Question about Sony Cyber-shot DSC-H7 Digital Camera
Cybershot H7 focus problem
My H7 won't auto focus when zooming, when the shutter button is depressed halfway the camera should auto focus but does nothing except flash the vibration warning symbol. The resulting picture is completely blurred.
    Champion:
  • 203 Answers
Things to check before you assume it is a mechanical issue-you can get vibration message if flash is disabled, be sure also that the macro mode is not enabled-this is very common on sony cameras to turn on by accident-flower button on camera will put in close up mode and you will get blur make sure no flower is present on lcd screen-if in macro press button on camera w/flower to turn off-also in menu you have continuous and monitor auto focus settings try changing one or the other and see what happens
Posted on May 09, 2008
Shots are blurry
This issue can occur in the following circumstances:
The subject is too close to the camera lens Insufficient lighting Subject movement Camera movement Incorrect camera settings Incorrect camera operation Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus. Make sure there is enough lighting to allow the camera to focus on the subject. Make sure the camera settings are set appropriately. When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position. If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting. If your camera has a SteadyShot/anti-blur function, ensure it is enabled. Aim the camera at the subject. Press the shutter button halfway down. NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture. Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Jan 01, 2011 | Cameras
I have a brand new nikon coolpix s3000. it's on full-time auto focus. Any ideas?
You can change this in the menu while in shooting mode. This is from page 48 of the manual:
Choose how the camera focuses.
A (auto) M d (Shooting menu) M I Autofocus mode
A Single AF (default setting)
The camera focuses when the shutter-release button is pressed halfway.
B Full-time AF
The camera focuses continuously until the shutter-release button is pressed down
halfway. Use with moving subjects. The sound of lens drive movement will be heard
while the camera focuses.
Sep 28, 2010 | Nikon Coolpix S3000 Digital Camera
How to get manual focus on Olympus Camedia C-750 ultra zoom digital camera
TTTTTTTTTTTTTTTTTTTTTTTTITf correct focus cannot be obtained
When the subject to be focused is not on the AF target mark (not positioned
in the center of the composition), you can use the following steps to obtain the
correct focus on the subject. This operation is referred to as "focus lock".
Determine the position of the subject after focusing (Focus Lock)
1 Press the power switch.
• The camera turns on in the shooting
mode.
• The lens extends and the monitor turns
on.
• The orange lamp lights.
2 Turn the mode dial and select a
shooting mode.
"Shooting mode" (P.36)
3 Position the AF target mark on
the subject you want to focus on.
• When shooting a hard-to-focus
subject, point the camera at an object
about the same distance away as the
subject.
until the green lamp lights.
• When the green lamp lights steadily,
the focus and the exposure are locked.
• When the green lamp blinks, the focus
and exposure are not locked. Release
your finger from the shutter button, reposition
your subject and press the
shutter button halfway again.
5 Keeping the shutter button
pressed halfway, recompose
your shot.
6 Press the shutter button fully.
Try the above, info from D-535, C-370 and X-450.
I can email you the complete manual if this works.
Regards
Phillip
Sep 12, 2009 | Cameras
Shutter button will not work
First see that autofocus is swiched on ( side of the camera ) camera will not auto focus if body set to manual focus. Otherwise check lens which may be faulty( use another lens to check ). If you are still getting no joy camera should go in but this sort of problem is not expensive to repair.
Sep 02, 2007 | Pentax K100D Digital Camera
Fuji FinePix F40fd aoto focus
Camera fault sounds like make sure the A/F sensor window is not obscured Fuji Tech Support will know more.
Jul 12, 2007 | Fuji FinePix F40fd Digital Camera
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Cannot focus on a particular subject
If the camera is having a difficult time auto-focusing, you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance from you and then move the camera back to the intended subject and take the picture without losing focus. First, turn the camera on and locate the Autofocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away as the subject the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While holding the shutter button halfway down, aim the camera at the original subject and press the shutter button all the way down.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Focus on a particular subject
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamplights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Focus on a particular subject?
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 42 in the D-535 Zoom Reference Manual in Section 3, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation.)
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Why doesn't the shutter button on my EasyShare digital camera work?
The cause and solution may include one of the following: The camera is not turned on. Turn on the camera. The camera is processing a picture; the camera Power ring light (on the Mode dial) blinks green. Wait until the light stops blinking before taking another picture. The card or internal memory is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The shutter button was not pressed. Depress the shutter button completely down. There was a failure in the focus and/or exposure. Press the shutter button halfway to set the Auto Focus (AF) and Auto Exposure (AE). When the AF/AE indicator turns green, press the shutter button completely down. The battery is exhausted. Replace or recharge the battery
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Sony Cyber-shot  DSC-H7 Digital Camera Logo
258 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
