Question about Samsung HCM422W 42" Rear Projection Television
Focuse Before I knew it was te convergence board, I played with the focus. Is there a way to put the TV into a test mode so I can line up the three guns?
    Genius:
  • 2,920 Answers
You should be able to do that from the remote with the convergence.
Posted on Nov 05, 2008
The colours are no longer lining up. On captions you can see the three seperate colours. The auto focus does not fix. How do you enter service mode to adjust grid lines?
U can't do any grid lines adjustments for this problems,the tv problems it is having are known as a convergence pictures problems,it is dead.The tv have any colors lines like R,G,B mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than the tv convergence board it is dead for the tv to causes all of these convergence pictures problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost like $300-350 for parts and labors.
Sep 21, 2011 | Toshiba 57H83 TV
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
What does it mean when you get a error code 5 when you are doing the magic focus?
Mean ur tv convergence board it is dead,any codes error at all,mean the tv convergence board have components it is dead and the board it just dosen't conververt it three CRTS tv colors Tubes like R,G,B colors lines yokes anymore.Now.The tv convergence board must have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.After the tv fixed it convergence board,the tv will run the entire Magic Focus function,without any error codes at all.The tvs shops will cost u like $300-350 for parts and labors.
Jul 10, 2011 | Hitachi 53UWX10B 53" Rear Projection...
Wavy color separation, auto focus doesn't fix problem. Doesn't have a manual focus.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
Oct 11, 2010 | Sony KP-57WS500 57" Rear Projection...
Wavy lines green and orange hue.While watching a fooball game the status bar is wavy and in two separate lines-Green and Orange-Tried flash focus and convergence and powered unit off for several minutes...
Flash focus button push,didn't solved pictures convergence problems.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Focus
its the convergence problem in your power supply board
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
also check out for the convergence bulb if that goes dim the screen becomes out of focus
thanks.
Oct 13, 2008 | Zenith SY2728RK TV
Samsung Rear Projection Problem (not convergence)
The tv has 2 focus adjustments for each tube, mechanical and electrical.
1. Mechanical focus is set by looking at screen from back (through inspection plate on back of most samsungs) and rotating the lens assembly on CRT. loosen wing nut and turn lens assembly to go through focus and back to best position.
Put convergence pattern on screen and manually misadjust bottom red and green lines convergence so they can be seen through inspection hole.
With back cover of TV off you can usually reach your hand up beside the lens assembly to loosen the wing nut then rotate to adjust. Green is in the middle. The focus will be obvious when you rotate and look
When you are finished make sure the foam dust protector is not over any of the lens assemblies and the wing nut is tight.
2. Electrical focus - located at front of unit. the front grille/speaker cover is removed and maybe a cover over the front crt inspection hole.
In the inspection hole there is a black plastic "Focus/screen adjust Assembly" with 2 rows of 3 controls.
One row is focus and the other is screen. The middle controls are for green with R/B on either side. Usually the controls are labelled as "focus" and "screen". You want to adjust the focus controls, one for each color. Look for the focus or screen label imprinted in the plastic. Don't play with the screen settings.
With the same misadjusted convergence pattern you can see a red, blue and green line. Adjust green focus and watch green line for best focus. Do same for other 2.
Screen adjustments are very exact and delicate. The easiest way to deal with them is to turn color off in Customer adjust menu. Put any color tone adjustments in the middle (low, med, high, put at med).
You should have a b/w picture if there are no crt or other color related faults. If it is close to B/W leave screens alone.
If the pix is too green, then the green screen setting must be reduced a small amount. Do not play with these adjustments as most TV repairrers have a difficult time adjusting them.
If focus adjustments don't help then focus control or CRT may be defective. Needs expert to determine.
easyab
http://calgaryconvergencerepair.weebly.com/convergence-ics.html
Jun 24, 2008 | Samsung HCM4216W 42" Rear Projection...
Akai PT4298HD Rear Projection
Perfect Focus and the convergence screen are for convergence, not actual focus. Real focusing is done in a combination of two ways: electrostatic and optical. And to do it right you need a good test pattern, like the convergence pattern from the Digital Video Essentials DVD. At a bare minimum turn your contrast down to half (don't use "dynamic" mode, ever).
This is going to sound scary, cuz it terrified me at first but now I'm comfortable with it:
To focus electrostatically, the front panel under the speakers needs to come off. As in actually unscrewing some screws and opening up your tv. Do all of this without cats or toddlers in the room. There are three circuit boards on which the picture tubes are mounted, and each board has a focusing knob next to the words "red," "green," and "blue." Do not touch ANYTHING other than these knobs. Twist the focus back and forth until it is as focused as it will get. The lines on the convergence pattern will get fatter or skinnier. If they get fat in one direction and skinny in the other, find the best compromise. Do not focus the blue too perfectly, as perfectly focused blue lessens the amount of blue relative to the other colors, making whites look yellowish.
