Question about Health & Beauty
Conair HC90CS hair clippers problem
The unit is now making a loud noise and im not sure why, it seems to function ok, its just the loud buzz makes it hard to use. any help would be appreciated.
thanks
kim
  • Anonymous Apr 13, 2009
    Clippers buzz very loudly when use them. water stopped it for a second then it got worse
SOURCE:
SOURCE: conair hc318d reassembly
you can buy another blade set for that model. Call 1-800-3-CONAIR
Posted on May 26, 2008
SOURCE: Conair Champion Hair clipper
i have an "hc318d" conair hair clipper. i took the two screws off to oil the inside and now i can't get it put back together properly. can u help?
Posted on Sep 14, 2008
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Posted on Aug 02, 2009
SOURCE: HOW TO PUT THE SPRING BACK IN A CONAIR HAIR HC318D
I can help with this!
Posted on Aug 07, 2009
  • 30 Answers
SOURCE: Noisy wahl hair clippers
1st remove the blade. Once the blade is off grab the blade drive between your fingers, if it moves side to side without any spring pressure than the drive arm is loose from the armature. If that is tight, than the armature may be loose and lifted out of alignment. There are two screws on the right hand side of the case which hold the armature. If the screw is phillips head it is standard thread, if it is torx head it is reverse thread. loosen these screws and press down firmly on the armature. The top of the armature should be even with the top of the motor coil. If the drive lever as mentioned earlier is seperating from the armature then this should be warranty repaired by the manufacturer.
Posted on Sep 21, 2009
Conair hair clippers repair
It could be the switch is shorting out or the cord is. If it doesn't cut off when you move the cord it is prob the switch.
Apr 22, 2013 | Health & Beauty
My clippers just stopped working...just gives a light buzz
oil your blade after each use. on the side there is a blade adjustment setting. after you oil the blade turn your clipper on, turn the set screw out a few turns till the blade is free. Then turn back in till it makes a loud clacking noise. Then u will back out the set screw till the baldes stop clacking and keep oiled well.
Mar 20, 2013 | Wahl Super Taper Hair Clipper 2000 Hair...
Won't cut anything
we have had this problem many times with our hair clippers
take off the outer blade and make sure it is all clean and there is no hair within the working when rebuilding add a little regular household oil
on the side of the trimmers there is usually a little plastic screw built into the casing this is the motor adjustment turn it until the trimmers become noisy then turn back half a turn so it lowers the noise out put hence the motor speed hopefully this should work
Dec 14, 2011 | Conair HC117 Hair Trimmer
I have a Wahl 79524-6001 hair cutting trimmer. Everything was working fine during a trim and then it immediatly became SCREAMING LOUD. Usually just a nice buzz. I adjusted the black screw and...
Be sure that you have oiled the blades per the manufacturer instructions. This is essential.
The noise you've described is usually due to a problem with the blade tension. You're in the right area with the screw but it sounds like you've over-tightened it causing the blades to not move. The correct way to adjust the tension is to turn the screw clockwise with the clipper running. When the blades begin to make a chattering sound, back the screw back by a quarter turn
Oct 21, 2017 | Wahl 79111
I have conair haircut kit 10 piece and i used it on my brother and it keeps pulling his hair and i turned the power on switch it still pulls his hair whats wrong with the clippers
Sounds like you may need the blade sharpened, it may be dull, otherwise the motor may not be functioning properly. Does he have thick or coarse hair? If so, you may need to go through it lightly in sections otherwise it will for sure pull, I learned that way back in hair school long ago. :) Goodluck!
Apr 02, 2010 | Conair HC90CS Hair Trimmer
Putting back together hair clippers
are u talking about the clipper it self or the clipper blade i need to know which one
Nov 07, 2009 | Health & Beauty
I HAVE A 115V USA HAIR CLIPPER.LIVE IN UK, SO
Look on the side of the clipper handle. You ahould see what appears to be a screw. With your clipper plugged in and turned on, turn that screw with a screw driver in either direction, the noise you are talking about should quiet down quite a bit,
Aug 21, 2009 | Oster Health & Beauty
Loud buzzing on Wahl "Designer" model clippers
There is a "power screw" located on the side of the clipper opposite the switch. This may need adjusting. Take a screw driver or coin....and with the unit running......turn the screw back and forth until the clipper stops making noise. The proper position for the most power is to turn the screw intil it makes a loud noise, then turn it back just enough to get rid of it.
Jul 03, 2009 | Wahl Designer 6 (8355100)
Aug 04, 2008 | Conair 5200
Loud buzzing noise
oil the blade with clipper oil, a couple of drops on the teeth
Oct 28, 2007 | Oster 76974-160 Hair Trimmer
Health & Beauty Logo
228 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
