Question about Dyna-Glo (PPH16-LP) Utility Heater
Will not stay lit
Have a workehorse portable 120000btu heater will not burn, but you take of top half of heater housing it will burn , but put back on flame goes out
    Sergeant:
  • 288 Answers
This sounds like its being starved of oxygen. Check the air input vent and clean it.
Posted on Mar 20, 2008
SOURCE:
Pilot will not stay lit on my mr. heater buddy. where do i get a thermocouple for this buddy model no. MH9BX
First follow this trouble shooting guide to make sure you need one-http://www.mrheater.com/product/faqs/little-buddy-troubleshooting/ Then Amazon http://www.amazon.com/Mr-Heater-Pilot-Assembly-Portable/dp/B008DBRB8W Make sure it's the right one for your model heater.0810snp
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
Feb 24, 2015 | Mr Heater Base Camp Portable Buddy Propane...
Cannot get pilot lit burns blue flame but goes out
The best approach first would be to blow out the dust. There are one to two breather ports that easily get clogged. If that doesn't work it may be a bad thermocouple. It can be checked with a volt meter set to multicolored. Disconnect the thermocouple from the valve and attach the black lead to the thermocouple itself and the red to only the tip that makes contact inside the valve. Light the pilot and hold in button to begin watching the readings. 18-24 millivolts is the desired range.
Jan 17, 2013 | The Companion Group Kozy World Portable...
Little Giant Hotomatic water heater not staying lit.
Sounds like the thermocouple/flame sensor. Change it.
Mar 09, 2017 | Heating & Cooling
I tried the jumper wire solution and heater still won't stay lit.
Yes, we service all brands and buys our kit from the local lawnmower supply house.
Dec 18, 2009 | Reddy Portable Forced Air Propane Heater...
Desa model tb103 wont stay lit.
at first i thought this was a bad flame rod but the fact that it burns on low and not on high tells me that it is not getting enough gas since it burns less gas on low. there will be a tap on the burner side of the regulator, take off the cap and turn the screw clockwise to increase the gas pressure. do this in small amounts until it corrects the problem. If you have or can get a manometer, the gas pressure should be set to @7 inches of water column
Dec 09, 2009 | Reddy Heater RLP100 Portable Forced Air...
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Reddyheat rlp 100 will not stay lit, strong gas smell.
I had the same problem with my Reddy Heater PRO 100. It is the 20Lb bottle causing your problem.
I Put a 100LB bottle on and ended my problems.
Dec 31, 2008 | Reddy Heater RLP100 Portable Forced Air...
Dyna-Glo (PPH16-LP) Utility Heater Logo
149 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Matthew Boulden
john h
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
