Question about Canon PIXMA MP780 All-In-One InkJet Printer
PIXMA MP780 Canon Copier skipping lines
We have been successfully using our copier all day. All of a sudden, a copy came out with lines missing. The area that had no ink on it at all was equal in size to that of college ruled lined paper. Coincidently, the last successful copy we made was of a paper on college lined paper. The copies since then have gotten progressively worse to the point of having almost no ink on the paper at all.
Also, the machine has started squeeking.
Any thoughts.
  • 2 more comments
  • Anonymous Mar 27, 2008
    copier prints 4 lines then look as if it erased the fifth line. this pattran
    goes on andon, replaced both black inks, please help me I need my
    printer.
  • Anonymous May 06, 2008
    My problem is the same. been usen my printer for three years with
    no problem, then it started; it prints two to three lines then earses the
    neck three are four line. I put in freash ink, took it apart and cleaned.
    in doing some reserch and reading some others problem.
    now i still need to locate the device that will clear this up. if you could
    steer me to find this I would be most appreciated.
  • Anonymous May 08, 2008
    Yes I have the same problem. it will scan,copy and print. The problem
    is the same it will print two to three lines then looks to erase the next
    line. I cleaned the head and installed new ink and they same problem
    still is there. Plan to drive in to STL to get a new printer head to see if
    if that will clear this problem. I will keep you posted on my progress. Len
  • Anonymous May 18, 2008
    I have the same problem. tring to get more info I found out that this
    could be in the printer head. replacement of this is around $31.00 put
    i am not sure that this could be the problem. I would like to know if
    this is the real heart of my problem don't want spending good money
    for something that might not work.
Try cleaning printhead (google it you find it) make sure you attempt cleaning with Windex ammonia D (overnight solution)
If not you may have to replace Printhead (Plastic Box, cartridges snap into) sometimes the resistor will burn out.
1-800-828-4040 (Direct from Canon $31 + shipping)
If that doesn''t work contact www.usa.canon.com and find authorized printer repair. location. I am having same problem!!!
Posted on Mar 31, 2008
6ya staff
SOURCE:
Right now, the scanner bar is stuck to the far right and it makes a loud noise like gears slipping. But I would also like a copy of the "Service and Repair Manual" for any future problems.
Hi rksde,
First of all, thank you for purchasing the service/repair manual of Canon Pixma MP780.
Please email me at [email protected], manual has 132 pages, it can't be uploaded here.
Again, thank you so much!
Rating and feedback are highly appreciated!
Good luck and have a great day!
mjsazon
Jan 18, 2012 | Canon PIXMA MP780 All-In-One InkJet...
Power is on to my Canon Pixma MP780, but no display
I got such problem on my MP 780 (grayed boxes on bottom LCD line, no function). It turned out to be missing 1.5V for CPU core. On revese (solder) side of mainboard i found point described as "1.5V". I've powered this from external supply (took about 2 amperes) for few seconds and MP is alive again (without external supply).
Jun 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I can not get my inkjet canon MP780 to print, Ican not get it to scan, I can not get it to copy! Two days ago no problems HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Delete the software as it is installed. Then rerun the installation disc. Or restore your computer to three days ago and you should be back in business.
Jun 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
When i scan on my Canon Pixma MP780 printer i get a red line down
This is what the service manual says:
(1) Clean the Document glass.
(2) Check the connection
between the contact sensor
and SPCNT board (JCCD1).
(3) Replace the SCANNER
unit.
(4) Replace the SPCNT board
***’y.
Jun 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
MP870 won't copy.
Try cleaning the heads and check print head allignment on the printer, this can usually be done through the printer software or your pc settings
Aug 21, 2017 | Canon PIXMA MP780 All-In-One InkJet...
We cannot receive or send faxes
hello dmhertz
anything here that may help Canon .
riz.
May 12, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Toner
when they say TONER , its refering to the INK CARTRIDGES , Color & black ,
CANON PIXMA MP780 & MP750 uses the same INK CARTRIDGES :
BCI-3eBK for BLACK & BC-31C for color
please rate this solution , hope this helps
May 01, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
542 people viewed this question
Clive
Clive
old marine
old marine
Ekse
