Question about Packard Bell (181379) Motherboard
Packard Bell MotherBoard R6512 (PWA-8050MB/M BD
Hi Fox
I'm very greatfull for what you are doing for me.
Tomorrow i wil take some measures from various components on the Power area specially this yellow component that i think is the FUSE (PF1).
As you say the other component on lacation PD701 must be the DIODE.
Now i send you 2 much better pictures:
Thank you very much
Domingos
  • Domingos Mar 21, 2008
    Allo Mulder:
    I have made some measurements and after that i brought my motherboard to a electronic shop to identify the DIODE and the FUSE.
    My measurements are: (I did it with a 9V battery)
    1. Incoming voltage between (+ )and (-) is 9.1V
    2. Voltage between the 2 poles of the FUSE 9.1V. (Fuse grilled???)
    3. Resistance between 2 poles of the FUSE = no movements (dead????)
    4. From (+ )and both poles of the DIODE Voltage is 9.1V
    It's seems that de Diode lets pass the neutral and the FUSE does'nt let pass the stream.
    When i know more i let you know. Now i'm waiting for response of i can buy both parts (Diode and Fuse)
  • 3 Answers
Hi Domingos,
Yes you're right !!! PF1 is the fuse and PD701 is the diode...
What are the results from measurements ?
Is the fuse grilled ? And is the diode OK ?
Do you have the voltage somewhere ? or is it shorted beetwen + and - ?
Regards.
Fox
Posted on Mar 19, 2008
SOURCE:
Where do i connect the sw wires on a packard bell imedia micro atx motherboard. Diagrams and written adive would be appreciated.
Hi, The SW wires are connected on pins just below SATA connectors.The details of what pin corresponds to what will be given in your Motherboard's user-manual. Thanks, C Rahul
Jul 20, 2011 | Packard Bell (181402) Motherboard
I have a packard bell r 6512 laptop I lost recovery cd. so I want drivers for the above said laptop. How can I get.
you can to to there old link here --->ftp://ftp.download.packardbell.com/NOTEBOOK/EasyNote%20R6%20series/Driver/xp/
Dec 04, 2010 | Packard Bell Computers & Internet
My battery wil not charge on my laptop
Two things could be wrong. Either your battery is bad or the port that your battery connects to on your motherboard is bad.
Buy a battery and see if it charges. If it don't then you have the bigger problem.
Here is a link to a battery.
http://www.pqbattery.com/battery_specs.cfm/Laptop-Batteries/PACKARD-BELL/Easy-One-Silver-2120/P39489-442670000005-69535-986
I'm sure you can try ebay for a cheaper one.
Apr 20, 2010 | Packard Bell Easy One Silver 2120 Notebook
I need Mitac moterboard pwa-avnv bd maual showing
hi i imran my motherboard d915grv sound hardware not dedect what asulotion
Aug 06, 2009 | Compaq (316864-001) Motherboard
Internet working msn working web cam working no google or fire fox homepage to search web sites on my new packard bell vista computer.
what do you get when you click on internet icon? sounds like you need to change your home page they setup them up for allsorts these days depends what there advertising
Nov 08, 2008 | Packard Bell Computers & Internet
Packard bell utow co20
Please look on the case of the PC, fron back & sides. There should be a model number. (There is no such number you posted, Packard Bell UTOW CO20).
Mike
Jul 06, 2008 | Packard Bell DR724 Motherboard
have you tried looking on lycos images for packard bell multimedia 7950 motherboard
May 01, 2008 | Packard Bell (181368) Motherboard
Motherboard Packard Bell EasyNote R6512
38ae9ee.jpg Hi Domingos,
Don't worry for your English, I'm french and mine is not so good...
The first component seems to be a diode : what is its indication near it on the mobo ("Dxxx" or "PDxxx" or what else) ? Check its resistance in both direction.
I don't recognize any fuse, and the orther picture is too far (components are too small), but you should look for indication like "Fxxx" or "PFxxx" or "FUxxx". Sometimes, fuses look like green resistor (flat and rectangular) with a cross on it like X. Just behind the diode it's a resistor because there is "R010" on it. However, check its resistance to be sure it isn't grilled.
When you put the power on the mobo, do you find voltage beetwin ground and positive pole of components ?
May be you could resend picture of the other side but nearer.
Hoping this help you...
FM.
Mar 17, 2008 | Packard Bell (181379) Motherboard
Mptherboard Packard Bell EasyNote R6512
Hi Domingos,
I've just changed the grilled fuse and the zener diode which was shorted. The problem is to find where they are on YOUR mobo if it's exactly the same trouble...
At least, did you find the fuse (very often the first component after power jack) ? and diodes are small red or orange glass cylinder with yellow ring.
The fuse should be conductive of course and diode should be conductive in only one direction. For both, check it with ohmmeter, in each direction for the diode (change probes of meter on poles).
If necessary, change compononents : be carefull with diode polarity because it's important (colored ring in the same direction).
I hope this will help you...
Regards
Fox
Mar 15, 2008 | Computers & Internet
Open Questions:
ZONEALARM Tech sUPPoRt pHoNe +18OO,,8O3''1O69 number Usa.G.Ds Usa ZONEALARM USA phone number is ranked #2 out of 2 because 7,728 ZONEALARM USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he ZONEALARM USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, ZONEALARM USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. ZONEALARM USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact ZONEALARM USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling ZONEALARM USA Calling ZONEALARM USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from ZONEALARM USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with ZONEALARM USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare ZONEALARM USA's phone numbers against each other. Contacting ZONEALARM USA in General While I8OO8O31O69 is ZONEALARM USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach ZONEALARM USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact ZONEALARM USA.
Oct 21, 2019 | Best Computers & Internet
VIPRE Tech sUPPoRt pHoNe +18OO,,8O3''1O69 number Usa.G.Ds Usa VIPRE USA phone number is ranked #2 out of 2 because 7,728 VIPRE USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he VIPRE USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, VIPRE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. VIPRE USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact VIPRE USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling VIPRE USA Calling VIPRE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from VIPRE USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with VIPRE USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare VIPRE USA's phone numbers against each other. Contacting VIPRE USA in General While I8OO8O31O69 is VIPRE USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach VIPRE USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact VIPRE USA.
See all Packard Bell (181379) Motherboard Questions
Packard Bell (181379) Motherboard Logo
1,755 people viewed this question
Top Packard Bell Computers & Internet Experts
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
