Question about Garmin StreetPilot c340 GPS Receiver
Charging unit with AC adapter
I do not have a cigarette lighter in my RV and I bought an AC adapter Cable from Garmin.
I have a Street Pilot c340. Can I plug the unit into a electrical plug in while I travel ? Will this work like the cigarette lighter in my car which recharges the unit?
Thanks.
norsan13@yahoo.com
    Problem Solver:
  • 5 Answers
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Posted on Apr 08, 2008
Seems to be dead .wont turn on when plugged into the cigarette lighter Garmin street pilot c 510
Before writing the unit off as dead I would try obtaining a new 12v power cable and maybe try your cable in someone else vehicle, often the 12v power in your car can short not providing power to the GPS.
Hope this helps!
Apr 13, 2011 | Garmin StreetPilot c510 Deluxe GPS...
Garmin Street pilot C340 has always worked. This morning it did not turn on. I relpaced the fuse in cord. Any other ideas?
Try charging it from the WALL charger. The battery inside the unit may not be too great. Try it - over night from the WALL charge -not the PC charger. 8de415c.jpg
May 04, 2010 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
My garmin street pilot 330 will not power on
I've had a couple of Garmin C330 units and a C340. They're good quality except for the flimsy power plugs. My first one out of the box had a defective plug which made intermittent contact when I plugged it into the lighter. Tightening the knurled nut on the tip of the plug helped somewhat, but didn't fix it completely. It became a non-issue after I bought a friction mount which came with a better cord and plug. The friction mount also stopped the problem of the suction cup constantly falling off the windshield.
Lee
Jul 08, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Karen died
If the unit works on battery but not the AC adapter or cigarette lighter adapter, obviously the problem is in the adapter.
1. Have you verified that you have +12VDC at your accessory jack?
2. Have you checked the fuse in the cigarette adapter?
What are you powering it with when not on the battery?
- Jim
Feb 15, 2008 | Garmin StreetPilot c340 GPS Receiver
I just received the Garmin C340 GPS as a gift from my daughter.
Only use Garmin approved power connector either AC or DC (cigarette lighter adapter), otherwise you risk ruining your unit. The DC power adapter actually step down the voltage from 12vdc to 5vdc. Using anything other than a Garmin approved adapter can fried the unit.
Jan 21, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin 330 street pilot keeps shutting down. Only 3 mos. old and has been connected to cigarette lighter. What is the problem? I need a manual.
Make sure that you age getting power from the plugin.
Test: With the unit OFF plug adapter into cigarette lighter.
The Garmin should turn on automatically. If it does not,
you are not getting power to the unit. Make sure you have
good connection at the holder.
Generally it powers off by itself because it is not receiving
power from the plug.
Oct 22, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
188 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
