Question about Whirlpool Duet Sport HT WFW8400TE Washer
Error code Sd (or 5d)
I have an error code of Sd or 5d (Whirlpool Duet Sport front loading washer). I am using the recommended amount of HE detergent so i do not believe I am ''oversudzing''. I did use an excessive amount of detergent about 4 or 5 washloads before. But on the last 2 loads I have been getting the Sd (or 5d) error. Any idea what it might be?
  • Anonymous Mar 27, 2014
    keep getting sd code even ater rewashing load with ni detergent
  • 155 Answers
It means Suds Lock(Overdose of Detergent Detected During The Wash Cycle).If suds are detected continuously by the pressure switch during the drain or spin phases,the washer will fill 4 litres of water and during 5 minutes the unit will rest without tumbling,the water will be drained and it will try to spin or drain again.
If too much detergent was used:
– Run the unit through a Rinse/Spin cycle.
– Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,pressure switch and Central Control Unit(CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test.
Posted on Apr 11, 2010
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Tip
Whirlpool duet washer F02 or F21 error code.
This error code indicates that drain times are longer than expected.
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds will slow or stop the removal of water from the washer.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Temporary fixes:
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
on Mar 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Problem draining. Getting 5d code.
Hi
Thanks for using FixYa. Error 5d means too much detergent was used. Try the following procedure---
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent. If still the problem persists, then please check the following things--
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Showing 5d and making a buzzing sound and stop in middle of washing: whirlpool duet sport front load -ghw9150p
5d is: It denotes suds lock (overdose of detergent dectected during the wash cycle).
Chances are you just put too much detergent in, or maybe the wrong detergent - make sure you're using the HE detergent.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
The error you have displayed is actually "SD", which is a SUDS detect error. This usually an indication of a restriction somewhere in the drainage system, a failed drain pump, you are using too much detergent, or you are using the wrong type of detergent. The following link explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_error
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
COURTESY:jsrock - A senior expert of fixya....
Please donot forget to rate and accept my answer...
Jun 06, 2010 | Whirlpool Washing Machines
What does 5d mean when it comes up on front load whirlpool duet
Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
Sd code: Washer sounds like it is straining during the
This is a suds error. Too much detergent,wrong kind of detergent or a blocked drain pump filter.
Remove the bottom front panel. Unscrew the filter and clean it out. Run a couple cycles with no detergent to clean out the tub. Use only HE soap and the correct amount.
More soap causes problems and does not get the laundry any cleaner.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code 5d???
sure it's not sud? if so may be oversudsingbe sure you are using an he detergent if you are and suds are and issue try cuting back on detergent
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport
5d is: suds lock (overdose of detergent dectected during the wash cycle).
Whirlpool Duet Sport HT WFW8400TE Washer Logo
14,828 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
