Question about Ricoh IS760D Flatbed Scanner
Ricoh IS760D Functional Problem SC4020
After a year of only light use, our Ricoh IS760D pdf scanner has died. When I press the green "go" switch on the Network Scanning  Unit Type A, its screen simply reads "Functional Problems. SC4020. Turn operation switch off then on. If the same error occurs again, please call service" and all the lights blink in unison on the main IS760 unit.  I get the same error message each time I power off and try it again.
The unit has just gone out of warranty. Is there any simple fix for this, short of a $700 warranty renewal? Thanks.
  • 4,234 Answers
Unfortunately, the message indicates that the internal startup tests have failed. If this unit is just past the warranty period, I would contact the manufacturer anyway and complain. No unit should fail that close to the period conclusion especially with little to no use. It is possible that a brown-out may have damaged the internal logic. Only a service tech for the company could tell you that. The blinking lights are an indication of the problem found. Report that to the company as well.
Good luck. Keep us posted.
Dan
Posted on Mar 18, 2008
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
Ricoh IS760D won't work with Windows 7 64-bit
Software (driver) can be found at driverupdate us.
Take a look... I hope this was helpful.
Cheers
Jun 27, 2012 | Ricoh IS760D Flatbed Scanner
Functional problem sc101
SC101 is an exposure problem.check if at on of the machine exposure lamp is light in a few sec. then off then follow this as a guide
SC101 D Exposure LampError At trigger on, thelamp was not detected on. Exposure lampdefective Lamp regulatordefective Exposure lampconnector defective Dirty standard whiteplate Dirty scanner mirroror scanner mirror out of position SBU board defective SBU connectordefective IPU defective
Aug 28, 2011 | Ricoh Aficio 450 Copier
Black line on right when scanning adf - have cleaned the machine dont know what else to do
If line appear in to your scanner pic no repair for that but is only when you print just clean the toner.
scanner Lents cant be change
Dec 17, 2010 | Ricoh IS760D Flatbed Scanner
Scannning too slowly
Increasing the default resolution setting, would slow the scanner down, and also increase file sizes dramatically
Feb 18, 2009 | Ricoh IS760D Flatbed Scanner
Richo color scanner is760d don't have option auto feeder
This scanner can be controlled by PixEdit so you may scan any amount of sheets. Even easy continue scanning to one document when not enough space in the ADF for the hold stack
Dec 08, 2008 | Ricoh IS760D Flatbed Scanner
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh IS760D
go into your properties by right clicking on the icon or goto my computer, look for your printer and right click to find property setttings.. you should be able to adjust your colors from one of the tabs that appear..d
Feb 22, 2008 | Ricoh IS760D Flatbed Scanner
Ricoh IS760D Flatbed Scanner Logo
603 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
