Question about Video Game Consoles & Games
Wii Remote is not responding. All four lights flashing. normal was only one light. Have pressed re-sinc button, but still no response. Have purchased a new remote, but same problem occurs. A quick response from you would be greatly appreciated. Thanking you Rylee Pryor
    Problem Solver:
  • 6 Answers
We asked some people and u had 2 press some button lolxt
Posted on Mar 18, 2008
I can't sinc my remotes to my wii
Try unplugging the Wii then plugging it in and press the red button on the wii then press the red button on the remote until lights flash then press the red button on the wii...hope it helps
Aug 31, 2013 | Nintendo Wii Remote Controller
Cant get pass the "press A button" screen
Turn off for a moment, try again, reconnect your controller.
Since its brand new, you can get it replaced if that doesn't work, dont waste your energy on it, just get another one, free replacement / warraty. Im sure.
Sep 05, 2008 | Nintendo Wii Console
All four reote lights blink but the ghame doesnt respond
You must sync the remote. To do this first take off Battery cover of remote.(leave batteries in) Then press the tiny red button on the front of the wii console next to the sd card slot for 2 seconds. Look at the back of the remote. In the battery compartment there is a tiny red button that looks like the one one the wii. Press it and they should sync. Now your remote should work.
Please rate.
Dec 31, 2010 | Nintendo Wii Console
When I turn on WII it says ''press A to continue''ut nothing happens. I have changed the batteries in the remotes but they do not respond. I have checked the sensor is plugged in.
If you have more than one remote, you may have to "sync" the remotes to your Wii system.
1. Open the battery cover on your remote and press the red "SYNC" button. The lights on the remote should begin flashing.
2. Open the cover on SD Card slot on the console and press the "SYNC" button.
3. The lights on the remote should stop flashing after a few seconds. Your remote is now ready for use.
This process must be repeated for each new remote.
Feb 09, 2010 | Nintendo Wii Console
If you have multiple wii remotes, make sure the remote you are using is synced to your system. In case you are not sure how to do this:
1. Open the battery cover on the remote and press the red "SYNC" button. The lights on the remote should begin flashing.
2. Open the SD slot on the Wii system and press the "SYNC" button.
3. Once the lights on the remote stop flashing, the process is complete and you should be able to use your remote.
Remember, you have to go through this process with each new remote in order for it to work.
Feb 09, 2010 | Video Game Consoles & Games
Wii remotes are not responding to anything. batteries have been changed and lights are flashing but
You need to synchronize them to your Wii. First turn on your Wii. Open the battery compartment on the back of your Wii-mote and the front SD Card door on the front of your Wii. There is a little round red SYNC button on the back of your Wii-mote and a red SYNC button on your Wii in that door. Press the button on the remote and then on the Wii and it should sync. If it doesn't work at first try again. You know it is synched when one of the four LED lights at the bottom of the Wii-mote is solid.
Dec 26, 2009 | Nintendo Wii Console
The ON button on the Wii remote doesn't respond. Tried new batteries but still no response. No blue lights, nothing! Tried patting it, reset button, all instructions as listed in troubleshooting. Had since...
Try reseting the wii console. This is done by removing the battery from the botton of the console. There is a small battery bay held in by 1 screw. Leave it out for a day and after you install it make sure you press the conect button on the wii. (located under SD card reader door). And the connect button on the controller (located in battery compartment on back of controller). Good Luck.
Nov 24, 2009 | Nintendo Wii Console
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Jul 30, 2009 | Nintendo Video Game Consoles & Games
Wii remote will not follow command.
It's problem a radio interference, since the wii controller uses radio frequences to contact the device, try to resync the wii controller.
1. Turn the Wii console on and wait until the "Health & Safety" screen appears (don't press A).
2. Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.
3. Resync the Wii Remote by removing the battery cover and pressing the red "SYNC" button. Do this for all Wii Remotes you wish to use, and test for proper response.
4. If the steps above do not work, remove the batteries of the Wii Remote and leave them out for at least 2 or 3 minutes. Reinsert the batteries and sync the Wii Remote again. Test for proper response.
If after removing the batteries for several minutes, and resyncing the Wii Remote, your still unable to get the Wii Remotes to work, try syncing another Wii Remote if available.
* If another Wii Remote works, then your previous Wii Remote will need to be repaired.
Feb 09, 2009 | Nintendo Wii Console
Wii remote
Hi Nixo, probably needs re-syncing, press the sync button on the Wii console and the button on the wiimote (under the battery cover), do it pretty much at the same time, the wiimote usually vibrates and one light wll show up.
Hope this helps
LesPix
Feb 28, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
42 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
