I have a counter top ice maker. I can't seem to locate parts or find out if this machine even exists. It stopped making ice last summer. It cycles but does't add water to the cube maker. You have to add water manually before setting the cube size. Then after that I believe the water is pumped up into the cube maker. Model #MCIM30TS, Serial #SA12863
Magic Chef Counter Top Ice Maker. just bought one. it seems to go through the cycle, but i noticed no water is getting pumped up to the tray. I looked through the back and the water tu be is 1/2 way, doesnt seem to pump water up. I may take it appart soon. Anyone have any luck?
I am thinking of buying a used 2005 GE side by side fridge model GSS25XSRCSS. Any experience good...
(More)
I am thinking of buying a used 2005 GE side by side fridge model GSS25XSRCSS. Any experience good or bad would be helpful. Thanks
My samsung side by side fridge/freezer has a flashing light on the fridge temp control 3rd light...
(More)
My samsung side by side fridge/freezer has a flashing light on the fridge temp control 3rd light down but the freezer has stopped working. The lights still on in the fridge but I can't control the temp on any off it. The last temp I had the fridge on was minimal as it hardly had anything in it so it's stuck on that setting if working at all. The serial number is Samsung Interlect DA68-11152F
need easy solution to turn off the beeping sound on Kenmore Top Freezer Fridgerator. No rhyme or...
(More)
need easy solution to turn off the beeping sound on Kenmore Top Freezer Fridgerator. No rhyme or reason for the beeping - driving me crazy.
