Back to:
Tags:
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
I have a bissell proheat
posted by hkandak on Mar 18, 2008
I have a bissell proheat carpet cleaner purchased in
4-18-2005 for $169.99 from kohls I have used it 6 times
and the last time the brushes would not move cause the belt
was broken and the end of the pump pulley which is plastic
broke off so I reorder the pump unit and 2 new belts and now I see you have sent me a exact pump but the end that broke off that the belt rides on is made of steel or aluminum much strong piece of equipment I want to know if there was a recall for the machine due to mechanical problems I have discribed, why the change in the part
cause it cost me $42.99 to replace as well as time to
fix it as warranty was up and I only used this 6 times
as I bought new carpet the same time and I feel I should
be at least compensated for the $42
Comment by hkandak, posted on Mar 18, 2008
thanks I will contact bissell just seems a sham it broke so easily
after little use thank you
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
reddevil6
Rank:Guru Guru
Rating: 88%, 1204 votes
That is something you would have to take up with Bissell. There is however no recall on the pump. They did change the pulley to a metal one. I know that if too much stuff coming off your carpet, or pet hair, will clog up the belt and pulley putting undo stress on the parts and can cause damage. Needs to be cleaned out once in a while.
Rating Locked! (?) hkandak has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on I have a bissell proheat:
I don't want to Accept this solution
Solution #2
posted on May 06, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I agree with reddevil6.
I have the same model. I've used it more then 25 times since 2006, when we bought it. I always follow the user manual instructions on:
A. Do not stall the brushes on odd shaped objects
B. Clean all hair, debris, and deposits out of the:
1. Bladder and bucket
2. Flow indicator
3 Brushes, and Belt well.
C Never store with liquid in bucket with bladder. If storing with solution bottle full, make sure storage area does not freeze.
(Since solution is made with H20 and may freeze), causing damage
Using it properly, and keeping it clean, has kept it working like new. The last Bissel we had lasted more then 10 years. Our Bissel Rolling Canaster Vacuum, is about 15 years. I just went and bougt a new set of belts as we finally went through the 2 which came with it.
We have an extremely thick greenish/blue
(I'm not sure of the color) burber carpet, that killed 2 ureka's and an oreck XL. All bought after, the bissel, by other family members who said we needed a newer one.
I'm surprised at the quality, of all our bissel cleaning appliances
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Vacuums problems?
Bissell 7901-1 ProHeat Scotchgard Upright...
1 side of my brush will not stay up. Could this be a...
After having to change a belt I decided to do a really...
Seems to be the same problem as alot of other folks. The...
I have replaced the pump in my unit. I cannot remember how...
bissel proheat mod# 7901-1 07124c
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
