Question about Kenwood KVT-719DVD 7 in. Car Monitor
In car DVD playback question?
Is there a way for the DVD to play video via the screen while the vehicle is in motion?
If I have a back seat monitor hooked up....will the head unit feed video signal to that rear screen while vehicle is in motion?
  • 3 Answers
There is a light blue wire on the kenwood adapter. It should be labled "Parking Switch". Take that wire and just ground it.
Disclaimer: I take no responsibility for any harm it may cause.
Posted on May 05, 2008
    Problem Solver:
  • 4 Answers
It will feed signal to alternate screen..but i dunno in motion..i cnt get a pic at all on mine still or motion...?????
Posted on Apr 24, 2008
When previewing my video in adobe encore, it looks fine but when i burn to dvd, the video jumps everytime the camera moves. What can i do?
This is everything from adobe encores website.
Playback issues in Adobe Encore DVD 2.0 have a variety of symptoms. The following symptoms may occur when you use the preview feature, when you play video in the Monitor panel, when you play to an external device, or when you edit a menu or slide:
-- Video or audio exhibits stuttered playback.
-- Video or audio cut in and out.
-- Audio is out of sync with video.
-- Video displays as black in the monitor panel or after burned to disc.
-- There are general redraw problems in the user interface.
-- Encore DVD returns the error message, "Invalid requested time," when you transcode a file.
Beginning troubleshooting
1. Test the DVD on a variety of players.
Not all DVD players behave the same way. By testing the DVD on a variety of players, both set-top and software, you can determine if the problem is related to the DVD itself or just the player.
2. Make sure that the system meets the requirements for digital video.
Video may not play correctly if your system doesn't meet the following requirements:
-- Intel Pentium 4, 1.4 GHz processor or faster
-- Windows XP Professional or Home Edition with Service Pack 2
-- 512 MB RAM (1 GB or more recommended)
-- Hard disk with at least 16 GB of space for installation and ongoing work (RAID recommended for HDV/HD editing)
-- 1280 x 1024 or greater color monitor resolution, 32-bit display adapter
-- QuickTime 6.5 required to support import and export of QuickTime files
-- Supported DVD burner *
-- Stereo sound card
* For a list of supported DVD burners, visit the Adobe website at www.adobe.com/products/encore/systemreqs.html.
3. Update video display card drivers.
Outdated or flawed video display card drivers may incorrectly display motion video and textures, or incorrectly report their ability to display motion video or textures to Adobe Encore DVD. Contact the video display card manufacturer for the latest display drivers and driver information.
4. Select an appropriate Playback Quality setting.
You can display playback in the Encore DVD Monitor panel at either High quality, Draft quality, or Automatic quality. By default, the Monitor panel displays video at High quality; that is, it displays all the pixels of each frame of video. When Encore DVD plays back unrendered video at High quality, the video may stutter or ****. When you select Draft quality, Encore DVD always displays video at one-half resolution in the Monitor panel. When Draft quality is selected, playback is smooth but the image quality is affected. When you select Automatic quality for the Monitor panel, Encore DVD dynamically adjusts image resolution between High quality and Draft quality to best address the available system resources.
To choose the Monitor panel playback quality, select File > Preferences > General, and then select an appropriate Playback Quality setting.
5. Deselect the Automatic option in Audio/Video preferences.
1. Choose File > Preferences > Audio/Video Out.
2. Under Video Playback, deselect Automatic.
3. In order for the change in preference to take effect, you must close the Monitor panel and then reopen it.
The Automatic option is selected by default, allowing Encore DVD 2.0 to play video in a Standard Direct3D mode. When it is not selected, video plays in GDI mode.
6. Troubleshoot slideshow playback issues.
Many DVD players, both set-top and software, handle playback of slideshows differently. To conserve disc space, Encore DVD creates an MPEG I frame for each slide then assigns a duration for that frame based on the slide's duration. Many players cannot accurately display these and will instead display only a single frame of the image before reverting to a black screen for the duration of the slide.
