Question about Dryers
Runs but does not heat up - Dryers
  • mtarlton Sep 24, 2008
    no heat even though dryer is running. I checked for lint build up near the lint screen and at the exterior exhaust point.
  • Anonymous Nov 04, 2008
    no heat but runs ,heating element works only when door open and door switch depressed
  • 156 Answers
Most commen problem is the thermo fuse eather on the lint chut are the one on the heater canister
Posted on Mar 19, 2008
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
Dryer runs but does not heat. It runs continually
If your dryer never quits on its own, then your main selection switch may be bad. Even if the clothes don't dry, the timer should still only run to the end of the cycle and then stop. The problem with the lack of heat could also be caused by a bad timer switch, but that is rare. Usually it is caused by a bad igniter/heat sensor unit. Sometimes you can use a piece of sandpaper and clean the carbon off of the sensor and then it will sense heat when the pilot flame starts, then it will let the gas valve send gas to the main burner. The heat sensor it the part that is in the flame of the pilot light.
Jun 11, 2010 | Roper RGX4634KQ Gas Dryer
Microwave runs but doesn't heat
Most likely shorted the transformer for the magnatron,Its expensive to repair and you should consider just replacing the micro.
Jun 01, 2010 | Microwave Ovens
Heat pump runs in em heat when outside temperature is low
Yes, you may turn to em heat only. May this confirmation help you.
Jan 06, 2010 | Heating & Cooling
My dryer runs but won't heat. What can I do to
My electric dryer runs but will not heat. this is for models 65731, 65741 or 65801. Help!
Dec 07, 2009 | Kenmore Dryers
Heat runs constantly. Feels cool unless emergency
make sure out door unit is running not just the fan out side should hear compressor and in heating mode the large copper line should be hot fan should be in auto position on stat hope this helps
Dec 06, 2009 | Heating & Cooling
Dryer runs but no heat
I have same problem with the kenmore elite. It runs but will not heat up. It is gas. Anyone same problems or easy solution.
Nov 19, 2009 | Frigidaire Dryers
Dryer runs but no heat, it heated before moved?
you've probably jarred the heating element too hard and if they are older and brittle from heat they will break just looking at them
Oct 02, 2009 | Dryers
My roper dryer is not heating
YOUR HEATING ELEMENT IS BAD OR YOUR HEATER BOX FUSE IS BAD,IF YOU HAVE A METER YOU CAN CHECK THEM BOTH-LET ME KNOW-MIKE
Dec 06, 2008 | Roper REX4634KQ Electric Dryer
Runs fine just no heat.
the heating element is out, or it has overheated and burned the wiring that runs to it
Mar 07, 2008 | Roper RES7648E Dryer
Dryers Logo
133 people viewed this question
Top Dryers Experts
