I need a new hard drive
I HAVE AN ACER ASPIRE 3003WLCI LAP TOP WITH A 80 GIG
HARD DRIVE IN IT.
I NEED TO REPLACE THE HARD DRIVE.
CAN I PURCHASE A BIGGER HARD DRIVE (120 OR 160 GIG) AND
WILL IT WORK IN IT.
I KNOW IT IS AN EIDE HARD DRIVE.
THANKS
ROB.
You can go up to 120 GB for this model computer. Following is a link to Drive Solutions, Inc. It shows a 120 GB ATA drive available for your drive. ATA is the formal name for an IDE drive.
Here's the link:
http://www.drivesolutions.com/cgi-bin/shop/ug2store.cgi?command=listitems&kind=acl&pos=0&type=itemid&itemid=acl228
Good luck.
Posted on Mar 18, 2008
SOURCE:
Installing new hard drive in a aspire 5736z
Yes you need to install the operating system back to your computer and you also need to install the drivers and the programs on it. New hard drives are blank.
After installing everything up, don't forget to add a premium anti-virus. That's very important. You should also add a tech software like RadarSync so that you won't have to worry about getting your computer's drivers updated.
David
May 26, 2013 | Acer Aspire One PC Notebook
Am I able to replace acer aspire t310 ata 40 gig with 200 gig sata hard drive
If this model Acer has a SATA controller then yes you can, but if it does not have a SATA controller then you can only install a ATA hard drive up to 80 Gb capacity.
Jan 27, 2013 | Acer Aspire T310 PC Desktop
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
Replace hard drive acer netbook 8 gig
Back up all info
Insert CD / DVD Win OS into Cd / DVD drive
Shut down laptop / remove battery / depress strat button several times to de-energise system.
Remove tiny screws under the laptop to access HDD, Be very careful prizing off cover so as not to break it.
Remove HDD carefully, you may need to unscrew HDD
Replace with new HDD / replace cover
Start Laptop and depress F1 or F2 to get into bios, alter boot sequence to CD as first boot.
Follow on screen instructions to format HDD / load Windows.
You must have a legit copy of the Windows disc and CD key
Dec 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Have an acer aspier 3620 - it is saying operating system not found and giving me an error pxe-e61 - media test failure, check cable, it isn't even recognizing hard drive - took out hard drive and put in...
Yes, you have hard drive problem, you get PXE error becuase when it cannot bootup from hard drive, it will try to bootup through he network instead. The hard drive must show up in the BIOS. You can verify by try it in another laptop if you can.
Nov 13, 2009 | Acer Aspire 3003WLCi Notebook
Hard drive needs to be replaced
Before you do any of this make sure your notebook is unplugged and the battery is removed.
The hard drive bay is on the bottom of the notebook, there are 2 panels on the bottom of your notebook. The smaller panel, near the front of the notebook there should be a "rubber square" on the top of the panel, is where the hard drive is located, unscrew that panel and remove it then you will be able to remove the hard drive.
Apr 26, 2009 | Acer Aspire 3003WLCi Laptop...
Acer Aspire Hard Drive failure
any laptop Hdd will work as long as you know whether it is SATA or IDE.
The casing around the Hard drive will be different, but can easily be put onto the new drive, but be careful of static and dont drop it
Feb 02, 2009 | Western Digital Scorpio WD800UE 80 GB Hard...
Acer Aspire 5100-3583
What size drive is in it now? The user manual should tell you what size drive it can use. If you are not sure, the best thing to do is to go back with the same size. The brand does not matter. Is your hard drive IDE or SATA? What is the model of your laptop?
May 30, 2008 | Acer Aspire 5100 Notebook
Open Questions:
SBCglobal MAil NuMbE -+**/{1.855.536**5666}#[email protected] SERVICE This SbCgLoBaL MaiL USA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbCgLoBaL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbCgLoBaL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiL USA Calling SbCgLoBaL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiL USA's phone numbers against each other. Contacting SbCgLoBaL MaiL USA in General While I********** is SbCgLoBaL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Oct 19, 2019 | Best Computers & Internet
SBCglobal MAil HeLpliNe *:{1-855*536*5666}#[email protected] PHoNe NuMbER PREMIUM This SbCgLoBaL MaiL USA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbCgLoBaL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbCgLoBaL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiL USA Calling SbCgLoBaL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiL USA's phone numbers against each other. Contacting SbCgLoBaL MaiL USA in General While I********** is SbCgLoBaL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Computers & Internet Logo
90 people viewed this question
Ekse
Alun Cox
