Question about Car Audio & Video
10.4 inch headrest lcd monitors
Headrest monitors modle T104DVPL-BK good picture and working properly on mian monitor/player but picture on second monitor grainy,defragmented when connected to audio/video 1 or audio/video 2. no signal displayed when connected to audio in video in. powers and grounds good. Battery swiched voltage. .001ohms on ground side.
  • 47 Answers
MOST OF ALL VIDEO OUTPUTS AR NOT STRONG I SUGGEST
ADD A VIDEO AMPLIFIER
Posted on May 13, 2008
SOURCE:
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
Directed 10.2
remove all the wires connected externally and then try as some of the wire has got loosed and not supporting the device to work properly.remove the wires and then reconnect it properly.
Oct 25, 2008 | Myron & Davis ADM169GY 7 Inch Flip Down...
Do you have printable installation instructions for the Roadview RHM 7.0 headrest? We seem to have misplaced ours. Thank you
Headrests slots are different in many vehicles. You can take the slots out of your other car & install them into the SUV bit it is a pain to do. Most are sewed in. Take small edged knife with thin blade, cut down the side of the slot,close to metal so to cut the stiches holding it in place. Some use Glue. Then take out other slots from headrest in SUV, same way. If glued,thats good,just glue your set to use back in. If stiched,just buy Auto Uphostery Glue & use that. Will work. Good Luck,not easy task.
May 17, 2014 | Roadview RHM-7.0 Universal Replacement...
Monitor dispaly picture for 3 to 5 second then display gone
From the description one of the inverter transformers have failed, located on the power supply/inverter board.
May 21, 2012 | Samsung SyncMaster 510N (Silver) 15 inch...
My samsung LCD monitor display blank but blue light is blink.
Check to ensure all connections are in good place and are properly connected, if they are and yet no display, the picture board on your monitor is faulty, since the power light is on, it means the picture board of your monitor has developed fault.
take the monitor to a local repairer within your vicinity to help with the replacement of the picture board.
Dec 10, 2010 | Samsung SyncMaster 740N (Silver) 17 inch...
Just bought a ForJ Dual Headrest with 7" LCD Monitors - One DVD Player from Walmart and it did not include instructions. Where can I obtain the instructions?
If you still need them, let me know I bought one as well and it had them. I will copy them for you. I can only get the one that has the built in dvd player to get sound the other has video but no sound. Let me know if yours works.
Feb 26, 2010 | MT&V Dual 7" Headrest Monitors & DVD...
How do i make the headrest poles wider?
good day, most of the headrest can be adjust horizontally just besides the poles. hope this helps, have a nice day
Feb 09, 2010 | Power Acoustik HD-8BK 8" UNIVERSAL...
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
VIZUALOGIC Headrest monitor
press menu, under the sub menu turn the parking off
Jan 07, 2008 | TMI Products Vizualogic Headrest Pair...
LCD Monitor power problems
yes the monitor is over heating there should be warranty on the montor
Dec 15, 2007 | NEC MultiSync LCD1980SX-BK 19" LCD Monitor
Car Audio & Video Logo
300 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