Next you really need to clean your lenses, they are filthy from dust and that's why the focusing is so bad. For this tv, you'll want all three panels on the front to come off. That's about twenty screws, both on the sides of the tv and the undersides of the panels. The middle panel that covers the speakers can rest on the floor by the front panel, but the screen panel needs a resting place. An ottoman, or a chair with a towel on it, makes a good place to rest the screen (parallel to the floor).
Each CRT has a set of focusing lenses, and these can be removed. Do one at a time. They come off from four screws each. FOUR SCREWS. Do NOT unscrew anything else, as just under the lenses is a cover for the CRT. Take this off and you risk coolant leak, leading to expensive electrical problems. Do not, repeat, NOT touch either the lenses or the mirror with your fingers. One scratch is bad. Scuff marks can destroy a picture. These lenses and mirror are easily damaged.
http://www.keohi.com/keohihdtv/learnabout/generaltips/screenoptics.html
There are some cleaning techniques there. I'd only bother cleaning the top and bottom of the lens assembly. Don't mess with the wingnut on the side, we'll handle that later.
Now, with your CRT lenses back on (wingnut facing towards the mirror), replace all of the panels and rescrew the screws. Next we do optical focusing. Again, this is where test patterns from a test pattern DVD come in handy. Regardless of what TV a person owns, a DVD like Digital Video Essentials is, well, essential.
This time we're taking a panel off the *back* of the TV. Scary, huh? Specifically, the bottom one (there are two big back panels). About fifteen screws, four of which are the same ones you do to get the front bottom panel off. Get all of the screws off, pull it back, and lift it out. Don't touch any of the electrical stuff. From here, if you are careful, you can reach up under the mirror and untighten the wingnuts on each CRT lens assembly. If you are using a test pattern, use a standard definition one here, makes the scanlines easier to see.
Here's what I do to focus each gun:
1) Put on a full screen of green, red, or blue, depending on which gun I'm focusing. DVE has just these patterns.
2) Untighten the wingnut, and start making minute adjustments.
3) What you want to see is *scanlines*, as clearly as possible. Make a tiny adjustment, get back around to the front of the tv, and see how well you can make out scanlines. An all-green screen should actually be a bunch of horizontal lines of green. If you can't make out these lines, you aren't focused.
4) If you don't seem to be making progress at all, switch to DVE's convergence pattern to make sure you haven't completely lost focus on that color. You want to start from good focus, and then fine tune very delicately.
5) You may find it hard to get blue-focus perfect. That's okay, really, as blue is a filler color. Green was very hard for me to see lines on, but it was a step up from not being able to see them at all.
6) You may find it necessary to go back and forth between electrostatic focusing and optical focusing adjustments to get them right. That's okay.
7) When it seems you've done the best you can, you're done. Put the back panel back on and rescrew all of the screws.
Now you need to adjust your convergence. You can use the user convergence menu, but it will only get you halfway there, because it only controls like nine or twelve points. What you want is to access the *service* convergence menu. With the tv on, press mute-1-8-3 on your remote (not pressing them all down, just in that sequence). You should switch to a secret built-in convergence screen.
I hate to tell you this, but the only way to save settings made in the service convergence screen that I know of is with a Samsung remote, not the Akai one. This tv is actually a Samsung after all, and the Akai remote is missing some buttons that the Samsung remote has. You can buy them off partstore.com, among other places. Here are what the buttons do:
7-allows you to control red convergence
8-allows you to control green convergence (what the screen defaults to)
9-allows you to control blue convergence
+100-turns red on or off
0-turns green on or off
pre-ch-turns blue on or off
circular direction buttons-moves the cursor to a new convergence point
channel up/down-moves the convergence up or down
volume up/down-moves the convergence left or right
ONLY ON THE SAMSUNG REMOTE:
add/erase-saves settings after blinking the screen and centering the cursor
If you can find a button on the Akai remote that does that, you won't need to buy a Samsung remote.
BTW, you'll want to do this service convergence on each scan rate. So one for 480p (from a progressive scan DVD player), once for 480i (s-video source or non-progressive DVD player), and once for HD (I use my HD DVD copy of DVE).
Feb 05, 2008 | Akai PT4298HD Rear Projection Television
Red lines, Help??
when you replace the convergence amp board. u usally have to go into setup. or service mode and manualy converge the set. these settings are what perfect focus basis it reconvegence on. sort of the factory settings. these faint lines may also be a red crt overdriving too
Jan 03, 2008 | Samsung HCN5527W 55" Rear Projection...
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCM422W 42" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
