Router security I currently don't have any password setup for my wireless internet, would like to use the serial # off of my router for a wep key... How do I set this up? (D1-614 -- D-Link)
  • 807 Answers
Read the router manual about securing your connection.
Posted on Mar 19, 2008
WAP/WEP password not working
These are the two options for your Router. Don't forget to save your settings
WPA is an upgrade to the WEP (Wired Equivalent Privacy) standard for securing your wireless network. If you would like to secure your wireless network using WPA, you will need the following:
  • WPA enabled on your Dell TrueMobile 2300 Wireless Broadband Router
  • WPA support for your wireless clients. If you are using a Dell TrueMobile wireless client, you can check for the availability of WPA enabled software update for your wireless client at http://support.dell.com.
  1. Log into the Web configuration of your router at http://my.router (or the default address http://192.168.2.1)
  2. Click on Basic Settings.
  3. Click on Wireless Security.
  4. Click on the Enable Wireless Security checkbox.
  5. Select either WEP or WPA in the Network Authentication list.
To setup WPA
  1. Enter your pre-shared key. This key must match the key that is used by each wireless client computer associated to your router.
  2. Choose a key format. This can be hexadecimal digits (0-9, A-F) or ASCII characters (any key on the keyboard).
  3. WPA Group Rekey Interval specifies how often the key rotates or changes.
  4. WPA Encryption allows you to select 1 of 2 possible encryption methods (TKIP and AES) - choose one that your wireless clients supports.
  5. Click NEXT, then Save and Restart to apply the changes.
  6. Setup the WPA on your wireless clients. Refer to the documentation that accompanied your wireless clients, or your wireless clients on-line help system for information on how to setup WPA.
May 14, 2012 | Dell TrueMobile 2300 Wireless Broadband...
Tip
Where can I find the WEP key on my router? Router security key, router password
If you have a wireless router at home you will need to have a WEP key setup on your router. WEP stands for "Wired Equivalent Privacy" and WEP is a security protocol used to secure wireless networks. When you setup a router for wireless, you normally specify a key(password) so anyone that wishes to join your network has to enter the key. You normally set the WEP key during the router setup phase. You may have set it up and forgot it, or want to reset it. In this article I will go over the steps to find out the WEP key or change it. Your router may use a different security protocol than WEP so don't worry, you still need a KEY in order to access the network.
-On most routers(reference your user manual) you can access the router configuration page by going to the gateway address. The gateway address is the IP address assigned to your router. In a lot of the cases, this address is 192.168.1.1 but depends on your router.
There are a couple of ways to find out this IP address.
-Reference your router manual
-In Microsoft Windows, go to Start > Run and in the run box type "cmd" or "command". A black DOS windows should open. In this window, type "ipconfig /all". Look near the top and you should see a "gateway address" item. This number is the ip address of your router.
Once you know your gateway address, open up your internet browser as if you were going to go to a website. In the URL(address) bar, type the gateway address and hit enter(see image below). A log in box should now show. Again, reference your router manual if you do not know the administrative password. Enter in your password and username.
Once you log in you now have access to the router settings and you can configure what you please. What we are looking for in this article is the wireless security settings. In the wireless security settings page you should be able to see the password for your wireless network and change it. If you see no password go ahead and set one up.
**You can also look around and modify other settings. You can change the wireless security, give your wireless network a name(SSID field) and even with some routers have built in testing features to test the connection at home.
I would recommend that if your router has a default password for admin/configuration access, that you go ahead and create a new one. The default router passwords are usually very simple and this information can be easily found on the internet by anyone. People who set up home networks tend to leave this as is and it is a security risk.
TIPS
-If you can't connect to the router and you know the gateway address, try plugging the computer into the router directly using a Ethernet cable(LAN/patch cable). If you are still having trouble, you can perform a power cycle. Turn off your modem, router and computer. After 10 seconds turn on your modem, after 30 seconds turn on your router and after another 30 seconds turn on your computer. Try to access the router now. This also helps resolve other quirky router issues.
-Make sure all the network cables, phone lines(if using DSL) and coaxial cables(cable/Broadband) are plugged in and secured firmly.
-If you set up a password and username for your routers administrative access and can't remember it, you can reset the username and password back to factory default by performing a factory reset. On most routers this can be achieved by pressing and holding the small reset button on the back of the router for 15 seconds. Please reference router user manual for more information.
I hope this article was informative. Thanks for reading.
Regards,
G33k
Keywords
Where can I find the WEP key on my router?, How to reset router WEP key, lost router security key, where can I find router password, how to reset router password, where to find router security key, how to configure router security, how to configure router password, how to configure router WEP key, lost WEP key, reset WEP key, can't find my pass key, lost router pass key, lost router wireless pass key, how to reset router passkey, how to obtain router passkey
on Jun 01, 2011 | Computers & Internet
Hello, What do I have to do so that not everyonecan use the WLAN, but has to login first.
You have to setup password protection for the router.
To do this, open up your internet browser and type into the navigation bar 192.168.1.254 and hit enter.
If presented with a user authentication (login) screen, try the following:
Default Username - Hawking Wireless Router: admin (lowercase)
Default Password - Hawking Wireless Router : none (none, leave blank)
To add password protection you will have to activate WEP (a standard encryption protocol used in most routers to protect from unauthorised access).
