Question about SanDisk Sansa m230 MP3 Player
I have this problem too....
I have an MP3 player as described above, and windows xp does not recongnize new hardware when I plug it into the usb port. I have tried finding a driver, downloading, and installing, but no luck. How can I get my computer to recognize this player so I can transfer music to it?
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 26, 2008
Windows XP is having issues seeing it when I plug
As always, check your connections.
USB has at least 2 'channels' so switching ports may help.
USB has a 'resgistry' of sorts which is one of the reasons you must always plug in 'hot'.
Check hardware devices to make sure your device is not marked with '!'. If it is, right click on it and click on 'Update Driver'.
If this fails or the device is not shown, in device manager, 'uninstall' the USB controllers (you may need to have the MB driver disk/MP3 player disk handy) then click on 'Action' and click on 'Scan for hardware changes' which will reset the USB and you should now see your player/drive.
Sep 24, 2009 | Audio Players & Recorders
Sansa m240 files won't show up on computer
Uninstall/remove the mp3 player from the device manager of windows while its plugged into you computer and unplug afterwards from your usb port and plug it back in, windows now sees a new device and starts installing it.
Go to the configuration panel\system and click at the tab hardware and klik at the button device manager.
This should solve the problem.
Succes.
Aug 31, 2009 | SanDisk Sansa m240 MP3 Player
I just want to register the purchase of a new mp3 player.
Hello Sue
Windows XP finds new hardware when it is plugged in a usb port.
First reboot your computer (this resets the pc). Solves a lot of problems, too!
Plug your MP3 player into an available usb port. You may have a couple of usb ports on the front of your pc and a couple in back.
Your player will show up in MY COMPUTER as another drive such as 'E" or "J" or the name of your device.
Right click on the device icon and a menu should appear with options to register your product.
Go to the MP3 player's manufacturer's site and register from there.
Hope This Helps.
BillyReeves
May 07, 2009 | Audio Players & Recorders
Mp3 Go Gear SA 1300 is not recognized by XP
Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> Universal Serial Bus Controllers - look to see if there are any yellow exclamation marks next to any of the USB ports. If so, right-click them and select Update Driver. Good luck!
-Tha Mp3 Doctor
Jan 24, 2009 | Philips GOGEAR SA6045 MP3 Player
Computer doesn't recognize the player
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it on the back of your computer...
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
Aug 19, 2008 | SanDisk Sansa e270 MP3 Player
Windows xp will not detect creative zen vision w
There are many possible reasons:
1) USB port is not 2.0 - previous usb ports are too weak for anything but charging - go into hardware device manager and see if their is a yellow exclamation by the USB port
2) You have not downloaded the installation CD with key drivers - download the cd
3) windows is missing drivers - -go into the hardware device manager and see if there is a yellow exclamation mark by the mp3 player icon
Creative's website has an FAQ addressing the exact question you have asked
If all else fails,
-Tha mp3 Doctor
Jun 18, 2008 | Audio Players & Recorders
Not recongnizing
Try this: disconnect the player from the computer, turn it off Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 21, 2008 | RCA OPAL M4001 MP3 Player
P. o s.
mja - uninstall the "MTP Device" in the control panel using the add/remove hardware option
xeno and 123 - go to RCA's website and get the firmware upgrade -
http://support.rcaaudiovideo.com/downloads.aspx?product=25
-Tha Mp3 Doctor
Jan 15, 2008 | RCA TH1101 MP3 Player
Insignia mp3
Please provide more information on the error message.
You can use Windows Explorer to transfer files to your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your mp3 files from your c drive to the new drive for your player. You'll notice that when you delete the files on your new drive for your player that it doesnt remove them from your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. Dave@OgleServices.com
Dec 21, 2007 | Insignia IN-MP3256 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
