Question about Canon PowerShot A710 IS Digital Camera
Prompted to set date
Every so often, when I turn on my camera, I am asked to set the date. It doesn't happen every time, but once in a while. I was once told it may be related to batteries not being fully charged.
Anyone else have an opinion on this?
Thank you,
Rob
  • Canon Master
  • 4,738 Answers
Check/replace the little CR1220 button battery for the clock. It sounds like yours is running down. It's compartment is located right next to where the AA batteries are inserted. It's a common battery, and you should be able to find one at Radio Shack, or even Walmart.
Posted on Mar 19, 2008
SOURCE:
Every time I turn on camera it ask to set date,
The Time/Date battery is a small round lithium battery the size of a dime in the battery compartment. You can get the numbers off it and buy one at Walmart or Ebay.
Instructions for replacing it:
http://www.manualslib.com/manual/275745/Canon-Powershot-Sx10-Is.html?page=267
Jun 06, 2014 | Canon PowerShot SX10 IS Digital Camera
My Camera keeps asking me for the date and time every time I turn it on How do i stop this?
Press the m button during shooting or playback to display the setup menu. The setup menu provides access to a variety of camera settings, including options not listed in the function menu, display options, and the time and date. Once you have the date and time set it should stop asking.
Aug 26, 2013 | DMCOM Olympus Vr-320 14 Mp Digital Camera...
How do I exit from time date on my Canon Power Shot A 510. It keeps defaulting to ask for time date and it won't save when I d0 put it in.
just pres ok to set it and it will get you out no matter if the date is set or not ...this is prompting you every time just for that cause ....you never pressed the button to save settings ..and it s keep asking every time ...The button will be the same u use for ok ..or the one you use for menu ..
Mar 01, 2010 | Cameras
Camera Canon A710 IS started to ask set time date when turned on
When the camera is left without power for an extended period of time, the time and date settings are gone. You need to reset them and when you're finished, click the set/ok button twice.
Feb 25, 2010 | Canon PowerShot A710 IS Digital Camera
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
CoolpixS51 camera stuck on set time and date
Not 100% sure about this model, but most have another battery in the camera for the clock functions. That battery could be low.
Try looking in the manual for the clock battery and pull that and replace it. See if that helps.
Jul 13, 2009 | Nikon COOLPIX S51 Digital Camera
When i turn on the camera, it always asks me to set time and date. If i click on yes, then i have to enter all the details as to the date, time, place. Also, the MP size defaults to 14MP instead of the...
Well, I have the same problem. Just introduce once the date and time. Turn off the camera. then turn the camera on using the button for presentation of pics (right arrow). You will see the last picture taken. Press again and you will be in shoot mode. The date and tame will be there. It is a bit fuzzy but works,
Feb 11, 2009 | Nikon COOLPIX S710 Digital Camera
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Date time setting does not program
There is not an option to remember the date/time when you power off the camera. The camera should always remember the time. If it forgets the setting when you power it off then your backup battery has gone dead. Check your manual to see if it is something you can replace yourself. I am not familiar with this camera specifically but some cameras make the backup battery accessible and some require disassembly. David Millier Advance Camera Repair
Feb 22, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Canon PowerShot A710 IS Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
