Question about Dell 1600n All-In-One Laser Printer
Dell 1815 After restarting the computer, the printer icon shows OFFLINE. Additionally, I am also unable to get on the internet. I'm now using a different computer. My computer is running of Vista. Please help!
  • 95 Answers
SOURCE:
Printer offline
Depends on your OS you need find "printer and faxes" or "printer options on the hardware.
  • Open the Start menu and click on the "Devices and Printers" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. The status of the printer will be shown as either "Printer: Ready" or "Printer: Offline."
  • Click on "Printer: Offline" and the Printer menu will appear. Click on "Printer" in the menu bar and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 12, 2013 | Office Equipment & Supplies
Dell1720 laser printer is offline and cant get it online
If you mean it shows "offline" in Windows, you can sometimes just uncheck that checkmark from the properties menu and it comes online. This happens if the printer experiences a problem. The computer has no way of knowing that you fixed the problem so you have to tell it that you fixed the problem.
If you are talking about the printer not being online (the actual hardware) you can try clicking on the "reset dell printer" icon in windows. You may need to download this utility from dell.com.
Aug 29, 2011 | Dell 1720dn Laser Printer
My Dell 1700n Printer keeps showing up as offline. I have a Dell Optiplex GX520 PC. My printer has been working fine, I moved the printer to a new PC temporarily and then moved it back to my PC and now...
hi
i suggest you reinstall the drivers on the computer(s) which will use the Dell 1700n printer.
let me know if this helps
if you need the drivers go to this link all you have to do is select the operating system (go to My Computer, right click and properties, will give you the OS)
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&ServiceTag=&SystemID=PRN_LSR_1700N&os=WW1&osl=en&catid=&impid=
Nov 03, 2010 | Dell 1700n Laser Printer
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Jun 12, 2009 | Dell 1710n Laser Printer
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
Dell Laser MFP 1815 wont print
The printer status showing offline is more then likely a computer issue then the printer. On the printer, use the menu to select "reports" and then select the printer settings report. If the printer prints the report, then the printer itself is working, and it is a communication issue between the printer and the computer. If you are connecting to the printer with a usb cable, then try moving the usb cable on the computer to another port. If this does not work, try deleting and reinstalling the printer.
Sep 25, 2008 | Dell 1815dn All-In-One Laser Printer
Problem with my Dell AIO 922 Printer on Windows Vista
if you have restored the printer to an earlier date , make sure that the printer drivers are still installed on your computer . Click on start and then click on run . type " control printer " , and then look for the printer icon Dell AIO 926 and check for the Status as Ready , if it is offline then right click on the icon and click on " use printer Online" and also look for the Check mark on the printer Icon. right click on the printer and then click on cancel all the documents , restart the computer and then power cycle the printer disconnect and reconnect the printer cable and then try printing a testpage...
May 16, 2008 | Dell 922 All-In-One InkJet Printer
Hp deskjet f340 series keep showing offline
hi,
follow the steps:
>unplug the usb cable from the back of the printer
> go to the printers folder inside the control panel
> right click on the printer icon and then click on delete.
> if the printer icon is deleted and if there are no more printer icons related to your printer, plug the usb cable back to the printer and wait for few minutes while it automatically installs the driver.
NB: if you are unable to delete the printer icon. then right click and click on "pause printing" and then again right click and clear the documents in queue. if it is done then delete it.
if you are unable to clean the documents in queue, then
click on Start-->Run, type "services.msc" and click ok.
Double click on print spoolers and then click on "Stop" and then click on "Start". Restart the computer. then try to delete the printer icon.
Thanks and regards,
Agnel
Feb 29, 2008 | HP Deskjet F340 All-In-One Printer
Dell 1600n All-In-One Laser Printer Logo
70 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
