Nathan, 2 Knock's are located under intake manifold.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
it should but recheck ur wires and plugs first a bad plug or wire can cause a knock ping problem and set off sensor also check the knock sensor connections at rear of engine----- the knock sensors for the 8 cyl are located under the intake manifold so its labor intensive to replace the sensor
car is 10yrs-probly due for new sensor-there r testers to do this--hav u used a tech II--is car driving ok or knocking--get some advice at a parts store
Under the intake manifold. Make sure you get the harness for the knock sensors. and clean out all of the rust and junk you're going to find donw in the holes before and after you replace the sensors.
on the 4.3l version the knock sensor is on the back left side of the engine right by the bell housing. on the bigger engines they are below the intake manifold in the engine valley
The knock sensors are located in the rocker valley underneath the intake manifold. GEt a hynes manual to assist you in replacing them. There is acertain tightening sequence when taking the manifold on and off. It is made of a composite plastic so use care and do not over tighten.
knock sensor 1
Are they 2 knock sensor on the 2011 chevy malibu 4.2
Ok i changed the one I had but its still coming up on the machine
Changed it but its still coming up that it need chaged
