Question about Connex 3300 240-Channels Base CB Radio
Dosy meter i have a dosy pm2000 watt meter how do you read the peak and dead key watts
  • 126 Answers
To read peak and dead key, use one length of coax between the radio and the input side of the input connector, and another length between the antenna connector and either a cb antenna or a dummy load. Then put the far right knob on either the 20, 200, or 2000 watt setting, which you will read on its corresponding scale on the meter. When you just push the ptt switch on your cb mic without talking, that will be your dead key. When you talk into the mic, most people repeat the some of the following "audio", "audio 1", "audio 1, 2, 3" etc. (kind of like a dj saying "testing") different ways, or you can put your mic up to the radios speaker and use the high pitch squeal for the same effect to read PEP or peak-envelope-power.
If you do not have a manual and would like one, here is one in pdf format that covers the PM1000 and PM2001 models:
http://www.dosy.com/pdf/pm1000.pdf
If you require more assistance, such as checking modulation or swr properly, feel free to reply here or to my email at:
rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Mount Vernon, TX
Posted on May 22, 2008
Is it good for a Galaxy 29HD peaked & tuned to dead key 3 watts and swing almost all the way to the right? I run a 4ft.Firestick antenna.
Stock radios dead key 1-2 watts and swing 4 watts max per FCC regulations. The swing is when you speak or whistle into the microphone. All the way to the right does not tell me watts or type of meter, so I cannot say. Typically to the right does mean more power out. Looks very good at 3 watts. For most people I suggest a longer antenna. Length = range, especially for CB's.
Oct 02, 2017 | Galaxy Radio Communications
Got a cobra 29 ltd classic dead keys 10 watts and swings back to 6 watts on an external meter any answers
Hi you have to make sure your antenna has 1:1 SWR reading improper use of antennas deplete the Effective radiating Power of Transmitting equipment such as the CB radio.
Mar 15, 2016 | Cobra Radio Communications
3300hp how many watts output, what swr/ power meter should be used
That style will get about 60w PEAK.. on older styles.. the newer Mosfets will do about 30-40ish..
Meters, are preference.. most are just RMS styles. and you wont see the Peak reading which is fine. there are alot of meters and brands.. Bird, Dosy, MFJ, Siltronix. they all have pros / cons.
if just want simple workman makes some lower end styles. also para dynamics..
there are some MFJ and other brands that have cross needles that show both power and swr at same time. but they will start in the $60ish range and go up from there.
Oct 24, 2013 | Connex 3300 240-Channels Base CB Radio
My 25LTD CB has been tuned and peaked. I just replaced the meter and it spikes hard when keyed. How can I adjust it without degrading the tune?
It could be the variable resistor that sets the meter movement or it could be the person that tuuned and peaked it didn't know what they were doing and set a high dead key. The radio should key low and then swing high. You must first track down which one is the problem. You will need a good watt meter for that. If it isn't a problem with too high a dead key then go to CBtricks and look up your model of radio and find the "VR" variable resistor that sets the meter. Open up the radio and turn the resistor to match the meter scale with what the watt meter reads.
Sep 16, 2012 | Cobra 25 LTD 40-Channels Base CB Radio
Galaxy saturn tubro 100 watt power is sticking after key up.
Not sure what you mean completely. If you mean, when you key up, it keys at 100 watts and stays, then this is probably not a problem.
If it doesn't swing, it is either the watt meter you are using, or you have the power up too high, or both.
I usually key my saturn turbo around 80 watts. You have to be careful with these radios. they get hot fast and when they do, they get whacky. Make sure you have a PC fan plowing on the heat sink on the back.
The higher the dead key, the less swing you will see.
Now as for the watt meter....
There are a few types of meters out there. The 2 most common are ones that read AVG, or average watts, or PEP or Peak envelope power, which in short terms is your Peak wattage. Some meters do both.
An AVG meter will not read peak wattage, or swing. So if you meter is an AVG meter, or is set to AVG, then it will not read swing, and will show you your dead key, and that's it. Some times the needle will move a little, but it is not showing your true swing.
All in all a PEP meter is a loose representation any way, because you really cannot get an accurate reading when there is modulation. But it's close enough. You would need a spectrum analyzer to really see what you are putting out with modulation. AVG with no modulation is a more accurate reading however you cannot see swing.
Now PEP while transmitting in SSB with modulation, would be accurate. Just not AM, but like I said, its close enough and is what every one goes by.
I don't know if your Saturn turbo has been modded or peaked and tuned but, you should see a max of about 170 to 200 watts swing on that radio if its been done right. But you will need a PEP reading meter to see that.
I wouldn't run it past 80 watt dead key for long. With that radio you should really only run what you need. For instance, when I am using mine, I start at around 70--80 watts, and do a check, and if it's not strong enough I bring it up a little, until the audio sounds good to who I am talking too.
Like I said, you have to keep it from getting too hot.
Nov 04, 2010 | Radio Communications
I have a cobra 200 gtl dx and some one make modification on it to get more power and more modulation but i see in my books the modification to raise up on the board in front of my cb tell me to raise up...
you do not do it by resistance. To turn up the radio it is a variable resistor. What you do is connect a watt meter that can read PEAK or PEP watts AND AVERAGE or dead key watts.
First you check it on avg watts. Hook the radio up in line with the watt meter and set it on avg watts. key the radio. Stock is 4 watts. A lot of times when you peak a radio, you lower the dead key.(thats keying with no audio.) This allows you to get more modulation wattage, or swing wattage. If that has been done it will probably do 2 or 3 watts. If it has had the AM power raised in it, it could be more, this is no good. You want your dead key a bit lower.
