Question about Panasonic KX-T7130 Corded Phone
Phone Problem. I cannot take my panisonic kx-t7130 off of FWD/DND. If I plug it into another jack it works fine. I also have another jack that no matter what phone I plug in the phone works but will not ring?
TO SOLVE YOUR FWD/DND TAKE THE PHONE OFF THE HOOK
PRESS FWD/DND DIAL 0 THEN HANG UP....
Posted on Apr 11, 2008
No access to outside lines from one jack
Hi, What you can try is check the plug connection. If they are bent or broken. Replace the cable to and from the phone. If that is OK then you know the phone is the problem. Take it to be repaired.
Jan 20, 2014 | Panasonic KX-T7730 Corded Phone
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
How do I turn on the FWD/DND button?
It depends on what phone system the 7130 is connected to. Most FWD sequences start in the 7xx's. In a TA series, you have 711 ext # to forward it to some extension and 714# for DND. On a TD it's 710x with 2 being all calls and 7101 being DND. . If you have your 7130 connected to anything lower (like a flat pack 308,616 or 1232) just look at the button because I don't think it will do anything else :-)
In the above examples, ending in 0 usually cancels, like 7100 cancels CF and DND on a TD and 710# on a TA. The OM or user's guides to your particular KSU will have the details under Call Forward and Do Not Disturb.
Carl
Jan 21, 2011 | Panasonic KX-T7130 Corded Phone
Panasonic Digital Model KX-T723OE The key FWD/DND
I'm guessing that you didn't mention that the phone doesn't work, it must be in FWD mode. You can cancel CF, or get someone to go into 990 area 9 bit 3&4 and reverse the bits so it will be solid on FWD and flashing on DND.
Carl
Nov 03, 2010 | Panasonic KX-T7730 Corded Phone
I need to turn of fwd/dnd
Take the handset off the hook, then press the FWD/DND button followed by 0 (zero). When you hear the tone, hang the handset back up. This will work with the PT (Panasonic Proprietary telephone) system. (Alternatively, pick up the handset, press 7 (seven) 1 (one) 0 (zero) 0 (zero) and hang up after the tone. This works for PT and SLT phones (single line telephone))
The same sequence works to cancel call forwarding (except for follow me forwarding). In the Follow me mode, pick up the handset, press FWD/DND or 7 1 0 followed by 8 and the extension number. Then hang up after hearing the tone.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7130 Corded Phone
I have an old model of Panasonic PBX system Model D816. I am connecting the main telephone device Panasonix KX-T7730 to Ext. No. 1, this main telephone device has no line and the FWD/DND button light is...
What are the other phones? a 7730 is an analog PITS phone and requires 4 wires to make it work. If you connect it to a digital jack, the data lets it indicate key functions, but there is no voice, and that sounds like what you have. Try taking a 4 pin base cord and plugging directly into port 1 of the 816 and see if everything works. If it does, you have your answer.
In passing, the FWD/DND light will flash if there's a forward or DND condition on the phone. Dialing 7100# from the intercom will clear all FWD/DND conditions, as will pressing the button until nothing lights.
Your delephone reference doesn't mean anything to me.
Carl
Sep 05, 2010 | Panasonic KX-T7730 Corded Phone
Fwd and dnd problem
It's supposed to be. That's what forwards unanswered calls to voice mail.
If you need more info, post back with your system model number and the voice mail model.
Carl
Sep 02, 2009 | Panasonic KX-T7130 Corded Phone
How do you cancel
Not knowing what the phone is connected to, the basic Panasonic command for cancelling FWD/DND is 7100/*7100.
As to the ringing, if your phone doesn't start ringing, please post the model number of the cabinet.
Carl
Jan 23, 2009 | Panasonic KX T7130 Corded Phone
FWD/DND - PANASONIC KX-T7130
Don't laugh. Push the button and read the display. It will either unset DND or CF :-).
The 7100 command is part of the sequence to cancel those features on most phone systems and 790 or 79# will reset the extension. Of course it may be different if you have a TDA or TAW box (*7100) or a KX-T xxx10 system.
Carl
Nov 16, 2008 | Panasonic KX-T7130 Corded Phone
Fwd/dnd button will not flash
FWD/DND is programmed in the system, not the phone. When you figure out what system you have, post again.
Carl
Jun 06, 2008 | Panasonic KX-T7130 Corded Phone
Panasonic KX-T7130 Corded Phone Logo
249 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
