Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore coldspot - How do you remove the ice maker box to clean
I have a kenmore coldspot / model #77292798 - It has an ice maker in the freezer compartment. Lately water has been leaking into the refrigerator comparment. My friend told me there is a box located in the refrigerator compartment that needs to be removed and the gunk cleaned out. I can see the box in located towards the back wall but need to know how to remove it so that I can clean out all the gunk. My friend said that once I clean out the box, the water will stop leaking into the refrigerator comparment. Can you help me?
  • rayritzler Oct 05, 2008
    I have the same problem. last time i took it apart and removed all ice from the drain.It worked for a while,but it keeps doing it. my ice maker does not seem to work like it should (ice qubes are small, like not enough water to fill what ever it is it fills ). I have already changed the filter.
    Could there be something else going on besides a clogged drain hole.
    And aslo how would i know if my defroster is working. I'm thinking maybe it's letting to much ice build up in that area?
I have the exact same Kenmore and exact same model #77292798. It's the top freezer model with ice maker. Here's what I did:
Empty everything in the freezer.
Turn water to ice maker off from source behind unit.
Remove bottom panel (two screws)
Every screw in the freezer is the exact same size. I used a screwdriver style socket and, I think
this works the best.
Remove ice maker (4 screws) and unplug from socket.
Remove rear panel (2 screws).
My freezer was loaded with ice underneath the bottom panel. The ice scraped away easily. There is a tin pan underneath the coils that drains toward the middle where the drain hole is. Again, my freezer was full of ice beneath this tin pan and, I had to scrape away. You may be tempted to try and remove the coil because it would be easier to get to drain hole. I tried this and, it did no good. Don't try it. Once all the ice was scraped away, I realized that the drain hole was plugged with ice. I used boiling hot water and used a squeeze bottle to pour the hot water into the drain hole. I then wrapped a paper towel around a thin screwdriver and used that to soak up the now cold water in the drain hole. After doing this a dozen times or so, the drain finally cleared.
Then, reassemble. This was a much easier task than I thought it would be and, will take care of it much quicker next time.
Posted on Apr 17, 2009
  • 172 Answers
Hi Cincygrl,
Well lets see, I believe you have a whirlpool made kenmore, Your model numer should start with 106.
The problem you are having is from our drain. When you freezer defrosts the water should drain down a tube and under the refrigerator into a pan. If the tube gets clogged it will leak water into the freshfood section. To clear the drain you will need to remove everything from the freezer and remove the inside back panel in the freezer. in the center bottom under the coils and the heater you will see a tiny hole. That is your drain. If it is frozen over you will need to defrost the ice or you may need to run a smaller tube into it to clear it of an obstruction. I use a small rubber hose and I just insert it into the hole and blow on the other end. If you have something in it, it should blow out. If it does not then it may have ice in it and you can pour hot water into the drain and defrost it. Once clear you should not have any further problems. But they do make a drain heater probe to keep ice from forming inside the drain. You can get one for about $6.00. Good luck and I hope this helped you. mca0824@aol.com
Posted on Apr 30, 2008
Kenmore coldspot model 105-56532400 ice maker leaking water. How to fix?
The water supply solenoid valve may be malfunctioning or the fill tube to the icemaker may be mis-positioned.
Mar 01, 2015 | Kenmore Refrigerators
Water is leaking into teferagerator, seemingly from the freezer compartment. It is a Kenmore Coldspot model 106.72132101 type 21 TFA.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 01, 2011 | Kenmore 61282 / 61284 / 61289 Top Freezer...
I have a Kenmore Coldspot Model #78187891, with a leaky icemaker problem. The icemaker seems to leak near the front of the icemaker (closes to freezer door) and makes these stalactite structures. This...
Most likely ice maker is the problem and would need replacing. Water valve is letting to much water in but the amount of time solenoid stays open is controlled by the ice maker
Sep 28, 2017 | Kenmore Refrigerators
We have a Kenmore Coldspot Model 106 70102000 with the water and ice maker, it is now leaking inside the fridge itself and we have turned the water off to the ice maker and dispenser. What is causing the...
It is probably your defrost cycle causing this. Obviously if you shut the water line off then it is not coming from there so there is only 1 other place it could be. Every 8, 10, or 12 hours depending on you defrost timer the refrigerator will defrost itself.......the frost melts into water and drains into a pan under the fridge. If the drain is plugged then it will just run into the refrigerator. If you have a freezer on top model then just remove the back wall inside the freezer, it will be a few 1/4 inch screws....If you have an icemaker then remove that too, it will be held on with 3 screws. Just look behind that wall and you will probably see ice at the bottom.....defrost the ice and pour a cup or 2 of water into the drain to make sure it is unclogged. If it is still plugged up then you have to find the clog....either in the back of the fridge behind the lower cover or in the refrig compartment near the back of the roof.
Sep 11, 2009 | Kenmore Refrigerators
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Water leaks from the freezer area to the fridge
Check your drip pan and the nozzle of the line and see if it is dry. If it is dry you got a clog like I did.
I solved my own is the line from freezer to the drip pan was clogged with ice. Just remove the two back screws in the freezer section and melt the ice using hot water from the tap and maybe use a light pump could be a small foot pump nothing to powerful to put in the hole and pump until you see the water come through.
Aug 04, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water is leaking from freezer into lower compartment of kenmore
If you think it is the ice maker then shut down the water supply and see if the leak stops. Most likely though it is probably a blocked defrost drain.
Apr 09, 2009 | Refrigerators
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
3,293 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