If you are experiencing playback issues with your slideshow, be sure to play it back using a variety of players. If you determined that slideshow playback is the issue, then you can try the following workarounds to ensure the slideshow will playback correctly on all players:
Note: The following workarounds will increase the amount of space used on the DVD.
Add zooms or pans to each slide.
When you add a zoom or pan effect to a slide, Encore DVD will render the slide as a video file instead of an MPEG I frame with duration.
Create the slideshow in Premiere Pro.
You can import all of your slides into Premiere Pro and create a slideshow there, then export the file as an AVI, import it into your Encore DVD project, and add it to a timeline.
If you create the slideshow in Premiere Pro, users cannot manually advance through the slideshow the same way they can if it was created with the Encore DVD slideshow editor. However, if you add chapter points for each image, then viewers can skip ahead before the timeline automatically reaches the next image.
Create menus from each slide and link them.
By creating menus from each slide and linking them in the desired sequence, users will have complete control over when they can advance to the next image. You can set up invisible buttons with invisible highlights to give the impression that only the image is on screen, or you can include visible navigation elements for the next and previous slide, as well as any option that is available for a traditional menu.
If you create menus for each slide and link them, then you cannot have a continuous soundtrack playing throughout the slideshow. Menus can have audio but they are specific to each menu and will start from the beginning each time you access a new menu.
Intermediate troubleshooting
7. Optimize hard disks.
Optimize hard disks by defragmenting them, updating their drivers, and configuring the disk drives. These procedures improve playback speed and performance in Encore DVD. For further assistance with these tasks, contact the hardware manufacturer or an authorized repair service facility.
-- Defragment hard disks by running the Disk Defragmenter utility included with Windows or a third-party disk utility such as Symantec Norton Utilities. If you use external (non-system) disks for video, you can reformat them instead. Be aware that formatting erases all information on the disk. For instructions, see Windows Help or the documentation for the utility.
-- Update disk drivers to ensure that they aren't damaged or incompatible with the system. If a disk was formatted with a third-party disk utility, you must use the third-party disk utility for this procedure. For instructions, see the documentation that came with the utility.
8. Test digital video playback in a third-party digital video utility.
Play your video clips in an application other than Encore DVD to try to isolate the problem. If playback is problematic in an application other than Encore DVD, the problem is not with Encore DVD; troubleshoot your system or that video file.
9. Optimize Encore DVD.
For information about optimizing Encore DVD, see the Encore DVD User Guide, Online Help, and document, "Optimize performance of Encore DVD (on Windows XP)."
Aug 20, 2009 | Brady CODESOFT 7 Premier (cs7-prem-usb)
Dvr4-alert full screen playback
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do: You need to have a TV with Video in and Video out jacks.  Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
Oct 26, 2008 | Home Security
MPEG2/4 playback on widnows media player
MPEG4 motion video can be played back with Windows Media Player 6.4 or later. MPEG2 cannot be played back in Windows Media Player. Files created with our D-snap Video Cameras are designed for playback with the included MediaStage software and our DMR-E100H DVD Recorders.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Play back in Windows Media Player
Sep 01, 2005 | Panasonic SV-AV50S Digital Camera
Sep 01, 2005 | Panasonic SV-AV25 Digital Camera
Play back and record
The SV-AV100 and the SV-AV50 come with an A/V cradle that allows you to connect to external devices for recording and playback. The SV-AS10 and SV-AV25 are not equipped for this operation.
Sep 01, 2005 | Panasonic SV-AS10D Digital Camera
Sep 01, 2005 | Panasonic SV-AS10 Digital Camera
Sep 01, 2005 | Panasonic SV-AV50 Digital Camera
MPEG4, MPEG2 - play back
Aug 31, 2005 | Panasonic D-Snap SV-AS30 Digital Camera
Kenwood KVT-719DVD 7 in. Car Monitor Logo
116 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
