Question about InFocus LP 755 Multimedia Projector
No video from computer input port
I have an infocus lp-755 projector that has a vesa input connector for a computer interface. I was trying to use an adapter cable to feed standard component video to this port. (ready made adapter cable is available on ebay) No video appears. Video is fine from svideo port. I tried auto source select and specific set to computer port with no luck. Scope shows video on the cable pins so there is video. Someone said a sync signal has to be included. ??? the adapter cable has only 3 coax cables, no other wires for sync. Any ideas? This is being done since many sources offer the cables.
    Welcome Back:
    Visited the website for 2 consecutive days.
When i plug in my vga to pc ,i had to unplug pc screen adnd reboot pc,
the pc vidio card could not find the vga plug until i rebooted.
also to get rid of the colour problem try switching infocus to auto select..
the above solved my problems
trevor b
Posted on Feb 20, 2012
  • 563 Answers
Hi there
As far as I know this specific model requires comes out with a convertor box - are you using it ?
Posted on Apr 03, 2008
  • trevor burlinson Jul 29, 2012
    ihave solved problem,thank for your help
Infocus lp770, trying to hook up to apple computer using the usb port? will this connection work to run the 770?
You need to hook it up using VGA or HDMI for it to transmit information from your Apple computer to projector. You can check the Ports available at the back of your projector and you can Purchase cable needed from either Apple or Infocus or any computer store.
Hope this helps.
Sep 05, 2011 | InFocus LP 770 Multimedia Projector
Colour dispaly problem in LP 640
are you useing SVIDEO out from your pcs video card to connect the image to the projector?
have you set your pc to send video out correctly?
It seems your pc is not sending correct video / settings wrong.
Or then there is a problem with the projector. Try a difrent input?
Mar 29, 2008 | InFocus LP 600 Multimedia Projector
Computer image does not cone out through the projector. the image goes blank immediate i connect it to the computer
try doing a Reset All on the projector, which should be located within the User menu. i'd also check the VGA cable connectors on each ends, make sure there are no bent pins
May 21, 2011 | InFocus LP530V Video Projector 2000 ANSI...
Power is on and light is coming from machine but it is not displaying the picture from my computer?
when you select the menu, do you see it on the screen.
if so then have you selected the correct rgb input.
If your sure thats correct then,
On the PC press down and hold down the Fn key.
Then press the F5 key and wait a bit then try the F5 key again until video comes out of the external rgb connector of the PC
Feb 24, 2011 | InFocus LP 240 Multimedia Projector
My projector will display an image from my PC, but when connected to a video scource via the Phono socket or the SVideo socket, nothing, It just stays on the Infocus welcome screen. The menu generation...
I have the exact same problem with my LP-755 projector !
Just then PC input detection works but no RCA A\V detection or S-VIDEO detection...
I'm looking for the service manual of this unit - can anybody help or refer to a download source ?
Even a simillar units electric-diagrams could be very helpful for troubleshooting !
The inside (video inputs) controller PCB model number/barcode is 510-1457-06 00
There are also daughter boards with EPSON name on them.
Dec 22, 2010 | InFocus LP 755 Multimedia Projector
I am trying to set up an InFocus LP400 projector with my computer. I followed the instructions using the CableWizard Lite cable for my laptop pc and get no projected image. I used the suggested port...
start the connecting all over again, by following the steps below:
1. Turn your computer off.
2. Connect the cable from the computer to the projector. If you want to have your monitor to be hooked up as well, connect a splitter to the video out port (DVI or VGA). You can also just hook the projector up to the second port on your video card (If you have one) or if you have a laptop, you can connect to the video out port on the back.
3. Turn the computer on and boot into your desktop.
4. Turn on the projector. Most projectors have an auto detect function, that will detect a video signal and auto configure the projector to display that signal. If you have a laptop, you have to hit a function key to activate the second display. Usually this is FN Key + F5 or one of the F Keys across the top of the laptop keyboard. It looks like two squares, one empty and one with something in it.
5. Adjust the focus, brightness, contrast, and color on the projector.
6. Aim the projector at something white. Try not to aim it at something highly reflective.
7. Step back ... Load up your favorite game or video ... and enjoy.
Your project should work, after following the above instruction.
Good luck.
Apr 07, 2010 | InFocus LP 400 Multimedia Projector
Cannot get computer screen projected by 530
reset the settings to factory default. does the splash screen or a blue screen come up? make sure the correct input is selected, swap out the cables, and make sure the port on your computer is activated. if all else fails, you may need to drop the resolution on your computer to match the projector.
Jan 13, 2010 | InFocus LP 530 Multimedia Projector
The infocus projects when the computer starts up but later says there is no connection. I have used the toggle keys but no success.
are you using the cable wizard and comp1? if so, that may be your problem. use comp 2 (regular 15 pin vga). if you're having a problem with that one too, reset the settings to factory default (the resolution may be off). it has 1024x768 native resolution and maxes at 1280x1024
Dec 02, 2009 | InFocus LP 755 Multimedia Projector
Infocus In24+ driver?
I think projector is do not need driver, i see in the infocus website as long as you connect it to the computer it always display.
please see the details of your infocus here:
and also you can download updates firmware to fix some error display.
May this help, best regards, melnavz
Jan 14, 2008 | ASK Proxima Proxima DP2000S Data Video...
Color Alignment
reset the settings to factory default. then re-solder the fingers on the edge of the power supply board where it goes into the main board edge connector.
Nov 14, 2007 | InFocus Proxima DP6155 Multimedia...
InFocus LP 755 Multimedia Projector Logo
178 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
