Question about Canon NP 6050 Copier
Canon np 6030
Stays in recovery mode -machine keeps running
  • Canon Expert
  • 1,326 Answers
Is it looking for toner or is there still a jam in it. You may want to try to turn it off and unplug the sorter and turn it back on. If that dose not work turn off again and unplug the adf and turn it on again. If that dose not work if you have unplug the bottom 2 trays. If one of those is causing the problem look deeper in to one of those units. Also, will it showw or flash a error code on the display?
Posted on Mar 19, 2008
    New Friend:
Paper jamed & copy quality
Posted on Mar 19, 2010
SOURCE:
My canon np 6030 copier is printing faint copies what could be the problemmy canon np 6030 copier is printing faint copies what could be the problem
clean the optical system i.e.first mirror,second mirror,reflector,lens etc to get dark copies.
checklife of photoconductor drum if it is over replace the drum.
Jul 26, 2011 | Canon Office Equipment & Supplies
I need technical specs for canon np 6030
do you mean SERVICE MANUAL ?
I have it
I can email to you.
May 25, 2011 | Canon NP 6035 Copier
E065 canon NP 6030
If I rember correctly, Your transfer roller unit is arching out. I would first clean off the loose toner in the unit & from the seperation unit. You will need to remove the transfer roller unit. If that dos not clear the code you will need to replace the transfer roller unit. Good Luck
Mar 10, 2011 | Canon NP 6035 Copier
Enter ID Number with the Number keys canon 6030
I have a Canon photocopier NP 6030. Problems on my machine, the display panel is written ENTER ID Number ......., How does the solution sir? Listen Read phonetically
Mar 04, 2011 | Canon NP 6035 Copier
I have machine canon 6030 np and there problem called : E224 please send how can I solve it
Basicly, a E224 is a scanning lamp error code. Here's a question for you??? Will the scanning lamp turn "ON" at all? If so, then the problem is with the scanner power cable. If the lamp will not turn "ON" you may have a blown lamp & or thermal fuse on the scanner unit. You can not clear the code until the problem is fixed. Good Luck
Feb 16, 2011 | Canon NP 6035 Copier
Berapakah ID Keys Canon NP 6030 Copier
PLEASE SPECIFY THE PROBLEM...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Feb 11, 2011 | Canon NP 6035 Copier
I want to download technical support manual for canon np 6030 what should i do?
you can do a search online to see if there is someplace that sells the service manual for the NP6030 and purchase it from them. other than that i don't know of any other way to get a copy of it of if there is even a pdf file for the service manual for that machine. It is a analog copier and has been out of service for a long time
Jun 18, 2010 | Canon NP 6035 Copier
Canon COpier NOP 6030 error code E064
hi.... sir
i've an erorr code for copier np 6030 is 064 how to solve it
Oct 28, 2008 | Canon Office Equipment & Supplies
Canon np 7130f keeps running
does anyone know where to get an owners manual for cannon np7130f online for free??
Jan 22, 2008 | Canon NP 7130 Black and White Copier
Canon NP 6050 Copier Logo
197 people viewed this question
Clive
Clive
old marine
old marine
Ekse
