Question about Hyundai ImageQuest HP4240 42 in. Plasma Television
Hitachi lcd has small green line on screenHitachi lcd has small green line on screen, how do i get rid of it?
    Genius:
  • Hyundai Master
  • 1,689 Answers
I would have to see this to make some kind of guess of where the fault is. But, usualy these types of faults are on one of the drive boards to the screen, or a bad ribbon cable or connector, or the screen itself. The set would be serviced with board, and or parts replacement.
You will have to take the set in for service.
Jerry G.
Posted on Apr 12, 2008
Have an Hitachi CP wx410, when black screen when turn on. Can see green tint at the side.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 23, 2016 | Hitachi Televison & Video
Vertical line
the LCD is not work well
you can do follow these:
1,reconnect the LCD cable (It is connected to the motherboard and LCD screen)
2,if the vertical line is still there,it means that the LCD is bad ,you need a new LCD
Feb 09, 2014 | Hitachi Ltd Projector, Hitachi,...
The TV works fine but the screen is green. Color
R G B circuit transistor to be checked. This is located in the picture
tube connecting end PCB. ( Neck ) Check the transistor and its components.
Can be dry solder also!!
Jul 28, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Small green line on right side of screen
This is an easy fix using the Philips remote control that came with your tv. On the center of the remote is a dial that has left right up down controls. Stand in front of the tv and using those controls you can recenter the screen and get rid fo the green line. I had same problem when we hooked up hd satellite reciver to philips 37 plasma
Feb 18, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Lines across screen
If the lines are slightly diagonal and in red, blue and green you have a problem in the ABL circuit. if the lines are only one color you may take the front grill cover offf and remove the panel. look fro the black box 2 inches square with 6 little controls on it. 3 are for focue 3 are for screen the middle on of the screen is the green adjustment the other 2 should be labled r and b respectivly. what ever the color of the line turn the control labeled screen and r b or g for that color ever so ligtly counter clock wise.
Mar 30, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 42edt41green static
Dave you know your stuff man !!! You helped me fix my black line fix on my LCD / Plasma and then now you helped me get rid of my green dots on my screen !! You rock . thanks a Million
Aug 07, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Hitachi Television Yellowing on the screen
Suggest you call Hitachi and complain. There is an issue with all projection LCD tvs (not just Hitachi) was that the light engine assembly did not have enough vents for cooling. This translates in a green or yellow blob that starts small and grows larger because the LCD screen frame starts to deform with the heat. Guess they did not test with young kids in the house and the tv on more than it is off :-). In March I managed to get Hitachi to pay for the part and I paid for the labor to get this fixed (out of warranty). The new light engine supposedly is better at cooling though I do see a faint 1/4 inch band of green at the bottom of the screen. Blackburn Electronics in Anderson IN has fixed many of these in the Indianapolis area.
May 06, 2008 | Hitachi 42V710 42" Rear Projection HDTV
Hitachi HDTV Model 46F500
You have two bad convergence integrated circuits and possibly an open resistor or two in the supply.
Mar 04, 2008 | Hitachi 53SDX01B 53" Rear Projection...
replace convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Hitachi 46F500 46" Rear Projection...
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Hyundai ImageQuest HP4240 42 in. Plasma Television Logo
69 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
