Barricade 7004VWBR Wireless Router
NetGear DG834G Router Logo
69 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