To access the WEP information, run the Setup Wizard and then go to the Wireless region. Hint: While troubleshooting, try a 64-bit (instead of using a 128 bit WEP key or WPA) WEP key first. To avoid WEP Key mismatch (typing errors, etc.), use a simple/short (i.e. a 10 digit Hex Key such as 0123456789, 5555555555, 6666666666, etc.) WEP Key.
Write down your WEP Key so that you don't forget it.
May 04, 2011 | Hawking H-WR258 Wireless Router
I'm currently trying to set up a wireless connection with my laptop and says limited or no connectivity and requires a network key
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the Left under wireless Click Security
Step 4 : If it asking for a password leave that blank and click submit
Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK ")
Step 6 : IF the security mode is WEP then the key 1 will be your password
Regards
TOM
Jan 16, 2011 | Belkin (F5D7230-4) Router (587009)
How do i find my WEP key?
Regards
TOM
Dec 25, 2010 | Belkin Basic Wireless Router
I want to add a computer to my wireless secured network but i have forgotten the wep security key i wanted to know if you could give me the key if i give you the serial number of the router please.
Step 5 : On this Page you can find the WPA/WEP Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK ") if it is WEP Then the key 1 will be your password
Dec 21, 2010 | Belkin (F5D7230-4) Router (587009)
Lost my wep key
Connect Router - Computer ( Wired ) <br /><br />Open Router Setup by typing http://192.168.2.1/ on the address bar of the internet explorer <br /><br />On this Page On the left under wireless click security <br /><br />leave the password blank and click submit <br /><br />You can find your WEP Key here ( the key 1 will be your wep key ) <br /><br />
Aug 22, 2010 | Belkin (F5D7633UK4A) Wireless Router
I have a D-Link DIR 615 wireless router i am trying to connect my daughters DS to the wifi but it keeps asking me for a WEP KEY???? i dont know the wep key i put the serial number in and the password but...
WEP KEY
WPA KEY
When you will make WEP key then you have to put this key on your pc first for connect to internet. It is very easy steps & your network will make secure.
First check your network option also.
Right click on your network then you see the property then go to security See dropdown menu If you have wep key then follow these steps if you did not see thi.
WPA is same as WEP
(WEP)
You need to sign in your router first.
1.open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1)
http://192.168.0.1/
2. Select "Admin" from the drop-down menu and then enter your password. Leave the password blank by default.
Now you can see your D-LINK webpage where you find your wep key.
Clik setup then wireless setting
Now you see on this page
1. Wireless Security mode then drop-down-menu Set Enable WEP
2. Authentication - Choose Shared Key.
3. WEP Encryption - 64 Bit.
4. Key Type - HEX
5. Default WEP Key - WEP Key 1
6. Now Make a key( You can choose any password but remember only 10 charcters allowed)
7. Now Save setting. then your router gonna boot up make sure let it boot. It connected after 5 minute.
You should write your password in paper first then you will have to add this key into your pc. network.
You can not connect internet because you have to put these Key(password) into your pc first.
Go to your network connection in your pc Choose your network
Or
You see two computer( internet icon) on the desktop
Right click then connect to network then you see so many network & your network ( Which you create).
Right click on your network then you see the property then go to security choose wep key then put the password(KEY).
WPA
1. Wireless Security mode then drop-down-menu - EnableWPA
2. Clipher type -TKIP
3. Passpharse - create own password here( don't put any personal info there)
Save setting
Device restart.
Now check Network status. Its working now.
Follow youtube video
Jun 10, 2010 | Computers & Internet
Securing my wifi network
Hi George,
Simply open your Internet browser, in the address line, inset 192.168.0.1, then:
-> Goto TOOLS
Here you set the administrator password, note that you have to set the same password twice.
Do set some security as well, other vice your neighbor will use your network, - and that you don’t want, as you don’t know what and where he go on the internet.
On page 27 in your manual, you find the way to set the wireless settings.
On page 37 in your manual, you find a way to set MAC address settings. Thise settings allow only those MAC addresses as you put in the table.
You find your own MAC address like this:
->Start->run->write cmd and hit enter; a black DOS window open, write ipconfig /all (note the space before /all). Here you find your MAC address – note that there is two cards in your laptop, and the card you want the MAC address for is the wireless card.
regards
Teis
plz let me know if you need furter help.
Jan 17, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
Need web key
Victoria,
You can find your WEP Key in the router setup page.
You can try these steps to check the network key.
1. Use a computer that is directly connected to the router with a cable. then Open your Internet Explorer, Type http://192.168.1.1 then it will ask you for a username and password by default you leave the username blank and type admin for the password, if you have your own password put it in the password feild rather than using admin.
2. Once you are in the setup page of the router, click the Tab at the top that says Wireless, then in the tab Wireless, Under the tab Wireless Click the sub tab that says Wireless Security, If the security mode is set to WEP, check the Defaul TX Key, If its set to 1, the network key 1 at the bottom of the page is the WEP Key that you need.
Just reply to this post if you have any other problems.
Jun 28, 2008 | Linksys Wireless-G Broadband Router
Open Questions:
Computers & Internet Logo
Alun Cox
David Payne
David Payne
