Question about Xerox DocuColor 12 Color Copier
Xerox DocuColor problem
Has stapling "error" - however, it is not allowing me to print - it has shut down the machine. I don't want to staple so is there any way to override the error in order to print?
I have a DocuColor 240 - not listed but hope you can help anyway
Thank you!
    President:
  • 2,072 Answers
The only thing I can tell you to do is turn off the machine. On the back of the finisher, unplug the finisher from the processor and power up the machine, it will reconfigure, plug and play like, and send the pages to the center tray.
Once you do that. Go into machine status and into faults. Print out a fault page and tell me the finisher/stapler code coming up so I can let you know exactly whats going on.
I hate that software puts a machine down for functions you do not 100 percent need.
Posted on Mar 19, 2008
  • Rick Kasper Mar 19, 2008
    Oh shoot. I gave you the DOC 40 information. Not 240, Sorry,
    You can still disconnect the finisher and move it away from the machine.
    on the xerox.com site you have to enter DC240 in the support search.
    You will need a service call on the 240. Sorry, my mind clicked in on a DC40 when I read the problem.
Xerox docucolor 252
http://www.support.xerox.com/support/docucolor-242-252-260/support/enus.html?associatedProduct=dc242-252-260-built-in-controller
Replace any new toner you put in the machine and shut it down for 2 min then power back on. If that doesn't fix it you will have to call Xerox service to replace a sensor that may be broken.
Jan 03, 2014 | Xerox Office Equipment & Supplies
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
Xerox docucolor 240-250 not stapling/folding, error codes 012-243, 012-229, 012-225
Koday Hero 7.1 carriage jam. Stuck to the left side. No paper jam can be found but can't get the carriage to move.
Nov 15, 2013 | Office Equipment & Supplies
Xerox Staple cartridge stuck
If the cartridge is stuck in the slide it is because there are still staples in the replaceable sleeve, if the whole slide is stuck in the finisher, you might open the panel over the staple unit and see if you have staples stuck that are causing you to not be able to remove the cartridge.
Oct 25, 2012 | Xerox 4110 4127 4112 4590 4595 Drum...
Cant print Xerox Docucolor 240 with Creo CX250
its the problem of connecting cable.and other error 212 is for internal circuit board error.you will have to contact xerox service center and get the resetter for this online.or if its board problem you will have to order the parts.
http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-240-250/sprt-enus.html
click the link directly and check out your areas service center or the nearest to your area.
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Jul 19, 2009 | Xerox Office Equipment & Supplies
Load staples in xerox 430st
I will assume you are talking about the stapler on the finisher. That is a little tricky, but you will see a button on top of the finisher, you have to hold it down for a few seconds and the trays will lower. There is then a small door that opens and the staple cartridge is in there. You can either hold the button down again to raise the bins or turn the machine on and off.
Jan 22, 2009 | Xerox CopyCentre C123 Copier
Docu color 252 fault code 012-324 ???? Bill
HERE is the manual for your unit.
HERE is the online support page.
THESE are all the available documents for your Copier
Your error code 012-324 is not listed in any documentation.
Is there something it is doing/not doing when this error comes up?
Their customer service will help you with the error code.
Please call 1-890-925-050 and have your 10 digit serial # available.
Thank you for Using FixYa!
Jan 20, 2009 | Xerox DocuColor 12 Color Copier
When the machine dont start fault error 102-353
Solution: Remove the Paper Jam in the Duplex Automatic Document Feeder (DADF) Top Left Cover bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif
  1. Lift up the handle on the Left Cover of the DADF until the cover comes to a stop.
    NOTE: An inside cover will also raise with the Left Cover as the two covers are interlocked.
  2. Gently open the covers.
  3. Remove any paper that may be jammed. Check for obstructions in the DADF area including jammed originals, paper fragments, paper clips or staples.
  4. Check for obstructions in the DADF paper sensor area, small paper fragments, paper clips or staples may get caught there.
  5. Clean the DADF rollers with a damp cloth.
  6. Close the Left Cover on the DADF until you hear it click into place.
  7. Raise the DADF, remove all the originals, and then lower the DADF.
  8. Make sure your originals are not torn, wrinkled, or folded. Load your originals again following the instructions on the Touch Screen.
    NOTE: Originals that have already been scanned will automatically be skipped, and scanning will resume from the previous document sheet.
  9. Torn, wrinkled, or folded originals may cause paper jams and damage. Place the originals directly on the Document Glass to make new originals that can be scanned using the DADF.
Dec 29, 2008 | Xerox DocuColor 1632 Laser Printer
Xerox DocuColor 12 Color Copier Logo
284 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
