Question about Canon imageRUNNER 5570 Copier
Trays When we print, the trays all of a sudden starting moving up and down and it prints one paper at the top then, the other tray goes down and the other sheets shoot out of the 2nd tray. How can fix this?
  • Canon Expert
  • 1,326 Answers
It is in the "additional funcation" part of the control pannel. You can program the out put tray of the finisher. You may need to find you manual or go to the "?" mark key and scroll through it till it shows info. on out put trays. The trays can be programed to out put copies,faxs, and prints on differnt trays. If you do have the manual it is listed as out put trays. It is a little hard to disscribe it without be next to a copier. you may have to pannic botton push for a few min. That is how it got changed in the first place. Good Luck.
Posted on Mar 19, 2008
When printing on the 4250, the margins are moved to the right of the paper cutting off the text. This is an XP computer and the PCL and PS drivers have been tested...
I would check to make sure that the paper trays are set properly and paper size is being detected properly. Print out the configuration page and see if that prints correctly. If it shows the same shift in image, check the paper sizes that the configuration sheet shows to make sure it is reading the trays properly. If the trays are reading properly and test print prints properly, then it is either your driver or the software you are printing from that has a problem.
To print the configuration sheet, press the down arrow button until the screen reads "information", press checkmark and then use the down arrow until "configuration page" is highlighted and then press the checkmark again. After a few seconds your page will print.
Apr 27, 2011 | Office Equipment & Supplies
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    HP Lazer 4300dtn keeps trying to print from tray 1. How can I set the default to tray 2?
    Selecting which tray is used for printing
    You can select how the printer pulls paper from the trays.
    Understanding tray order
    When the printer receives a print job, it selects the tray by trying to match the requested paper
    type and size with what has been loaded in the trays. Using an "autoselect" process, it searches
    all available trays for the paper that satisfies the request, starting with the bottom tray and ending
    with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/
    size.
    Note The "autoselect" process occurs only if no specific tray is requested for the job. If a specific tray
    is requested, the job prints from the requested tray.
     If paper is loaded in tray 1 and tray 1 is set TRAY 1 TYPE=ANY and TRAY 1 SIZE=ANY on the
    Paper Handling menu, the printer will always pull paper from tray 1 first. See "Customizing
    tray 1 operation" on page 47 for more information.
     If the search fails, a message appears on the printer control panel display requesting that
    you load the correct paper type/size. You can load that paper type/size, or you can override
    the request by selecting a different type/size at the printer control panel.
     If a tray runs out of paper during a print job, the printer automatically switches to any tray that
    contains the same paper type/size.
    The autoselect process changes somewhat if you customize tray 1 operation (as explained in
    "Customizing tray 1 operation" on page 47) or set tray 1 for manual feed (as explained in
    "Manually feeding paper from tray 1" on page 49). See if this works. Good luck !
    Jan 08, 2011 | Computers & Internet
    I wantto print from tray 2. but it always print on tray 1
    When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an "autoselect" process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
    Press the "Check" button, scroll down to "Paper Handling", press the Check button again, scroll down to Tray 2 Type and press the check button again. Select the type of paper you have in that cassette and confirm by pressing the check button.
    Nov 16, 2010 | HP LaserJet 4700N Printer
    I have this printer with 2 paper trays in it. Even though both trays have paper in them every time I try to print from tray 2 it says load paper in the multipurpose tray. Why will it not print from the...
    Check the electrical contacts on the tray. also, try cleaning the pickup roller with alcohol. the pickup roller may be out of position too. You can manually move it by hand. It should have the flat side parallel to the paper.
    May 10, 2017 | Brother HL 7050 Laser Printer
    The paper trays on my HP 4250n are now printing very slow
    check the trays and make sure that the guides and but plates are set correctly..
    I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
    Mar 31, 2010 | HP LaserJet 4250n Printer
    Default paper tray selection for HP LaserJet 4200tn
    1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
    2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
    Dec 09, 2009 | HP LaserJet 4200 Printer
    I can't print from tray 2 or 3 from either Mac or PC
    You need to remove the trys affected, most likely there is a sensor issue.
    Remove the trays and check behind them as paper sometimes falls behind blocking the sensors. If so, remove the paper.
    Also, check the paper slides in the tray themselves, remove the paper and slide them in and out all the way, put the trays back in the machine and put the paper back in the tray moving the slides right up against the paper and close the door. It should work normally from now on, if not try a reboot one more time.
    Mar 26, 2009 | Xerox Phaser 7700DX Laser Printer
    913 service motor error
    If this is the first time you have seen this error, do the following:
    1. Power off the printer.
    2. Remove all installed paper trays.
    3. Make sure the paper is loaded correctly in each tray. If it is not, reload the paper into that tray.
    4. Look up into the printer where the paper tray slides in and out. Check the feed (autocompensator) assembly for any damage.
    5. If everything is fine, reinstall the tray and power on the printer.
    6. Try printing a few print jobs.
    7. If the error does not return, continue using the printer as before. Keep an eye on it for the next few days. If the error does not return, it may have been an isolated incident.
    8. If the error returns just as soon as you power on the printer or when you try to print again, you will need to find out which paper tray/paper source is causing the problem.
    • If the printer has only the one integrated paper tray, the problem will be with either the tray 1 pick arm/autocompensator assembly or the printer's engine/system board.
    • If the printer has more than one paper tray installed, try printing from each paper tray one at a time. The best way to do this is to have all of the paper trays empty and then proceed as follows:
      1. Put paper in tray 1 only.
      2. Print from tray 1.
      3. If tray 1 works fine, empty tray 1 and put paper in tray 2 and so on until you encounter the error message.
      4. If you receive the error when printing from one particular tray, power off the printer to clear the error.
      5. Power the printer back on.
      6. Skip the faulty paper feed slot and move on to the next one (if another one is present). If you can print from all but one of the paper trays, this is the source of the problem.
        If you have extra paper trays/drawer units installed and the error occurs from only one particular source, there are some things you can do as a temporary fix.
        • If the error is occurring from an OPTIONAL paper drawer/source, power off the printer and remove the defective drawer from the printer. You will then need to set up the printer to print from a different tray. For information on removing an optional drawer, click here.
        • If the error is occurring from the integrated paper tray (tray 1) AND you have optional paper trays installed, take all of the paper out of tray 1 but leave tray 1 installed. Set up the printer to print from one of the other paper tray sources (tray 2, tray 3, multi-purpose feeder, etc.).
      7. And if your getting the same error then you need to get it serviced...
    Sep 09, 2008 | Lexmark Optra SC 1275 Laser Printer
    Only wants to print out of tray 1
    paper size or paper type is incorrectly set on trays (check settings via printers keyboard menu) or and settings in print driver are incorrect (control panel/printers and faxs right click hp icon properties
    Nov 30, 2007 | HP LaserJet 4350 Printer
    Canon imageRUNNER 5570 Copier Logo
    57 people viewed this question
    old marine
    old marine
