Question about Bissell 8910 ProHeat Clear View Upright Vacuum
No water/soap to carpet, but upholstery attachment works fine.
I am having an issue with my Bissell not putting water/soap to the floor, yet the handheld attachment works fine. I called a local repair place and they said it was the pump, and they would be happy to replace it for $140 and 3 weeks.
I can buy a pump online for far less, but I question that the pump is the issue here. Why would I get mixture out of the handheld but not to the floor? I have completely cleaned everything and I can find nothing that visually looks awry.
  • 126 Answers
If the hose is spraying, then the pump is working. The pump is a common problem which is why the repair shop assumes that it is the problem, but their repair cost is way out of line. The more likely cause could be the heater. The heaters on these machines have been problematic in the past. The heater is heating water and soap and quite often they will plug up and then the water will not flow. The heater is used for the floor spray but not the hose. It is also possible that the floor spray jets are plugged or that the indicator dial is fowled with something and will not allow solution to flow. I would suggest finding a different shop to take it to and make sure they find the trouble before repairing and give you a more resonable estimate. This should fall somewhere in the $60.00 repair range.
Posted on Mar 21, 2008
SOURCE:
Water not pumping out
It could Be one or more of a few problems. It may have soap clogging the pump or heater (if your model has a heater) or the belt turning the pump may be stretched or broken. I start by making sure water is coming from the tank. Make sure the belts are good. Make sure the pump is working. If water comes from the upholstery tool. But not at the floor it may indicate the heater Has a clog or restriction. Make sure there is not anything clogging the spray jets.
Mar 14, 2014 | Bissell Vacuums
I have a bissell pro heat carpet cleaner. It is model 25a3 and about 1 year old. no water comes out when I press the trigger to clean the floor. The tools attachment works fine, any ideas?
If you are getting water from the tool. But not at the floor the most likely problem is the heater is clogged with coagulated soap or minerals. You will need to separate the upper handle to get to the heater. Insure the machine is unplugged. Remove the cover from the heater making sure you don't lose the little gaskets on each screw. Clean the channels inside the heater and put the cover back on. Be aware of how you are Taking it apart so you will know how to reassemble it.
Oct 31, 2013 | Bissell 25A3 Proheat Upright Deep Heated...
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
Bissell spray to floor not operating. Spray to upholstery fine.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
urr
Jan 01, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell carpet cleaner not spraying water out of bladder
my bissell machine was bought 2nd hand and I can see where to put the water in...too complicated...anyone have the bissell proheat pro-tech with scotchgard i believe the model # is 010-5458
May 08, 2008 | Vacuums
Bissell power shoot carpet cleaner
It sounds like the heater may be plugged. This is a problem for an experienced technician. The heater is located in the handle and they are prone to plugging at the tubing connections. The heater is heating soap and water solution and this can cause the soap to coagulate and plug the lines. It must be addressed carefully to avoid damaging the heater.
Mar 23, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
282 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Marvin
Marvin
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
