I just installed a Wireless router and the security type is WPA I need to change it to WEP How do I get in to change it? I went into http://www.routerlogin.com like it said I could do to change any of these settings. Butit won't let me
    Scholar:
  • 67 Answers
If you reinstall the router using the CD it came with, the install program will recognise that the router is already installed. But, when you come to the security part of the install, everything is new. You can then change it to WEP if you want. Why would you want to? It's fairly easy to crack into.
Posted on Mar 18, 2008
SOURCE:
My son went to youtube and found a video on how to change WPA to WEP. Now my network is not working on my printer and laptop
you need to reconfigure your printer and laptop to WEP but I don't recommend it as WEP is terrible and easy to crack.
connect to your router via cat 5
open internet explorer and browse to http://192.168.1.1
login with the default login is blank. pass is admin.
go to wireless and to wireless security.
change it back to WPA personal.
change the passphase for the wireless password.
use the new passphase you created and tell your printer/laptop to join your wireless network
you may want to change your wireless password too so your son won't reconfigure your router again.
do this by going to administration and change the password there.
Apr 03, 2011 | Linksys Wireless-G WRT54G Router
When my son tries to get onto internet he keeps getting error code: 051099-1 - what is the problem please?
This is a problem with the security settings on your browser. To do what you were doing when the error code appeared, change your security type to WEP, or disable security.
hope this helps.
Mar 06, 2011 | Nintendo DSi XL Burgundy
How do I secure my network
etting up wireless security is the easiest way to prevent other people from using your wireless internet connection. Your Linksys router supports three (3) of the most commonly-used wireless security types WEP, WPA and WPA2.
This article will explain the difference between WEP, WPA, WPA2 and how to set up each of them.
Nov 06, 2010 | Linksys WRT160N Wireless Router
Is the PIN on the bottom of the router the same as the WEP or WPA?
WEP or WPA are the types of wireless security. If your wireless network is secured then there will be a password on the network that is called as wireless network key or passphrase ( WEP or WPA key ). PIN number is different than WEP or WPA.
To check the wireless network key ( WEP / WPA) you will need to access the router settings page.
On that page , you will find all the settings of the router.
Apr 29, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
How to identify security type on my belkin wireless router relative to nintendo wii security type options
For nintendo wii , you can use the security WEP or WPA ( PSK ).
These 2 security types will works with WII. If you put WEP,then 10 digit number will be the security code.
To change the security on the wireless network, you will need to open the set up page of the router.
Once you change the security on the router, it is recommended that you will change the wireless network name SSID. after changing the wireless settings , you will need to connect to the new wireless network on all your wireless devices like laptop , wii.
Click Here for step by step instructions
Mar 05, 2010 | Belkin Computers & Internet
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
Need to change my security PW to WPA from WPA2 which xbox360 does not support
Went into my router settings and changed the security password for my network to WPA only. This allowed my Xbox 360 to see my network.
Apr 11, 2009 | Computers & Internet
Belkin Wireless G desktop card & BTHome Hub
hi..
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility only...how come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
Jan 26, 2009 | Belkin 802.11g Wireless Desktop Network...
I have a Belkin FSD9230-4 wireless router, it says it is unsecured when I go on using my laptop. How do I secure the wireless connection?
You will have to login to the router's web utility, go to wireless security settings, and choose either WEP, or WPA. After selecting one of the two you will need to select a passphrase which you will need the next time you connect. I suggest WPA personal, because it offers a stronger encryption method than wep, making it more secure.
May 04, 2008 | Computers & Internet
Security type
http://www.routerlogin.net
disconnect router from modem
hook up a cat 5E cable from your pc/laptop to the router
log in to router, default login user=admin password=password.
press enter and the router screen will come up go to wireless settings and select no security/ wep/or wpa
select wep
page 3-8 (page 30 on pdf) describes in detail
link
Mar 18, 2008 | NetGear WGR614 Wireless Router
Open Questions:
Computers & Internet Logo
24 people viewed this question
Ekse
Alun Cox
