Question about HP iPAQ H5550 Pocket PC
Ipaq 5550 background problem
Failed to start background reading (status=5, error=-102, retcode=0). Perform a normal resert and try again. IPAQ 5500
can you please send me the files to upgrade it?
[email protected]
thank you
  • Motoi  Bogdan
    Motoi Bogdan May 11, 2010
    Does this error occur when you try to boot the pda? And is it permanent, each time the pda tries to boot? Can you see the the pda's normal stand-by screen (the one with today items, start button etc) ?.
    I need these answers in order to better understand the problem.
[email protected]
thank you
Posted on May 23, 2008
SOURCE:
IPAQ 5550 can I override the pin number?
Simple Solution:
Perform a hard reset and then attempt to login repeatedly (10x).
You will then be prompted if you wish to reset the pin entirely.
Good luck,
-AndyPants-
Jun 15, 2009 | HP iPAQ H4150 Pocket PC
(status=5,error=-102,retcode=0)
Please provide me the pda model you have and an email adress.
Also please tell me what language should the rom file be. If I don't find that specific language I'll send the english standard one.
Mar 26, 2008 | HP iPAQ H5550 Pocket PC
Rx1950 freeze on soft reset
You can do a hard reset by doing the following...
01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
03) Release the "Calendar" and "iPAQ Wireless" buttons.
04) Press the "Reset" button/hole again (so that it resets/powers on.)
Nov 01, 2007 | HP iPAQ rx1950 Pocket PC
HP ipaq 5550 - Bluetooth error
The error message is telling you that there is not enough memory to load the BlueTooth driver, try moving some of your files from My Documents/My Music etc. to your memory card. Also try uninstalling some of your programs and reinstalling them to your memory card, this will free up a fair bit of space in main memory and hopefully resolve the problem. Also; Tap Start, tap Settings, then tap the System tab and tap Memory. Tap the Main tab to see how much space is available in main memory, you should see a total of around 115-120MB available (128MB - the lie of storage device sizes - the file system) divided in to storage memory and program memory, if you see considerably less then you're iPaq has a hardware memory problem and will need repairing. Lastly keep in mind that Windows error messages cannot be trusted and the actual problem may be absolutely nothing to do with memory, so if this doesn't help post back.
Aug 22, 2007 | HP iPAQ H5555 Pocket PC
IPAQ 5550
Performing a Full Reset A full reset is sometimes referred to as a ?hard reset.? Perform a full reset when you want to clear all settings, programs, and data from RAM. A full reset deactivates the battery. The power button does not function until the battery is reactivated. CAUTION: If you perform a full reset, your iPAQ Pocket PC returns to its default settings and loses all information that is not recorded in ROM. To perform a full reset: 1. Press and hold Application Buttons 1 (Calendar) and 4 (iTask) on the front of the unit and, at the same time, use the stylus to press the Reset button on the bottom of your iPAQ Pocket PC. 2. Hold all buttons until the displayed Full PDF document can be found here: http://h20000.www2.hp.com/bc/docs/support/SupportManual/lpia8006/lpia8006.pdf
Aug 19, 2007 | HP iPAQ H5555 Pocket PC
Finger Print Scanner
Hi again. Give me your email adress please, for me to send you the required upgrades. Read my other post in the other section you've wrotten and you will have the instructions on how to do everything there. Thanks.
Jan 22, 2007 | HP iPAQ H5450 Pocket PC
Not Loading Up
You may be in need for a ROM update/reinstall. It is pretty easy to do that. You can either go at HP's web site and download a ROM update for your specific model. Make shure you select your operating sistem rigt. Or you can browse the internet for a specific ROM update for your model. I recomand the HP site, and if you have problems regarding the ROM update process, or the ROM and OS version you need, please reply here and I'll guide you throught. Good luck.
Jan 18, 2007 | HP iPAQ H4150 Pocket PC
Fingerprint reader issue
after a number of soft resets the problem seems to go away.... for no apparent reason. However the problem then reappears for no apparent reason.
Sep 14, 2005 | HP iPAQ H5550 Pocket PC
Ipaq 5555
If you did a "hard" reset and it doesn't work, it's a hardware problem... Send it in for repair.
Sep 07, 2005 | HP iPAQ H5555 Pocket PC
HP iPAQ H5550 Pocket PC Logo
120 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
