Question about Samsung HCL4715W 47" Rear Projection Television
TV won't power on
Hi! Here's a description of the problem. Please let me know if it sounds like it's worth fixing. Thanks!
When the power button is pressed, the red light glows; sometimes a click occurs and sometimes not. There is no picture on the screen,however. Every now and then there will be a flash of light (which apparently eliminates the possibility of a bulb burnout).
    Problem Solver:
  • 11 Answers
On my hcll4715w set I found that the -30 and the +30 vold lines were overloading the power supply. These lines power the convergence IC's. I found the IC's are drawing too much current without having a dead short. Try replacing the convergence IC's to correct dead set.
Posted on Apr 22, 2008
I had the same problem. Turns out something called a flyback transformer went out, and it comes on a large board, not separately (go figure). This transformer powers the three crt's. 365 bucks later and its fixed, but in need of bulbs, as the edges of the picture is turning yellow, and the auto convergence just makes the picture blurry. Doing manual convergence works. Now I have a TV that probably isn't worth anywhere near what I've got in it, after $900 initially 2 years ago, $365 to repair, and who knows how much for three bulbs. I looked on Ebay and crt rear projectors arent even getting $150.................
Posted on Apr 06, 2008
  • Samsung Master
  • 8,617 Answers
Your model doesnt have a bulb. It has 3 CRTs instead. Sounds like something minor in the start up voltages. thereby allowing the start up relay to click then other times the relay doesnt click. So its either standby or start up supplies where the fault is. You can get a manual here at this link and also free support to help you figure it out.
http://servicemanuals.vstore.ca/
Posted on Mar 19, 2008
How can I get it working?
Based on your description it appears there may be something wrong with the buffer board. The repair business these days is a lost art and now all they do is identify the offending board and simply replace it entirely. There is no cheapo, cheapo fix to your issue.
Oct 11, 2015 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Philips HDTV does not turn on
i this problem is in pwoer cord u change it try to on it your problem will be sloves
if the poqwer code is ok then chak your tv trnsformer
May 15, 2008 | Quasar VV-1301 13 in. Combo
Hi, I have a 42 inch NEC plasma tv I purchased about t years ago, about 6 months ago every now and then the sound would become slightly distorted like a swishing noise shortly after the tv was turned on....
From your description, it is likely that power supply operation is becoming erratic. Because your TV is new, it probably would be worth having it fixed
Mar 29, 2013 | Televison & Video
HiI have a dell desktop and won't start. for a second the fan spin than the power button turn yellow. help
hi,
Does your desktop is making any beap sounds? Are you able to see the dell logo on the startup on the screen? Please do let me know these things.
Mar 08, 2012 | Dell OptiPlex GX280 PC Desktop
Hi our tv just won't turn on any ideas? We have pluged it into another power source and checked the cable . the cable is fine. thanks
If it does not turn on then it is usually due to a component level failure on one of the boards. Does the LED at the front blink or just stay on? Does it make a clicking noise like its trying to turn on when you press the power button on your remote? Also please let me know the make and model of the tv. Please provide this info so that I can offer you insights into the cause of the problem and how to fix it.
Sai.
May 28, 2011 | Televison & Video
Is 9 year old Fujitsu Plasmavision TV worth fixing?
Hi
Can i please know yout TV model number to assist you better.
Thanx
Jul 22, 2010 | Fujitsu Plasmavision 42" TV
Sony KV-32XBR96S Wont power on,Just makes clicking sound
I have the same problem with the power button clicking on and off was there a solution? Is it worth fixing?
Nov 30, 2008 | Televison & Video
TV flickering on and off
I will unplug the TV power cord from the surge protector and have it connect directly to the outlet first and see if this will resolve the issue,small chance but worth to try.
Secondly,if you have an universal remote control for your system,you need to let me know what kind!
Now,if you don't have an universal remote control that had programmed to either IR or RF,and you have the TV power cord connected directly to the outlet and still having the same issue,it is time for a TV repair specialist to check it out;however,if you have your TV more than 7-10 years,you might consider buying a new one,cause cost of labor and part might not be worth to fix it.
Soultiondoct
Nov 09, 2008 | Samsung HP-T4254 42 in. Plasma Television
Astar LTV-3001
I've sent you the info to your hotmail.
May 07, 2008 | Astar LTV-3201 32 in. LCD Television
Samsung HCL4715W 47" Rear Projection Television Logo
121 people viewed this question
Henry  Thomas
Henry Thomas
