Question about Xerox Phaser 7300DN Laser Printer
XEROX 7300 Our prints are coming out dirty - textured looking - with a seemingly white 'film' on them. If any of you are familiar w/printing b&w photos in a dark room - it's equivelant to the fixer not properly drying.... leaving a white stain/residue. (let me know if this doesn't make sense. Suggestions on how to fix? Thanks, Chris
    President:
  • 2,072 Answers
Sounds like you have had a fuser roll failure.
Could be either the heat or pressure roll failure from your description.
That is an easy replacement. You can call 1-800-835-6100 and order one. It is on the left side of the machine, The area that is very hot. It has 2 thumb screws to remove and replace it. Only issue would be, the fuser has a replacement count on it that needs the proper laptop hooked up to it to reset the count. Although it will not fail to run without the count reset, once the fuser count reaches 100,000 images in the counter, it will shut the machine down until it is reset.
Posted on Mar 19, 2008
Printer producing dirty copies
it could be that the roller needs cleaning, how you do that, I don't know, but that's my guess. try printing blank white pages and see if they come out dirty
Nov 26, 2013 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Xerox 7300 print is pixilated
This depends on what you are trying to print and with what software. Most likely, you need to choose a higher print resolution in the software before sending to the printer, but more details would be required to give a precise response.
Aug 10, 2012 | Xerox Phaser 7300DN Laser Printer
Xerox wc 7300 printing very slow
most probably the size of the document you are sending to print? send in jpeg and it should process more quickly
May 24, 2010 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
The printing is ok on about 2 thirds of the sheet but each printed sheet has a black line about 2 " wide all the way down the sheet we have a xerox xc351 photo copier we have tried a new toner.
I'm not familiar with the Xerox, but it sounds like you've probably got a bad drim or drum blade, which, I think, comes as a whole PCU or photoconductor unit.There's other things such as fuser rollers, could be dirty laser, etc.
Jul 16, 2009 | Xerox Office Equipment & Supplies
Prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
check
cartridge motor running
and supplying toner proeprly
May 24, 2009 | Xerox DocuColor 12 Color Copier
Tektronix phaser 7300 uneven inking
sounds like a bad cyan developer housing. Or that somehow the housing has come out of its mounting, but I cant think how that would happen. There are some rails in the machine that may have also come loose.
You have to remove the IBT ( transfer) assembly to look into that.
Apr 07, 2008 | Xerox Phaser 7300DN Laser Printer
Printing on CD labels seem to ruin fuser in Phaser 7300
Probably the labels have a slight plastic fiber or coating in them and is getting a coating on the heat roller.
Here are part numbers of the correct CD labels you can run without a problem.
Xerox Matte Coated CD Labels, 6-Up, 11x17
Reorder 3R12373
75 sheets per box
spacer.gif Other items to consider: Return to Top spacer.gif Item Color Price/Unit Quantity Xerox Gloss Coated CD Labels, 6-Up, 11x17
Reorder 3R12372
75 sheets per box
Item Color Price/Unit Quantity Xerox CD-ROM Glossy Coated Labels, 4 x 7
Reorder 3R6322
50 CD-ROM Labels, 25 Sheets per carton
White - Glossy Coated 1-9 Box $17.44 10-49 Box $16.90 50-99 Box $15.65 100+ Box $14.89spacer.gif
Feb 22, 2008 | Xerox Phaser 7300DN Laser Printer
Specific PDF Document/Specific Print Area Black Toner Not Fusing And Flakes Off
Without a doubt you have a problem with the fuser.
What that is caused from is buildup over time of ink on the heat roller. The teflon coating wears some and the ink sticks to the aluminum instead of pealing off onto the paper.
You then do not get enough heat or perssure to "fuse" the image into the paper.
Replacine the fuser will correct the problem.
Feb 03, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
158 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
