Plasma Repair Parts
Where is the best/cheapest place to find a PCB repair kit for the lg pdp42v7 plasma that comes with the ysus ,zsus, and control board? I have found many in the UK and AU for about 200 shipped. Is there somewhere in the US that I can purchase for the same price?
I know of a comapny is RSA,? quite cheap, and lots of stock, the PDP42V7 panel had a lot of speckles issues(red green, lu dots on panel) the new ctrl board will sort it out,
Posted on Jul 24, 2008
  • 4,234 Answers
Available from tritronicsinc.com are the following:
6871QZH041A Zenith/LG Z-SUS Cost: $137.44
6871QYH036A Zenith/LG Y-SUS Cost: $238.38
6871QYH053A Zenith/LG Control Board Cost: $189.39
Hope this helps,
Dan
Posted on Mar 18, 2008
Where is Zeus board located
Samsung HP-R5072 50 in. Plasma HDTV Board ysus lg ...
www.fixya.com > ... > Samsung HP-R5072 50 in. Plasma HDTV
Samsung HP-R5072 50 in. ... LG 50PX1D, YSUS and ZSUS board replacement ... andZSUS boards and have found conflicting information. So... YSUS = .
Samsung HP-R5072 50 in. Plasma HDTV Ysus - Questions ...
LG 50PX1D, YSUS and ZSUS board replacement 1. ... right away I found a bad fuse on the ysus board and replaced it. if i unplug ysus board the unit stays on.
Jan 18, 2016 | Samsung Televison & Video
I am looking for the complete repair kit for a samsung 51 inch plasma tv model number PN51D490A1DXZA.
Samsung LCD / Plasma TV Capacitor Repair Kit ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Rating: 4.4 - ‎86 reviews
Samsung LCD / Plasma TV Capacitor Repair Kit, Replacement Parts: ... 1-220uf 25v; 4-2200uf 10v; 6-1000uf 25v; 6 Inch Solder and Solder Wick; Cleaning Swabs ... pump + Solder wire + Solder wick + CAPACITORS Replacement)-COMPLETE KIT ... In my case, the OEM capacitors did not look bad, but I replaced them all ...
Samsung PN51D530 Plasma TV Repair Kit, Capacitors ...
Amazon.com, Inc.Samsung PN51D530 Plasma TV Repair Kit, Capacitors Only, Not the Entire ... Save on the full line of Powerblanket heating solutions. ... and 8 inches of 0.1 inch (2.5 mm) copper de-solder wick are included in the kit. .... Made Easy · Look.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX SERVICE VIDEO TUTORIAL ... if you go to get tv repair kit- http://tampatec.blogspot.com/ easy ways .... The YSus/Zsus boardlook to be ok but I'm wondering if I need to replace the YSUS board> Any thoughts?
Jan 05, 2016 | Samsung Televison & Video
What does a pcb look like i want to make sure i am right
PCB means printed circuit board.All the boards in your TV are PCBs, Please specify which board. example YSus, ZSus, Power Supply. Control board, YDrivers etc
May 17, 2014 | LG 42PC3D 42 in. Plasma Television
Red picles areas
An aging plasma display and or the ysus.......zsus board set up alignments will cause this. If it is better warmed up........the ysus board may have some slow capacitors causing the adjustments to change causing mis firing pixels A qualified repair shop can check and hopefully repair this for $150 to $300 as long as the display itself is ok
Jun 06, 2010 | LG 42PX5D 42 in. Plasma HDTV
I have a lg 42pc3dv plasma tv. it made a loud pop
Looking at it from the back, the board on the left is the ysus. You should see a big red cable coming from the power supply board in the middle of the set going to the ysus. Near the red cable plug on the ysus should be a fuse. Most likely the fuse has blown. If it is you need a ysus PCB. Check out encompassparts.com. If you get a new board be sure to set all the controls on the new board to match the old board. If you don't you will have little sparkles all over the screen when it comes back on. I hope this helps. You may want to check all fuses on the power supply and the zsus which is on the right side of the set. I have seen both the ysus and zsus be bad together. Good luck and thanks.
Oct 24, 2009 | LG 42PC3D 42 in. Plasma Television
Hello, I just experienced the same problem...two pops from my LG Plasma 50X1D and now a blirred or hazy picture is all that remains. Can you please help with what and how to repair this problem? Thank you...
This problem is always either the ysus bd or zsus bd failing and sometimes both. As a rule because these boards work together as the scan and return when on fails I replace both. The part # for most versions are YSUS = 6871QYH039C and ZSUS = 6871QZH044B and can be found on either the Andrews Electronic or Vance Baldwin website.
Jun 24, 2008 | LG 50PX1D 50 in. Plasma Television
LG 50PC5D 50 in plasma
Service information may be available on LG website but I am not sure. I am sure that when the LG plasma pops and goes out a high percentage of those type failures require the replacment of the YSUS and or the ZSUS boards. I believe the YSUS is 6871QYH039C and the YSUS is 6871QZH044B. You can get those from Andrews or Vance Baldwin.
Jun 21, 2008 | LG 50PX1D 50 in. Plasma Television
LG 50PX4DR plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Jan 13, 2008 | LG DU-50PX10 50 in. Plasma HDTV
Lg 50px4d
LG 42" Plasma TV 42PX3DCV Parts - YSUS ZSUS CTRL Part Number (set): 6871VSNB03E Part Numbers (individual): 6871QYH036D, 6871QZH041B, 6871QCH053G Part Number: 6871QYH036D Description: PCB ASSEMBLY, DISPLAY YSUS ASSY 42V7 FOUND THESE ON THIS: http://cgi.ebay.com/LG-42-Plasma-TV-42PX3DCV-Parts-YSUS-ZSUS-CTRL_W0QQitemZ110086231102QQihZ001QQcategoryZ116199QQcmdZViewItem HOPE IT HELPS
Feb 26, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
807 people viewed this question
Top Televison & Video Experts
