Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE profile side by side wiring connection question
When replacing the two defrost heaters I found a wire with male connector (white with stripe (brown ?) hanging there by the defroster heater main coonector. Any ideas what it connects too?
  • Anonymous Mar 17, 2014
    WR9X480 has black wire loop attached to terminal#1 and black wire from inside timer attached to terminal #3. Do I leave these wires as is and connect the color coded wires to the terminals or do I remove the black wires first? Do I detach the black wire black wire from Terminal #3 and use it as the ground?
    Novelist:
  • 184 Answers
IT COULD BE A JUMPER FOR THE DEFROST BI-METAL OR A
WIRE USED FOR DIAGNOSTICS OF SOME KIND. IF THERE ISN'T ANYTHING AROUND TO PLUG IT INTO, I WOULDN'T BE CONCERNED. IF THE REFRIGERATOR DOESN'T OPERATE PROPERLY LATER ON, THAT MIGHT BE ONE PLACE I WOULD REVISIT.
Posted on Apr 10, 2008
6ya staff
SOURCE:
Rear speaker wire colors for 2008 harley Davidson ultra classic flhtcu
Hi Danny, found a diagram from an earlier model but the colors schould be the same. Right speaker light green with a brown stripe and positive side of speaker gets the green wire. Left speaker white with a brown stripe and positive side of speaker gets the brown wire. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 12, 2015 | Harley Davidson Motorcycles
Heil outside fan motor 3 wire rd/blk/br new dayton motor 4 wire blk /br /purpule /brown with white strip Need help on wiring
Hi, the new motor takes its own capacitor to run it. This is what the 2- brown wires are for, one will have a white stripe. You will need to but a seperate run capacitor for this motor, a 5 uf, 7.5, or what ever it calls for. they should have told you when you bought the motor. It will have to spade connectors on it where the brown wires connect alone. Use the dual capacitor if that is what you have for the other 220 volt wires.Black and purple will be your 2 hot wires.You can connect either one to the old capacitor on the fan terminal and the other to the load side of the contactor, so when the contactor closes it will energize the motor.Or, take both the black and the purple wires and to the load side ( outlet side ) of the contactor, connect one to one side and the other to the other side. The line side is where your 2 hot wires that connect to the contactor from the incoming wires from the electrical box, you want to be on the other end. I would connect the black to the contactor load side and purple to the old capacitor as long as the old wiring is still on it as it has to be fed by a hot wire from the contactor. Each wire, blk, and purple has to have 120 volts to each one and you can get this a couple of ways. The contactor has several terminals that are not used and if you wire them on the outlet side, they will only be energized when the contactor is closed on a call from the stat, very easy to do. You will have to get a coulple of crimp on connectors to put on the ends of the wires, but the brown ones should already have them for this capacitor. Do not try to put the brown wires on the old run capacitor as you will burn out the new motor! Go get the small run cap for these 2 wires for about $10. I know that you can do this wiring change just remember the blk is hot 120, and purple is hot 120, = 240.volts. If you have removed all of the wires from the old capacitor, then use the contactor to connect to. The compressor wires must stay on the old run cap on the hermetic side and this old cap. must be fed by a hot wire from the contactor to the common terminal, that is marked with a C..If you look at the new motor diagram, it will show you also. Please dont forget to rate me as I know you will be kind, and I will check in on you to see how you are doing. Get this capacitor and it will run. This is a must!! Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 07, 2010 | Goodman CLQ36AR49 Air Conditioner
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
GE GSH22KGM Frig not defrosting again
I would suggest replacing the # 4 thermistor , which is a 1 " long white piece with 2 white wires attached , clipped to the top of the coils . This thermistor , tells the main control board , the temperature of the coils and the board decides what to do next , such as defrost , end defrost cycle . Also , replace the defrost thermostat , the 1 inch cylinder with 2 wires going to it , which is also clipped onto the coils . This thermostat , cuts the heater off when it reaches a certain temperature , to keep the food from defrosting . It may also help , to replace the # 5 thermistor , which is below the coils , slid into a housing , with 2 white wires going to it also . This thermistor , tells the board , the actual freezer temp , so the compressor will cycle off/on , and the fan speed also . All 3 parts , are relatively not expensive . Be sure to get wire connectors because they do not come with these parts .
Apr 14, 2010 | GE GSH22KGM Side by Side Refrigerator
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
"i'm replacing my Rheem RBGC 08KA FAU blower motor. My dayton 3lu83j 4 speed motor has white, black, red, yellow,orange, brown, and brown with stripe wires. My old westinghouse motor has only one brown...
There should be a wiring diagram on the side of the new motor.
The brown and the brown w/ white go to the new capacitor you should have bought with the motor.
The black and white go to your L1 & L2 power source. The remaining wires must be capped off.
Feb 25, 2010 | Dayton Heating & Cooling
Ge side by side profile. freezer works fine, all
Hi!
First of all you need to clean the coils (condenser coils under the unit or evaporator coils inside the freezer). The coils inside could be iced over because of failure of defrost system. Now check that the condenser fan under the fridge is working properly. Check that the fan in the freezer work which pulls cold air from the coils inside freezer and blows it to the fridge side. Are the temperature control knobs in the fridge adjusted correctly? It actually just opens a vent to let more or less cold air in from the freezer. It takes a while for the ice to build up in the freezer enough to affect the cooling.
My first guess would be the defrost timer. You can manually turn it to engage the defrost cycle and observe whether or not the defrost heaters come on. Now use a hair dryer to speed up melting the ice when there is lots of ice buildup. Most timers are 24 hour timers. It will turn the defroster on every 6 or maybe 12 hours depending on the model.
Before testing the defrost heater, unplug the refrigerator to avoid an electrical shock hazard.
The defrost heater is usually located at the back of a side by side freezer or under the floor of a top freezer. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, icemaker and the inside rear or bottom panel of the freezer.
The heater is connected by two wires. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Where is the defrost timer located on GE model# GSS20IEMDWW side by side refrigerator? My freezer works but the other side is warm. I took the freezer panel off and it had a thick layer of frost...
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
Jun 04, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
GE (PSS26MSRSS) Side by Side Refrigerator Logo
67 people viewed this question
Top Refrigerators Experts
Brad Goodale
Jeff sanchez
Level 1 Expert
Peter Taylor
