If you open the duplexer cover, you will see a photo interupt sensor on the right. Stick a piece of paper in it. Take the waste bottle out, so you can see the inside of the duplexer. Turn the machine on. A minimal amount of waste toner will fall, and can be easily cleaned up. There are two stacker guides in the duplexer. One stacks lengthwise, the other widthwise. If memory serves me correctly, the horizontal guide not moving, or the sensor not sensing movement causes that error. If the guide moves, the sensor is probably dirty or bad.
canon m32043 microfiche reader and printer 90 has just stopped printing. It starts but then seems to...
(More)
canon m32043 microfiche reader and printer 90 has just stopped printing. It starts but then seems to jam - I am sure it not a paper jam as the code doesnt come up. Any ideas
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is...
(More)
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is narrower, thus its dimensions are not constant.
Among the solutions I have resorted to were:
- ITB (which I cleaned);
- changed the reader unit afterwards;
- checked the mechaism responsible for the drums unit rotation.
None of the above solutions worked.
I would be extremely grateful for any hint or advice.
