HP C5180 All-in One printer. I cannot feed pre printed DVD label sheets. tried their fix of selecting Photo paper plus option but still got problem . The sheet has a grey block of color at lead edge. If I reverse sheet it feeds ok but print is in wrong position of course
  • Anglian Mar 18, 2008
    Have also tried just about every other paper type setting available but still the same problem. I believe the problem i caused by the grey printed block of color at the top of each sheet but I could be wrong. But why does the paper feed and print if the lead edge is plain. These are pre printed sheets and must be fed so that grey color block is the lead edge
    Thanks fot that , but am I to assume that this type of printer will kick out any pre printed paper that carries a coloured block at the lead edge?
  • 4,889 Answers
Fix:
Cut a piece of scotch tape that is slightly wider than the page. 9" or so.
Apply about 1/2 the width of the tape to the top of the label sheet so it DOES NOT cover any of your labels. Wrap the other 1/2 of the width of the tape over to the other (backing) side of the page.
Use a scissor to trim off the overhanging tape on each side of the page.
Feed the label into your printer and it should now work.
Posted on Mar 18, 2008
    President:
  • 1,314 Answers
Look dont care about the cash just want to help try here ok http://avery.com/
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
C5180 sounds like printing then jams
try aligning the heads, and cleaning ink cartridges
Nov 18, 2012 | HP Photosmart C5180 All-In-One InkJet...
C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
How do i print labels using epson r2400 photo printer?
If you are using the Avery template, make sure you change the page setup settings from Manual Front (default) to Default Tray (sheet). Then when it tries to fix the layout, select ignore (on Wrd 2007 anyway). Then select Photo / Glossy paper and hopefully away you go.
Mar 31, 2009 | Epson Stylus Photo R2400 InkJet Printer
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
I can't seem to print borderless photo prints
Ok,
After going back and forth with Hp which by the way were very helpful I still did not get a fix. I decided to go to "Control Panel" Clicked on "Printers and Faxes". Right clicked on my printer icon and deleted it. Then I clicked on "Add a printer" I added the C5180 again and now it works great. Don't know why and I don't care. Just so it works again. That's the nature of computers sometimes. Thanks
Feb 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Can i print on printable dvds on this printer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Print CDs
1. Open HP Photosmart Essential 3.5 software.
2. Select Create option.
3. Select Disc Labels option.
4. Select Print directly on Disc option.
5. Choose the Mini CD.
6. Select Choose this format option.
7. Choose the appropriate Design and Photo you want.
8. Click on Create.
9. Under Settings option, select the appropriate printer and Media type.
10. Under Printable Area option, select Standard/Print to hub option from the drop down list under Standard Sizes.
11. Click on Print button.
Jan 25, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 (wont accept photo paper but will normal paper)
Load the printer with the slick glossy paper face down. See if it will print.
Jun 06, 2017 | HP Photosmart C5180 All-In-One InkJet...
Avery Ink Jet Magnetic Sheets - 3270
It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
Feb 04, 2008 | Avery DesignPro Deluxe CD-ROM...
Paper jam error message
I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery with age, and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it). And then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
Dec 28, 2007 | Canon PIXMA iP1600 Printer
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
