Question about Lands Phones
Hi, I have a sony ericson w900i, i press the on button and the phone just comes up with a white screen and whatever i do apart from turn it off the screen remains the same, just white? please help thanks
    President:
  • 778 Answers
Ewok712,
Is it GSM, CDMA, etc... (doe's it require a SIM card?)? I have seen GSM phones that require a SIM card with "White Screen" only when no SIM is inserted, so try with a SIM if that's the case?
You could remove the battery for a while, then replace it and see if it revives your display. Otherwise,you could check your warranty/insurance on the phone.
Posted on Mar 18, 2008
  • Lands Phones Master
  • 13,433 Answers
I would take the phone to the shop where you bought it or a professional. for analysis and possible repairs, In most cases these kind of problems are hardware and we cant really help you that much.
good luck, If you need more asistance, let me know.
  • 4,102 Answers
Hi
the problem relates to either the information not getting to the screen usually due to the phone getting dropped or banged around as sometimes the screen conection comes lose and stops the info getting to the screen the other problem could be that the screen itself has a problem and replacing it would solve both of these problems.
Their is nothing you can do or press to solve this problem its a case of replacing the screen witch isnt easy to do as youll need special tools and also get the parts can be a problem
Unrestrict sony ericsson w900i
If you want to remove the network restriction on a Sony Ericsson W900i, You need to enter it's unique unlock code. You can get the unique unlock code for a Sony Ericsson W900i from ClassicUnlocking.com at affordable cost.
-------UNLOCKING INSTRUCTIONS-------
1 - Switch ON your Sony Ericsson W900i without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
Jul 02, 2014 | Cell Phones
I am using a sony Ericson W900i. I turned my phone off and tuned it on again but I wasn't able to operate it anymore. A message appeared on the screen saying: Configuration Error. Please contact your...
...you need to reprogram it to you're trusted mobile repair shop ...i had that problem before too and that's what i did.... they just reformat my W900i and they install a new software ...
Mar 31, 2011 | Sony Ericsson W900i Cellular Phone
How to change the battery of Sony-Ericson HBH-610
figure out how to open it then take the battery out then put in the new one duh
May 02, 2010 | Sony Ericsson HBH-610a (Auto Pairing)...
I forgot my past code for sony ericson w900i code what do i do
try ro make MASTER RESET .... after the reset the default code is 0000 ....
Dec 02, 2009 | Sony Ericsson W900i Cellular Phone
Freezing, flashing backlight on and off, vibrates
my w900i turns on, and can charge. just got re-flashed from a white screen of death. now every time i try to acess something on the phone such as a midi file or the master reset, it freezes and the back light flashes on and off and the phone vibrates. is this a software error? does it need to be reflashed?
Apr 08, 2009 | Sony Ericsson W900i Cellular Phone
W900i not working
i have the same problem.. i had it fix in a local repair shop.. it cost me around 400 pesos...
Aug 24, 2008 | Sony Ericsson W900i Cellular Phone
Sony ericsson w550i has white screen problem
Try taking out the battery and leaving it out overnight then put back in and try to turn on again. If this doesn't help, then your phone's software needs to be flashed.
Jun 04, 2008 | Sony Ericsson W550i Cellular Phone
Unable to use my w900i's phone functions, can only listen to the mp3 player
When I try to charge my W900i the transfer files screen appears as if its connected to a USB device. When I connect it to a USB device I cannot seem to get the correct drivers installed to enable internet use through my phone. I also cannot save any new pictures taken with my camera as it's not saving them to the phone. When I check the memory it says that I have ample memory though...why is this? I connected my phone to my pc and it shows the phone memory but it doesn't connect to the PC suite. PLEASE HELP!
Marlon
Jan 26, 2008 | Sony Ericsson W900i Cellular Phone
Sony Ericsson W900i Pairing With HBH-608
turn the bluetooth on wait 10 seconds after the bluetooth has turned on. after it has turned on hold the (+) & (-) volume buttons at the same time for about 5 seconds. the light on the outside will then start to flash green and red, and it is ready to pair to your phone.
Oct 05, 2007 | Sony Ericsson HBH-610a (Auto Pairing)...
My phone is off but it wont turns on
Ensure the battery has a good charge on it, and attempt to turn the item on while plugged in to the charger. If this does not work, I would return it for a replacement.
Jun 09, 2007 | Sony Ericsson HBH-610a (Auto Pairing)...
Lands Phones Logo
94 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