Now check it on peak. Flip the meter to peak and make an AHHHHHHHHHHHHHHH noise into the radio. It should swing to anywhere between 15 and 20 watts.
You adjust the AMC while giving it audio and watching the meter on peak to adjust the modulation. 4 watts is legal modulation.
Feb 07, 2010 | Cobra 200 GTL DX 4-Channels Base CB Radio
Can i wire direct to battery to get more power instead of the fuse panel.Plus i have a comet 200 hooked up and only getting 125 watts whats the prob
comet 200? its a 2 pill. 125 watts seems right. The amp should be run straight to the battery always. you can run the radio, but that will not get you more power although it will help with engine noise in your radio. You could be starving the amp if its not run to the battery, but you won't see much more wattage.
Also your dead key will effect your power output. Should have some where around a 2 watt dead key.
This leads me to my next point.
What kind of meter are you using? if its a cheapo pyramid or workman, it may only read average watts. and it will only show you your dead key. It will not show you audio swing. you need a meter that can read peak watts to see your true swing.
you may be doing more then you see on your meter.
Jan 05, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 29 classic "swing kit" ?
A swing kit is nothing more then a Cap and a resistor. There really isn't a different way to do a swing kit, unless you do variable power, which you don't need unless you are going to run a linear, and even then you can just set the dead key with a swing kit.
you need a watt meter, preferably one that reads peak and average watts. If not, average will be find.
Open the bottom cover of the radio. Hook the radio up to the watt meter, use a dummy load or have it hooked to the antenna. Never key the radio with an antenna or a dummy load.
Find VR4. Its toward the back right of the radio. Turn it all the way to the left. That increases your modulation.
Next find L14. it is at the back in front of the final resistor. While making a steady sound into the radio, just make an ahhhhhhh noise. Back the slug out of the tank until the needle hits peak. Don't move it out any more or you will over bias the final.
Now you will need a 220 uf electrolytic cap, and a 100 ohm 1/2 watt resistor, both of which you can get from radio shack. (this is your swing kit.
To the right of the tank slug is a jumper maked JP36. Us soldering wick to remove the solder and pull out the jumper. Now put the cap in it with the stripe facing the back of the radio.(that is very important. the other way you will blow the radio.) Solder it in place and cut the extra leads off. Now on the back of the board were you soldered in the cap, solder the 100 ohm resistor in between the 2 points.
The amount of resistance determines you dead key. you will be at about a 2 watt dead key which is good for swing and if you want to run a linear. The higher the resistor the lower the dead key, and the lower the cap, the higher the dead key.
That is your basic peak and tune with a swing kit.
Dec 23, 2009 | Cobra 29 LTD CB Radio
Tunring up a cobra 150 gtl/dx
Um... What?? This is hooked to a switch? CB radio by FCC regulations is only supposed to have a max of 4 watts total output. If you can flip it to 7 watts dead key, you are doing really good. It won't do much more then that. It sounds like its set up to run on a linear amplifier, which cannot have more then 3 watts dead key transmitting into it.
Dead key, and modulation are different. You may have a meter that only reads dead key, and won't see the modulation. This radio is probably swinging close to 15-20 watts. you need a meter that can read PEP, Peak envelope power. Cheap meters only read AVG, or average power, witch will only show your dead key.
7 watts dead key is really good for that radio.especially since stock only has 4 watts. you cannot get any higher then that without changing finals.
at 3 watt dead key, or 7 watt dead key, your modulation wattage is still swinging much higher.
Also, you will get more swing with a lower dead key any way, which is better if you want it to be loud.
Leave it alone. its probably set just right.
May 12, 2009 | Cobra 150 GTL DX Base CB Radio
Low output power
On the meter you are using, does it mesure Average power or peak envelope power?
This is very important to know when you are measuring.
AVG measures basically your dead key. It usually will very little if at all.
PEP measures your peak output, or swing. Modulation.
So even if you have a radio that has been peaked, on a meter that reads AVG, it will still read around 3 to 4 watts. And, if it has a swing kit in it, it will read even less. A swing kit lowers the dead key it increase modulation. Higher PEP.
For example. I peaked my cobra 29 and it does some where around 22 -25 watts PEP. I have variable power in it as well, but usually run the dead key at 2 watts because I have a linear. The Radio alone, when mesureing on PEP with key up at 2 watts, and then when you talk, swings to about 22 -25 watts.
If I flip the meter to AVG, it stays at 2 watts even with talking.
If you have one of those cheap pyramid meters, etc, they usually only read AVG.
Get a meter from radioshack. They have a fairly decent radio for the money. It reads both PEP and AVG and has SWR as well.
If the radio has been peaked and it has a swing mod, it will most likely be swinging to some where in the 20 watt range.
On a side note. According to FCC regulations, a CB radio is only allowed to transmit with 4 watts of final power. Most times the manufacturer will have it a hair under so that they are leagal.
Basically it is illegal to use a CB that puts out more then 4 Watts.
But its a free for all these days. There is no more funding to the FCC for monitoring CB radio, so they do not want anything to do with it. As long as you don't over do it, have over 50000 watts and terrorize a small community with RF, you can do what you want.
Now a days most cb radio's bought have already been peaked if you got it from a cb shop, or off a website that does it.
Apr 21, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
390 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Steve
Steve
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
