SOURCE: power inverter
Most likely a fuse. Check for a fuse on the inverter itself or one inline with the plug. Usually you can screw off the tip of the plug and replace the fuse inside.
SOURCE: power inverter blows fuse in car
overloading fuse on cars wiring try direct connection to battery
SOURCE: emerson lc320em82s need help checking inverters
OK,
1. On the power inverter board unplug all 6 wires that go to the LCD screen.
2. Test each of those ports for resistance.( the one without the resistance is the bad one.)
3. Or, test each port for Voltage output ( this will happen very briefly since the TV will turn itself off automatically).( The one without voltage will be the bad one).
SOURCE: i need a fuse box map for a 2005 vw jetta 2.5.
lift up cowl in front of wipers and unplug the motor
SOURCE: need to replace fuse for the power windows... do
the power windows are controlled through the Body Control Module. this module controls the windows through a circuit breaker under the hood in the relay and fuse box located near the master cylinder, it is
Position #62 30A CB Power windows circuit breaker, I really doubt this is the problem, but check it, if u have a short circuit the circuit breaker will be hot to the touch.
