Question about Dryers
Kenmore series 80 Gas Dryer: No heat
Kenmore series 80 gas dryer: heat doesn't come on; drum turns normally, everything else seems okay.
  • 8 more comments
  • Anonymous Mar 12, 2014
    Suddenly no heat
    wont heat
  • Anonymous Mar 15, 2014
    My Kenmore series 80 gas dryer runs whenever the door is shut. I don't need to push the start button. The dryer does shut off when the timer runs down though.
  • Anonymous Mar 16, 2014
    Series 80 gas dryer not heating
  • Anonymous Mar 17, 2014
    kenmore series 80 dryer Drive Motor
  • Anonymous Mar 18, 2014
    110.67832794
  • Anonymous Mar 19, 2014
    I have a Kenmore gas dryer and it makes a knocking sound as the drum turns
  • Anonymous Mar 23, 2014
    new Kenmore dryer was purchased and the dryer is not working
    Turns but has no heat
    Drum turns but no heat in electric dryer
  • 156 Answers
Ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Posted on Mar 19, 2008
I have good info. on fixing the 80 series gas dryer but accidently posted it under a problem with no heat in the electric version. Check it out, our dryer finally works! Leslie
Posted on Oct 27, 2012
Kenmore 80's series electric dryer no heat...drum
Check your breaker by turning it off and back on. Then check wiring at plug and back of dryer. You could have a bad relay switch. You can find it under the top and put the 2wires together and try it then . If it works, you know that it is the relay switch. Last but not least, it may be your element. Check it visually to see if there is a break in it or a weak spot.
Feb 27, 2013 | Dryers
I have a kenmore 80 series. dryer will heat on all cycles. drum will not turn. gas dryer was in about 9" of water.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 07, 2011 | Kenmore Dryers
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Kenmore 80 Series Gas Dryer won't run unless empty
MORE THAN LIKELY YOUR TENSION PULLEY IS SHOT WAS IT MAKING ANY SQUEEKING NOISES
Aug 26, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Nov 27, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
2,216 people viewed this question
Top Dryers Experts
