Question about Toshiba DKT-2020 Corded Phone
Changing the LCD
On my LCD panel the first line reads: SENT 214
The second line has the date & time.
How do I remove the SENT 214 and replace it with my name and extension?
  • Socorra Mar 31, 2008
    Thank you - it worked!!!
That is usually caused by a message waiting light being turned on from an extension, the message waiting feature can be used to call voicemail or to call another extension, enter code #409 on ext 214 to cancel the msg waiting light
Posted on Mar 29, 2008
I haveMy compaq presario CQ40 and my monitor screen got flicker always for past few days and more red horizantal lines @bottom of the screen, where i couldn't see the data,time,date... Plz help me...
This is usually a sign of either a bad LCD screen cable, a bad LCD screen, or a bad display adapter.
If you connect an external monitor & you get a picture without these red horizontal lines, then your display adapter is OK.
Diagnosing a bad LCD screen cable or a bad LCD screen requires that you disassemble the LCD screen panel, & swap them one at a time with a matching part. This way you can identify which part is causing the problem & replace it.
Sep 02, 2011 | Compaq Presario CQ40 Series Laptop Charger...
My hannspree monitor recently started flashing colors
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
Mar 29, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
System Date Problem in EEE PC 1005HA
As if you have tried changing the date & time in your control panel plus BIOS.There is nothing left to be done regarding changing date & time.
But If your CMOS battery in the motherboard fails,it will always goes back to it deafult date & time.Replace the battery and it will solve your problem.
I recommend to use Sony Lithium Battery
Dec 21, 2009 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Disabling users from changing system time & date?
If you're the administrator you should be able to set user permissions through the control panel. I had a Windows 2000 which had some features comparable to a 98. Most likely you will have to enter the category known as, "Administrative Tools" located within the, "Control Panel."
In this region you can change security policies, overall computer settings, and user settings (At least that's how it was on my 2000). I don't know which option you need to change to disable non-administrative users from changing time, however playing around with some of the settings might help you figure out which one it is.
NOTE: Make sure you don't change any of the settings for administrative users! If you do you might not be able to access the control panel or change administrative settings in the future.
Since I'm uncertain about this working with a 98, contact me again later notifying me if the above worked or not. I'll see if I can help you resolve this.
Mar 11, 2009 | Microsoft Windows 98 Second Edition for PC
I have breitling superocean watch.my problem is everytime i change the date the watch stops running. i have sent it back to breitling 3 times now and they say it is fixed but it stops working again. they...
you're not supposed to change the time at certain times if it is an automatic. I think any time after 8pm and before 4am (but check your manual). Apparently it messes up the mechanism. Maybe that's the issue?
Sep 06, 2008 | Watches
Lines in images
Color lines in the LCD display is caused by certain type of light connections. If you get all the time when you turn on the camera then the LCD panel is bad, would need to be replaced. Black lines in printed printed pictures from your printer or the Kodak dock station printer? If that's the case, then the transfer rollers are dirty and would need to checked or replaced. Also drivers could do this also. Report the problem to Kodak Live Chat Online Tech Rep or called on the LAN line (phone).
Jun 25, 2008 | Kodak EasyShare M853 Digital Camera
Nintendo ds
Setting the Time and Date
Changing the time
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
Dec 30, 2007 | Nintendo DS Console
Time
This should take care of it for you.
NOTE: The current date and time are displayed on the LCD when the machine is ON and ready for use (Standby mode). The date and time are printed on all faxes that are sent. When the machine is installed for the first time, the LCD will prompt for the date and time to be set.
  1. Press the [Setup] button on the Control Panel. 'Fax Number / Name' will be displayed on the LCD.
  2. Press the left or right arrow button until 'Time / Date Setup' is displayed, then press the [Start / Enter] button to access the Time / Date Setup menu. The LCD will prompt you to select a Date Format.
  3. Press the [Start / Enter] button.
  4. Press the left or right arrow button to select the required date format, then press [Start / Enter]. The LCD will display the currently set date and time using the selected date format and prompt to set the month. The cursor will be under the first digit of the month and the number will blink.
    NOTE: If you select USA, the date will be displayed in the format of Month-Day-Year. If you select Europe, the date will be displayed in the format of Day-Month-Year.
  5. Enter the correct date using the numeric keypad on the Control Panel. Each time you enter the appropriate number, the LCD will prompt for the next item to be entered in the following order: month, day, year, hour, and minute.
  6. Enter the correct time in 24-hour format using the numeric keypad. For example, enter 22:30 for 10:30 P.M. If an invalid number is entered, the LCD will not proceed to the next step. Re-enter the correct number.
  7. Press the [Start / Enter] button to save the setting and return to the Standby mode. The LCD will display the date and that has been set.
Dec 13, 2007 | Office Equipment & Supplies
Toshiba DKT-2020 Corded Phone Logo
393 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Marvin
Marvin
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
